Old 07-24-2018, 11:35 AM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
6 lug disc rotor
Any way to buy them locally? With out having to buy them online
Calipers you can buy at your local parts store. But the rotor I'm having an issue finding them.
I'm working on buying the spindles online or shopping on craiglist
Sick5 is offline   Reply With Quote
Old 07-24-2018, 12:39 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 6 lug disc rotor
There is no factory application for this, hence why you cannot buy off the shelf locally. All of the 6 lug conversion rotors are special made for the vendors (either outsourced or done in house). You're stuck buying online.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-24-2018, 01:12 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
By from Summit Racing.
CPP brand.
Cheapest deal out there with good service from Summit.
https://www.summitracing.com/parts/clp-cp4r-6
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 07-24-2018, 04:50 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-24-2018, 05:38 PM   #5
sixty4bigwindow
sixty4bigwindow's Avatar
Huh, when I bought my CPP disc brake conversion kit, there was a sticker in the box that said that a later year 6 lug rotor could be purchased to fit. I have a horrible memory and can't remember the year range, but I'm pretty sure it was mid to late 70's c20? Because as long as the rotor is a certain diameter, and 1.25" thick with the 6 lug pattern, you should be able to use any brand. Although I could be way off, I just remember seeing that sticker in my kit.
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck...
My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023
sixty4bigwindow is offline   Reply With Quote
Old 07-24-2018, 06:50 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
CPP brand.
I agree
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-24-2018, 09:33 PM   #7
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Thanks guys
Old 07-24-2018, 09:34 PM   #8
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Any suggestion on drop spindels
Old 07-24-2018, 09:43 PM   #9
lolife99
lolife99's Avatar
Bell tech, Western Chassis, ECE, or McGaughy’s.
What year truck?
What year parts are up front?
Still drum brake or swapped already?
Keith
Old 07-24-2018, 09:51 PM   #10
62bagger
62bagger's Avatar
where are you located?
62bagger is offline   Reply With Quote
Old 07-25-2018, 01:39 AM   #11
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
What year truck?
1961
1965 parts
Drum still
Old 07-25-2018, 01:40 AM   #12
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Tracy ca
Old 07-25-2018, 05:33 AM   #13
lolife99
lolife99's Avatar
Originally Posted by Sick5 View Post
1961
1965 parts
Drum still
You need 63-70 conversion spindles.
The companies that I listed above all make conversion drop spindles.
No need to use 71-72 or 73-87 parts.
Keith
Old 07-25-2018, 10:46 AM   #14
Chevy Fleetside
https://www.earlyclassic.com/catalog...&keys=&=Search You can drive down and get them. They bolt up to the stock steering components.
Old 07-25-2018, 06:05 PM   #15
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Correct but im changing ball joints and the 7387 are cheaper
Old 07-25-2018, 08:19 PM   #16
lolife99
lolife99's Avatar
Then you have to change all the steering to 73-87 or run tie rod adapters.
You choose where you want to spend your money,...
Keith
