Old 08-09-2018, 11:58 PM   #1
28TudorAZ
28TudorAZ's Avatar
Re: Starting a 52 Chevy 3100 Project.
Originally Posted by joedoh View Post
so make sure your fender style line is mostly level with the frame, it could be you have the front pointing down a little.
Thanks for the tip. I think it might have been pointing down. I loosened up the fenders from the the cab and raised it, and my dad is coming over tomorrow to help put the hood on again and we will see how it lines up.
I ended up re-using the mounts for the front end from the S10 to mount the radiator support. I am going to drill a hole in the frame and weld a bolt to the top of the frame.
28TudorAZ is offline   Reply With Quote
