Old 09-25-2018, 11:41 PM   #1
Quikshft
Quikshft's Avatar
L31 with mechanical clutch
Do the new L31 crate engines come drilled and tapped for the clutch cross shaft ball stud?
Thanks!
Quikshft is offline   Reply With Quote
Old 09-26-2018, 12:04 AM   #2
B. W.
B. W.'s Avatar
Re: L31 with mechanical clutch
Mine was not, had to drill & tap.
B. W. is offline   Reply With Quote
Old 09-26-2018, 12:47 AM   #3
Quikshft
Quikshft's Avatar
Excellent, I can handle that. Thanks.
Old 09-26-2018, 09:24 AM   #4
Kuzican
Kuzican's Avatar
Had to drill and tap mine to, use a sharp bit. also had to do two for the timing cover. got it running last weekend sweet engine, love it.
Kuzican is offline   Reply With Quote
Old 09-26-2018, 09:35 AM   #5
sweetk30
sweetk30's Avatar
my 4 bolt main l31 has a hole drilled / tapped just above the oil pressure port above the filter boss area .
the hole goes in to the bell housing cavity .
i think its the right one for mech clutch ? ?
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-26-2018, 10:09 AM   #6
Kuzican
Kuzican's Avatar
Yes, I put the bracket on and marked the forward hole, don’t go too deep use the bottom end tab and a real short bolt.
Old 09-26-2018, 11:58 PM   #7
Captainfab
60-66 Nut
It depends on what year truck you are installing the engine in. The '63-'66 trucks require the forward boss for the ball stud for the bellcrank.
Old 09-30-2018, 12:08 AM   #8
Chevyrestorerman
It depends exactly what year of a truck you are installing the engine into.
Chevyrestorerman is offline   Reply With Quote
Old 10-01-2018, 03:43 PM   #9
Tom
driving is in my blood
Tom's Avatar
My L31 was a take out from a 99 model and accepted a mechanical clutch in my 78 no problem. But I'm pretty sure it attached to the bellhousing not the engine. Been a while so I forget lol.
Old 10-02-2018, 12:00 AM   #10
Captainfab
60-66 Nut
Yes the square bodies have the clutch ballstud bolted to the side of the bellhousing.
