Old 08-15-2018, 01:52 PM   #1
Gls
1965 gmc 1000 Stromberg WW on a 305e rebuild question
So i got the truck a few months ago. I have cleaned, lined and sealed fuel tank, new sending unit and fuel pump and rebuilt the Stromberg ww. It runs good from idle to hard acceleration but i can not get it to idle right while in drive. It drops 300 rpms when in drive and dies. Also i have to keep my foot on the gas just a smidge while at a stop to keep it running. Would this be a linkage or power valve or vacuum. It does seem to be running rich. I have done some research on Stromberg carbs and those would be my best guess but i am hoping someone could help me out with their knowledge.
Also what plugs should i run in it? I cant get the ac c44ns i have seen recommended.
Gls is offline   Reply With Quote
Old 08-15-2018, 02:40 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 1965 gmc 1000 Stromberg WW on a 305e rebuild question
I would probably look to an air bleed adjustment issue before making any changes that cost money or parts replacements. Obviously diagnosing issues like this over the internet is just a guess, but, from your description, It sounds like the carburetor is not getting enough air at idle, especially if the engine is running rich.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-15-2018, 09:39 PM   #3
Gls
It took a little tunning and the vacuum line at the tranny was not connected.
Any suggestions on plugs?
Old 08-16-2018, 11:25 AM   #4
vin63
vin63's Avatar
Looks like NGK 6211, 6511, 7327 are possible on the cross reference chart. Might want to double check though.
Old 08-16-2018, 06:51 PM   #5
MusicMan70
MusicMan70's Avatar
Here’s a tutorial on a rebuild of a Stromberg
http://67-72chevytrucks.com/vboard/s...d.php?t=515543
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-16-2018, 10:30 PM   #6
Gls
Thank you.
Old 08-17-2018, 08:58 PM   #7
Gls
I saw a few ngk that said would work but i felt weird considering ngk in a antique gmc.
