Old 07-31-2018, 10:26 PM   #726
karlbenz
Re: What did you do to your truck today part IV
Put the stroker motor in over the weekend, changed front driveshaft, Changed both front brake hoses. broke a bleeder. changed caliper, changed out heater core
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 08-04-2018, 03:47 PM   #727
69 C10 LWB
I pulled the 230 and installed a 350. I didn't want to do it but the 230 still wont turn so it has to come apart and I don't want to wait to drive the truck. I also learned the 73 and later manifolds wont fit our trucks, so the almost new exhaust I saved wont do me any good. The driver side manifold dumps down right where the clutch linkage attaches to the frame. It wouldnt have done me much good anyway since I left the pivot ball at home.
69 C10 LWB is offline   Reply With Quote
Old 08-05-2018, 04:30 PM   #728
karlbenz
New parklamp and headlight harness from classic parts installed today
1965 Chevy C60
Old 08-05-2018, 08:07 PM   #729
RDrancher
RDrancher's Avatar
Removed the bulk of someone's idea of custom paint and hard-as-a-rock masking tape from my tailgate.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 08-05-2018, 08:29 PM   #730
Clyde65
Clyde65's Avatar
Got him back from painter, put gas in and put him in the garage until next weekend when I’ll hopefully have time to put him back together!!
I like to say Clyde( truck) is now shacking up with Bonnie( trailer)!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-06-2018, 07:49 AM   #731
nsb29
nsb29's Avatar
It makes you wonder what goes on when the doors are closed lMAO
nsb29 is offline   Reply With Quote
Old 08-07-2018, 08:07 PM   #732
vin63
It's Better With Nitro
vin63's Avatar
Finishing up the last bit of rear suspension work this morning before the forecasted heat.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-10-2018, 11:17 AM   #733
jchav62
1962 C-10
jchav62's Avatar
Converted to an internally regulated alternator last night. Very simple and everything seems to be running much happier.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 08-11-2018, 02:13 PM   #734
69 C10 LWB
Ive been looking for a set of manifolds for the small block in my truck and stumbled on these. Loosely installed them this morning to check fit. Couldnt do much because the yard at work is wet after the rain and I dont have room inside at the moment
Old 08-11-2018, 04:01 PM   #735
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Are those chrome or stainless steel?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-11-2018, 04:21 PM   #736
The Rocknrod
Moderator
The Rocknrod's Avatar
Ive been looking for a set of manifolds for the small block in my truck and stumbled on these. Loosely installed them this morning to check fit...
And?
Old 08-11-2018, 06:08 PM   #737
69 C10 LWB
They are ceramic coated. Unfortunately I didnt have bolts to put them on but they look like there shouldnt be any issues. Clears the clutch linkage no problem but they will be kinda close to the factory starter. They are Jegs p/n 300555, I got them off Craigslist.
Old 08-11-2018, 06:24 PM   #738
forestb
forestb's Avatar
Got the truck back from interior shop on Tuesday. All and all I am pretty happy.
forestb is offline   Reply With Quote
Old 08-13-2018, 06:35 PM   #739
vin63
vin63's Avatar
Got the Poncho back in the PonchoC10...
Old 08-14-2018, 07:13 PM   #740
69 C10 LWB
Quick update on the Jegs headers. They kid of fit. Im going to have to smash a tube on the driver side or trim some metal from the motor mount. Ill probably trim the mount. The front tube is making contact with the top of the support that attaches to the frame. I also had to grind a little off the flange so that it will clear the factory temp sending unit.
Old 08-14-2018, 09:42 PM   #741
CousinTone
I’d like to ask Clyde what brand and color his owner put on him? I’ve got similar truck and would love for mine to look like you!!...if you don’t mind
CousinTone is offline   Reply With Quote
Old 08-15-2018, 07:40 AM   #742
Clyde65
Clyde65's Avatar
It’s the GM Frost White, I’ll get the brand and code for you today.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-15-2018, 04:29 PM   #743
GreyFox
Been replacing my bed wood this week. Using my 1955 Radial Arm saw I'm using 2"x8" and 2"x6" boards. only issue is I have to make all the edges 3/4" to fit properly. It's a bit of a chore to do but I have the tools to make it happen.
GreyFox is offline   Reply With Quote
Old 08-15-2018, 06:33 PM   #744
Clyde65
Clyde65's Avatar
PPG Frost White
PPG PAINT OMNI AU MBC9700 GM CODE WA8555
Clyde65
Rebuild of Clyde
support our troops!
Old 08-16-2018, 06:11 PM   #745
karlbenz
Made me a puke tank outta pvc
1965 Chevy C60
Old 08-16-2018, 06:36 PM   #746
Aceslow
Fixed some cab mounts
Picked up a 12 bolt diff
Aceslow is offline   Reply With Quote
Old 08-18-2018, 09:06 PM   #747
karlbenz
got the exhaust on the stroker today. was gonna use ram horns but seemed too close to the valve covers. Ended up getting some flotech headers from oreily's. they fit great
1965 Chevy C60
Old 08-19-2018, 07:46 AM   #748
allchevy58
allchevy58's Avatar
Installed and wired marker lights on the bed.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 08-19-2018, 07:38 PM   #749
62bagger
62bagger's Avatar
I was able t make some progress this weekend. I brought the air lines up through the floor and routed to the switches and added air gauges. I also got some sound deadener laid down.
62bagger is offline   Reply With Quote
Old 08-19-2018, 07:43 PM   #750
Ratman74
Ratman74's Avatar
did some painting on the engine
Dan "Ratman" Ratcliffe
Fourth generation Chevy truck guy, raising the fifth
1978 Scottsdale Big 10 "Bad Medicine" Daily Driver 28 yrs
1965 C10 Panel Truck "RWC" http://www.67-72chevytrucks.com/vboa...d.php?t=749003
Ratman74 is offline   Reply With Quote
