Old 08-15-2018, 01:41 PM   #1
Anthony14
I'm going crazy, need help with trans/gear ratio
I'm going crazy and need help. SBC350 and TH350 transmission. 3.42 rear end, 29.6" tires, TCI 328800 rebuild kit/shift kit, TCI Breakway 240900 torque converter. 60MPH @ 3500RPM!!?? When I installed the torque converter to get it to idle in gear (cam dur. heads etc...) it fixed that problem then had these high rpms at cruise. I tore the transmission down cause TCI and Summit said that it sounds like it was slipping. I found some burnt clutches and steelies. Installed the TCI rebuild kit and now I have the extact same problem! I should only be at 2330rpm according to Summit's gear ratio calculator. I'm outta ideas...
Anthony14 is offline   Reply With Quote
Old 08-15-2018, 02:44 PM   #2
RustyBucket
RustyBucket's Avatar
Re: I'm going crazy, need help with trans/gear ratio
Hafta ask, you're SURE it's in top(3rd.) gear?
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 08-15-2018, 02:46 PM   #3
geezer#99
geezer#99's Avatar
Maybe it’s your tach!
When you’re cruising at 60 and 3500 rpm, take your foot off the loud pedal. If it still shows 3500 then your tach is wacky. If the rpm drops a bunch you know it’s converter slip.
Old 08-15-2018, 02:48 PM   #4
Anthony14
Your not the first to ask. I dropped it into 2nd just to be sure and the rpm jumped, put back into D and the rpm dropped back to 3500rpm. So it would appear that it is going into 3rd. Also downloaded a app to track my speed to make sure my speedo is accurate - it is.
Old 08-15-2018, 02:50 PM   #5
Anthony14
When I take my foot off the rpm does fall down to around 2400/2500rpm... But TCI says it's suppose to be a 2200/2400 stall so it should be fully locked up by that rpm...
Old 08-15-2018, 02:56 PM   #6
Anthony14
TCI website has a converter slip calculator, I plugged in my info, says my converter slip is 50%!?
Why would a new converter be slipping? what can I do to fix it?
Old 08-15-2018, 03:04 PM   #7
Shinysideup
Shinysideup's Avatar
You are in 2nd gear!
1.52 is second gear for TH350
Adjust your linkages!
From this page...https://spicerparts.com/calculators/...rpm-calculator
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 08-15-2018, 03:10 PM   #8
geezer#99
geezer#99's Avatar
Turf the pos tic converter and put the old one back in.
Possible the tic was labeled wrong.
Old 08-15-2018, 03:17 PM   #9
Anthony14
I had to pull the old one out, wouldn't even idle in gear with the stock one... So I can't really just shove that one back in.
Old 08-15-2018, 03:17 PM   #10
Anthony14
Holy hell I hope your right! I'm pretty sure it is but I'll have to double check everything. Those #'s are just to much bang on.
Old 08-15-2018, 03:25 PM   #11
geezer#99
geezer#99's Avatar
Tweaking your timing curve will let you use the old one.
Old 08-15-2018, 03:37 PM   #12
Anthony14
I tried a bunch before making the purchase and couldn't get it to work.
Old 08-15-2018, 03:41 PM   #13
geezer#99
geezer#99's Avatar
Did you get close to 20 initial, 12 in mechanical, 10 from vacuum all in by 3200 rpm?
Old 08-15-2018, 04:15 PM   #14
Anthony14
Yeah, almost exactly that.
Old 08-15-2018, 09:21 PM   #15
trac209
I calculated your rpm to be 2441 at 60 with your data
trac209 is offline   Reply With Quote
Old 08-21-2018, 09:58 AM   #16
Anthony14
So my shift linkage was off. I went through it and got it fixed, but didn't fix my problem. Ran a steel line for the vacuum advanced to manifold vacuum. Disconnected the kickdown cable to eliminate it. I tried to check the stall speed of the TCI converter, suppose to be 2200-2400. One way I held the brake and mashed the pedal, went to around 3500rpm. Other way was slowly gave gas till the tires started to brake loose and that was around 2400rpm. I drove in reverse and mashed the pedal, left a fantastic burnout until I stopped. Wish it would do it going fwd... when I down shift from D to 2nd it goes from 3500rpm to around 5000rpm.
See videos...(if they worked)
View My Video
View My Video
View My Video
Old 08-21-2018, 10:12 AM   #17
geezer#99
geezer#99's Avatar
Usually when it flash stalls you only get another 400 rpm. It shoulda been 2800 and not 3500.
You got the wrong converter or a bad one from them.
Old 08-21-2018, 12:52 PM   #18
jocko
jocko's Avatar
Make sure you are referencing actual speed with a gps, your speedo is meaningless if your truck didn’t originally come with that rear gearing, which it didn’t. (Unless you’ve corrected the speedo gearing).
Also - are you absolutely certain you have 3.42s?
Old 08-21-2018, 01:06 PM   #19
Anthony14
Yep. Checked the speed with a gps and its accurate. I installed the 3.42's myself. Gm 10 bolt 8.5" rear end.
Old 08-21-2018, 01:14 PM   #20
67 chevelle
67 chevelle's Avatar
Are you sure on the rear gears , do you have enough trany fluid in it , these are basics but I have to ask
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-21-2018, 01:28 PM   #21
Anthony14
Yes. Put the gears in myself. If anything a little to much fluid.
Old 08-21-2018, 09:36 PM   #22
jocko
jocko's Avatar
Just to be clear - you're saying you confirmed that your speedometer was accurate with a GPS - or are you saying the speeds you mention in this thread are GPS speeds? If the latter, good to go. If you confirmed the speedometer was displaying accurately - then I'd ask what gear ratio did the 3.42s replace and how did you recalibrate your speedometer (i.e. for it to be accurate with a rear gearing change, the speedometer gearing would also need to be replaced to still be accurate)?
Also, can you elaborate on your shift linkage being "off"? As in, disconnected, connected incorrectly, etc.
Lastly - are you certain you have an 8 cyl tach? ( I watched one of your videos, didn't realize it was an aftermarket tach). Some are adjustable between 4,6,8 cyl - you could have it set for a 6. Just one more thing to check.
Old 08-21-2018, 09:42 PM   #23
too much stuff
Roadtrip!
too much stuff's Avatar
Being in Canada, are your RPMs metric?
Sorry, just trying to lighten the mood and maybe make you smile...
Hope you get it figured out.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-22-2018, 12:48 AM   #24
Anthony14
Correct. I used a GPS to confirm and it is accurate. When I rebuilt the trans I counted the teeth on the drive gear for the speedo and used TCI's calculator with my gear ratio and tire size to select the "driven" gear and installed that when I did the rebuild.
When I checked the install of the B&M megashifter i couldn't get the clevis to slide in and out nicely at the trans lever at all the gear positions. So i went through and adjusted the cable and now the clevis will slide in and out of the trans lever without issue at every position as per B&M's instructions.
I do have a setable tach; 4-6-8. Its set to 8, but that doesn't mean it's working correctly.
Old 08-22-2018, 12:49 AM   #25
Anthony14
Haha I did laugh. I hope its something easy and inexpensive.
