08-05-2018, 09:35 PM | #1 |
No adjusting slot on drum backing plate
My rear drum brake backing plates don't have a slot in them for adjusting the brakes. Is this the norm for our trucks? I have had other vehicles that I had to back off the brakes through the slot to get the drum off. Hate to have a drum stuck and have no slot.
1968 SWB Step Side, Big Block, 4L80E , Running! |
08-05-2018, 09:48 PM | #2 | |
The Older Generation
Re: No adjusting slot on drum backing plate
LockDoc
08-05-2018, 09:53 PM | #3 |
Who Changed This?
Yup.
08-05-2018, 09:55 PM | #4 |
Will check that out, Thanks LockDoc
08-05-2018, 10:08 PM | #5 |
Just looked at the drums ( which I had off ), and there is not even a hint of a punch out. These are likely replacement drums. I was thinking of putting a hole in the backing plate that would fit one of those rubber plugs they sell.
08-05-2018, 10:14 PM | #6 | |
I have never tried it but it should work. Let us know if you run into any problems with that. LockDoc
08-05-2018, 11:34 PM | #7 |
20' Daredevil (Ret)
My K20 still has original drums, also with no hint of a knockout. Finally drilled holes in the backing plates and put in rubber plugs a number of years ago. Works great!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-05-2018, 11:36 PM | #8 |
Who Changed This?
Weird. I've punched literally hundreds of those knockouts out of drums and backing plates (trucks and cars). I guess the new stuff from Chinee isn't provided with that feature?
08-06-2018, 12:06 AM | #9 |
I just bought new drums for my 71 and they dont have knockouts. I'd be interested to see how you cut the holes in the backing plates. Drill holes on each side and then file out the middle?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
08-06-2018, 12:48 AM | #10 | |
Value added What? |
08-06-2018, 07:26 AM | #11 |
Stocker says his original drums has no slots, so there's more to the story than cheap and/or replacement drums. So my first ? Would be to stocker- how do u confirm your drums are original ? Stamped part # maybe. Facts first
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
08-06-2018, 08:49 AM | #12 |
Think I would drill two or three holes, and then dremel them out.
08-06-2018, 09:42 AM | #13 |
20' Daredevil (Ret)
I have owned the truck since 1977 when it was 5 years old with about 50K miles. Pretty sure everything on the truck was factory original at that point, except the saddle tanks and rear bumper. If the drums had been changed before I got it, they would probably not be the same as whatever is available these days.
08-06-2018, 12:59 PM | #14 |
I have a low mile 68 that has the knockouts outlined on drums. With under 40k , I am confident they are originals. Maybe later ones don’t have the markings for knockout.
08-06-2018, 04:11 PM | #15 |
Don't blast me for mentioning this, but don't our trucks have a self-adjusting rear drum brake set-up. A few 10 mph reverse blasts, then lock up the brakes is supposed to adjust the rears drums. Might be why we see so many back plates with no holes?
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 |
08-06-2018, 04:40 PM | #16 |
The problem is when you want to take the drums off, it is nice to be able to back off a little bit on the adjuster to free up the drum.
08-06-2018, 07:41 PM | #17 | |
20' Daredevil (Ret)
Also, those adjusters operate in a nasty environment and may not work anymore. With luck, they can be cleaned & lubed and continue doing their job.
08-07-2018, 08:04 AM | #18 |
No blasting here, you are 100% correct.
08-18-2018, 09:54 PM | #19 |
Cut in brake adjusting slots in my rear drum backing plates to fit the rubber plugs I bought. This is so I can adjust the brakes initially, or back them off if I need to take the drum off, and it won't come off.
08-18-2018, 10:14 PM | #20 |
Who Changed This?
And you only have to do it once. It's worth all the sweat.
