Detroit locker
I ended up with a 77 blazer, I was told that it had a Detroit locker. Another person said that they did not make a Detroit locker for a GM 12 bolt. Does anyone know which is correct. I am more into 3/4, 1 tons than halves, Thanks
![]() Join Date: Oct 2011
Re: Detroit locker
Prolly referring the the G80, it’s a Detroit locker. I think in 77 it was optional. GM really pushed this and still uses it today. Most older rear ends I have seen with the G80 have been broken and all the teeth are missing or in the bottom of the housing. But older trucks saw more farm use then modern trucks. Best to remove the cover and have a look see.
Re: Detroit locker
Well that is interesting, I thank you for your knowledge and reply. I am working on a septic system and a well, trying to get a plow truck running before snow, though I am really curious now (and now know what it looks like) but do not have the time at the moment nor the desire to lay in the mud to check. But its on the list. Thanks
Re: Detroit locker
2nd poster posted a link to a posi listed wrong as a locker . yes its a eaton/detroit unit .
then the g80 is NOT a detroit locker . its a posi that locks in when 1 wheel spins to fast . and they are knows to go BOOM in 10bolt / 12 bolt / 14semi float axles way more then in 14ff axles . only true way to tell is pull the cover and take pic and post up . also good time to service the rear end oil . i know whats added in to my axles each one of them as i have put them in there . thats how you know for sure .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
![]() ![]() Join Date: May 2015
Re: Detroit locker
My bad...I didn't even see the pic was wrong until you pointed it out k30...my network is running really slow for some unknown reason and i didnt see it was wrong...so I deleted it...
But yeah....pull the cover...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 09-21-2018 at 09:36 PM. |
Re: Detroit locker
mine a bit slow tonight also .
figure i would just clear it up if you missed it .
Re: Detroit locker
Well guess I will pull dif cover during a hopefully break in the rain tomorrow. 🤐 Now if i understand there could be a true locker in there, -they are made?
Re: Detroit locker
They do make detroit lockers for the gm 12 bolt truck rear end. Is the truck in running condition? If it is you can google driving characteristics of the detroit locker, they make there presence pretty easily with the clunk when you let off the accelerator. My 81 has one installed in the 12 bolt.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Re: Detroit locker
No, not running, but time, money, parts, and knowledge it could be, unfortunately I have little of those. Going to have to learn to post pictures, unsuccessful attempts so far.
Re: Detroit locker
Here's how to post pics....http://67-72chevytrucks.com/vboard/s...sting+pictures
Re: Detroit locker
Here is what it may look like if it has the G80.
Re: Detroit locker
Great picture - will look tomorrow even if it snows. I was doing ok with the picture posting, but got the "security token missing" the thread stated that was a too large of picture. Now, I need to figure out how to reduce size of a picture in my Gallery. Just never seems to end. 😂 Thanks
Re: Detroit locker
Picture of the Blazer diff.
Feel good as I have successfully uploaded a picture. Could someone tell me what it is and what I need to use to replace the diff oil. Thanks Last edited by Caminuvik; 09-22-2018 at 11:46 AM. Reason: comment |
Re: Detroit locker
Looks like a open diff....can you get a better pic of the center of the diff where the spider and side gears are?
This area
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 09-22-2018 at 12:15 PM. |
#15 |
Re: Detroit locker
I can't tell what these are outlined in red
#16 |
Re: Detroit locker
A better picture, I think.
#17 |
Re: Detroit locker
#18 |
Re: Detroit locker
Spin the diff over and get a pic of the opposite side of the carrier...
#19 |
Re: Detroit locker
opposite side
#20 |
Re: Detroit locker
I us delo that I can pick up at truck shops cheap, but I think they have it at auto parts stores as well. Service intervols on delo is way higher than most others. Or at least that's what it says on the bottle. And being the trucking industry the oils get a lot of testing and research.
Sorry, many years in the trucking industry. I even run Alison Transmission fluid in my GM truck. |
#21 |
Re: Detroit locker
good pictures, sure looks like a G80 Gov-Lock [governor locker] or affectionately called Gov-Bomb
![]() lots of good illustrations and videos out there on these.. and as mentioned, they are not the same as a Detroit Locker.. I wouldn't just willy-nilly pour TES-295 in my automotive trans without checking specs.. modern automotive ATF has gotten real slippery with non backwards compatibility.. <-- pun intended ![]() as for differentials, same issues arise, better to check specs of any oils you're planning to use.. must consider weights, friction modifiers, soft parts compatibility e.g. seals, gaskets, clutches, sensor wiring, etc.. 'high performance' for some applications may = 'no performance' for others.. good luck y'all!
I started out with nothing - and I still have most of it |
#22 |
Re: Detroit locker
I thought so also, but noticed an extra bar in the Blazer one, and in the picture of G80 on the right is that a clutch pack? Doesn't seem to be one in the Blazer diff. Could this just be an open diff?
#23 |
Re: Detroit locker
lol, I edited my post after noticing something a little different there.. oops
![]() that deserves closer inspection and/or comparisons to known stock units.. I know little more about these than what they generally look like and how they work.. other members above are much better candidates to answer that question.. good luck!
#24 |
Re: Detroit locker
Yep its a g80..govlok...youll need the correct lube for it....https://www.chevytalk.org/fusionbb/s...php?tid/256237
#25 |
Re: Detroit locker
Thanks, it been a great learning experience.
