Old 08-12-2018, 10:36 PM   #26
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Harmonic b
Originally Posted by LockDoc View Post
Good deal. Glad you got that solved.
LockDoc
Yup, that's the sound I was talking about. Right on!
~Steven
Simi Valley, CA
Old 08-13-2018, 01:20 AM   #27
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Harmonic b
I'm installing one myself soon. Here's an excellent video, this guy is real good, though he seems to have more faith in experience than torque wrenches https://www.youtube.com/watch?v=R7BuijqjcUk
Not saying you didn't, but the bolt inserted into the crank has to bottom out. Otherwise you're tearing up threads as you tighten the balancer.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-13-2018, 07:50 AM   #28
Grumpy old man
Grumpy old man's Avatar
Re: Harmonic b
Here is an explanation of why you apply grease to the back of the crank seal , It's just a safety measure but if the spring does come off when your replacing the seal with the timing cover on the engine it eventually will end up in your oil pan and nobody wants pieces of spring steel getting sucked up into your oil pump . I've seen it happen . This is why I pull timing covers to replace crank seals .
https://www.youtube.com/watch?v=WOfOHMI6Wnc
https://www.youtube.com/watch?v=1MzHlqQFHcs
Old 08-13-2018, 09:44 AM   #29
68ihscout
funny thing is ,that spring came flying off as soon as we took the cover off , and yes nobody wants pieces of steel flying around in there
68ihscout is offline   Reply With Quote
Old 08-13-2018, 09:45 AM   #30
68ihscout
Old 08-13-2018, 09:48 AM   #31
68ihscout
LockDoc
Thanks LockDoc
Old 08-24-2018, 03:47 PM   #32
68ihscout
Re: Harmonic b
Well folks got the truck started sounded good but now we have hemorrhage from the bottom of timing cover /oil pan meet ,would it be safe to say its the oil pan gasket ,i did replace the half moon one but i guess it did not seat correctly ,thanks again
Old 08-24-2018, 04:30 PM   #33
geezer#99
geezer#99's Avatar
Re: Harmonic b
Did you use the right one?
There are two.
Different thicknesses.
Old 08-24-2018, 05:04 PM   #34
mrein3
mrein3's Avatar
Re: Harmonic b
Back to your messed up threads in the snout of the crank.
Google "Bottoming Tap". You can usually cut a few more threads in there with one.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-24-2018, 09:56 PM   #35
garyd1961
Re: Harmonic b
I've seen people drill out a crank with stripped threads and rethread it for a larger bolt, I believe it was a 3/4 bolt.
garyd1961 is offline   Reply With Quote
Old 08-24-2018, 10:00 PM   #36
68ihscout
There are two.
I used the one that came with the timing cover gasket which was the right one ,i did put them side to side and they were the same ,.
Old 08-24-2018, 10:02 PM   #37
geezer#99
geezer#99's Avatar
Re: Harmonic b
Did you lower the pan when you put the timing cover back on?
Old 08-24-2018, 10:03 PM   #38
68ihscout
I did run a 7/16 20 in there , the initial 1/4 inch threada were bad just deep wnough for the bolt to slip ,i got a longer bolt and cut it down a bit and it was able to grab enough to tighten ,its all good now .
Old 08-24-2018, 10:05 PM   #39
68ihscout
Its all good bow ,but if i have to take it off again ill have to go that route.
Old 08-25-2018, 08:35 AM   #40
68ihscout
Oh oh ,i most certainly did not ,smh
Old 08-25-2018, 08:44 AM   #41
geezer#99
geezer#99's Avatar
Re: Harmonic b
Oh, oh is right.
Likely knocked the gasket outta place.
There’s two ways to fix it.
One is drop the front of the pan about 1/2 inch so the timing cover gasket stays in place.
Two is leave the pan alone and modify the cover bottom channel.
Like this. Pic-in here and explanation.
https://forums.iboats.com/forum/engi...ng-the-oil-pan
Old 08-25-2018, 08:54 AM   #42
68ihscout
Oh, oh is right.
Old 08-25-2018, 09:03 AM   #43
68ihscout
Oh, oh is right.
i got me in this mess , looks like ill just change the oil pan gasket and be done with it hell of a lot easier than taking timing cover off if it was the seal.
Thanks for the info and help..
