09-19-2018, 10:46 PM | #1 |
speedometer reducer/gear question
I got a 1977 K10 95% original. I bought it with the speedometer not working earlier this week. I am looking for info on where to buy the Gear and reducer. Every where I have looked so far is different then what I have.
Or if there are parts I can fix the reducer with, I can possibly weld the broken spot back into the Gear. Thanks for any info, its greatly appreciated. |
09-19-2018, 11:21 PM | #2 |
Re: speedometer reducer/gear question
What tranny?
Do you have a speedo housing in the tranny? These guys have gears and reducers. https://transmissioncenter.net/?swoo...edometer-world |
09-19-2018, 11:50 PM | #3 |
Sorry I should have stated that its a full time 4wd. the speedometer hooks up to the transfer case.
it has the 400 engine and I'm pretty sure a TH700R tranny, just going off the few mins I was under the truck and seeing what the transmission pan looked like. the photo is of the transfer case number if that helps. I will get accurate information Friday when I get back to the shop. |
09-20-2018, 05:42 AM | #4 | |
Old Heap Driver
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
09-20-2018, 11:57 PM | #5 |
Update*
I was able to get the broken speedometer cable out of the gear today. Now to see if I can find a replacement for the cable part that comes out of the reducer and in to the gear itself. I was gonna call the website you guys suggested, but we had a major storm with numerous houses and power lines damaged. A normal 8 hour day turned into a 12 hour day. |
09-21-2018, 06:08 PM | #6 |
Located another gear reduction part and took the good speedo shaft out of it and installed it into my correct gear reduction unit. Still not working, thinking my speedo cable or gauge is bad.
But I got called into work so haven’t been able to go any farther with it yet. |
09-22-2018, 08:38 AM | #7 |
Moderator
Full time 4x4 is the NP203 transfer case. If the transmission is original it's either a TH350 or TH400. The TH700R4 is a 4 speed auto that was first available from the early 80's on.
You can buy that metal driven gear for the NP203. They aren't pricey. Yours looks like it's been recovered from the bottom of the ocean. Check the plastic helical drive gear on the transfer case output shaft to make sure it's not stripped. Do you have cruise control? The break in the end of the driven gear makes me think you may have a very tight or seized speedo cable or a seized or siezing up Cruisemaster transducer... or the gears in the ratio adapter are worn and bind up.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 09-22-2018 at 08:49 AM. |
09-22-2018, 10:56 AM | #8 | |
Yes the gear looks bad, its been out of the transfer case for many years it seems. I donot have cruise control option. I am planning on changing the speedo cable, also on replacing all ujoints, so ill take the tail shaft housing off the transfer case and look a the gears when I have the drive shaft out. |
09-22-2018, 03:25 PM | #9 |
Moderator
I usually replace the driveshaft bushing and seal in the end of the tailshaft housing while I have em off. It goes without saying theere's probably a bunch of crud sitting on top that you don't want falling inside the transfer case. The drive gear is not difficult to replace if it's knackered. Surprising the driven gear looks like that if it was installed...
BTW the NP 203 takes 30W non detergent motor oil. Lots of folks fill em with ATF or gear oil but the original fill was 30W non detergent. The older New Process cases are odd ducks. My NP201 in the 67 Dodge takes 50W non detergent motor oil. I run 75W90 Synthetic in the NP205 in the 72 F250... same as the axles in everything I own that has axles.
And please let us know if and how your repairs were successful. Last edited by hatzie; 09-22-2018 at 03:39 PM. |
