07-31-2018, 10:26 PM | #726 |
Re: What did you do to your truck today part IV
Put the stroker motor in over the weekend, changed front driveshaft, Changed both front brake hoses. broke a bleeder. changed caliper, changed out heater core
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 1965 Chevy C50 |
08-04-2018, 03:47 PM | #727 |
I pulled the 230 and installed a 350. I didn't want to do it but the 230 still wont turn so it has to come apart and I don't want to wait to drive the truck. I also learned the 73 and later manifolds wont fit our trucks, so the almost new exhaust I saved wont do me any good. The driver side manifold dumps down right where the clutch linkage attaches to the frame. It wouldnt have done me much good anyway since I left the pivot ball at home.
08-05-2018, 04:30 PM | #728 |
New parklamp and headlight harness from classic parts installed today
08-05-2018, 08:07 PM | #729 |
Removed the bulk of someone's idea of custom paint and hard-as-a-rock masking tape from my tailgate.
Romans 10:9 - The Truth |
08-05-2018, 08:29 PM | #730 |
Got him back from painter, put gas in and put him in the garage until next weekend when I’ll hopefully have time to put him back together!!
I like to say Clyde( truck) is now shacking up with Bonnie( trailer)!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-06-2018, 07:49 AM | #731 |
It makes you wonder what goes on when the doors are closed lMAO
08-07-2018, 08:07 PM | #732 |
It's Better With Nitro
Finishing up the last bit of rear suspension work this morning before the forecasted heat.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
08-10-2018, 11:17 AM | #733 |
1962 C-10
Converted to an internally regulated alternator last night. Very simple and everything seems to be running much happier.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
08-11-2018, 02:13 PM | #734 |
Ive been looking for a set of manifolds for the small block in my truck and stumbled on these. Loosely installed them this morning to check fit. Couldnt do much because the yard at work is wet after the rain and I dont have room inside at the moment
08-11-2018, 04:01 PM | #735 |
But Found Her 25yrs Later!
Are those chrome or stainless steel?
08-11-2018, 04:21 PM | #736 |
Moderator
And?
08-11-2018, 06:08 PM | #737 |
They are ceramic coated. Unfortunately I didnt have bolts to put them on but they look like there shouldnt be any issues. Clears the clutch linkage no problem but they will be kinda close to the factory starter. They are Jegs p/n 300555, I got them off Craigslist.
08-11-2018, 06:24 PM | #738 |
Got the truck back from interior shop on Tuesday. All and all I am pretty happy.
08-13-2018, 06:35 PM | #739 |
Got the Poncho back in the PonchoC10...
08-14-2018, 07:13 PM | #740 |
Quick update on the Jegs headers. They kid of fit. Im going to have to smash a tube on the driver side or trim some metal from the motor mount. Ill probably trim the mount. The front tube is making contact with the top of the support that attaches to the frame. I also had to grind a little off the flange so that it will clear the factory temp sending unit.
08-14-2018, 09:42 PM | #741 |
I’d like to ask Clyde what brand and color his owner put on him? I’ve got similar truck and would love for mine to look like you!!...if you don’t mind
08-15-2018, 07:40 AM | #742 | |
It’s the GM Frost White, I’ll get the brand and code for you today.
08-15-2018, 04:29 PM | #743 |
Been replacing my bed wood this week. Using my 1955 Radial Arm saw I'm using 2"x8" and 2"x6" boards. only issue is I have to make all the edges 3/4" to fit properly. It's a bit of a chore to do but I have the tools to make it happen.
08-15-2018, 06:33 PM | #744 | |
PPG Frost White PPG PAINT OMNI AU MBC9700 GM CODE WA8555
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 08-15-2018 at 06:51 PM. |
08-16-2018, 06:11 PM | #745 |
Made me a puke tank outta pvc
08-16-2018, 06:36 PM | #746 |
Fixed some cab mounts
Picked up a 12 bolt diff Last edited by Aceslow; 08-16-2018 at 06:52 PM. |
08-18-2018, 09:06 PM | #747 |
got the exhaust on the stroker today. was gonna use ram horns but seemed too close to the valve covers. Ended up getting some flotech headers from oreily's. they fit great
08-19-2018, 07:46 AM | #748 |
Installed and wired marker lights on the bed.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
08-19-2018, 07:38 PM | #749 |
I was able t make some progress this weekend. I brought the air lines up through the floor and routed to the switches and added air gauges. I also got some sound deadener laid down.
08-19-2018, 07:43 PM | #750 |
did some painting on the engine
Dan "Ratman" Ratcliffe Fourth generation Chevy truck guy, raising the fifth 1978 Scottsdale Big 10 "Bad Medicine" Daily Driver 28 yrs 1965 C10 Panel Truck "RWC" http://www.67-72chevytrucks.com/vboa...d.php?t=749003 |
