Old 10-01-2018, 04:42 PM   #26
Myself
Re: Help...1972 350 W/HEI
Was the old module AND the new module doing this?? If not, then try another module.
Myself is offline   Reply With Quote
Old 10-02-2018, 11:18 AM   #27
Travisarmenta
Travisarmenta's Avatar
Thanks for all the help fellas, especially the ones that said the ballast wire needs to be replaced, it was not.
Replaced the wire from the firewall to the Distributor and it Ran Great, all the way until it died due to carb getting too hot. only way it will start is WOT. So now onto a spacer to rectify that problem.
Any preference on spacers? for a factory Q-Jet, Factory intake.
Travisarmenta is offline   Reply With Quote
Old 10-02-2018, 11:39 AM   #28
BigRandy
BigRandy's Avatar
I only suggested you confirm the voltage to the dist since it's easy to overlook and I didn't see anything in your post indicating you had verified that - other than the swap was done by a reputable shop, but maybe I missed it.
Repairing and driving old trucks is an analog experience. No computers or sensors and they can be fixed with basic hand tools
BigRandy is offline   Reply With Quote
Old 10-02-2018, 01:05 PM   #29
geezer#99
geezer#99's Avatar
Spacer won’t cure the flooding problem!
Find out why it’s flooding.
Old 10-02-2018, 01:48 PM   #30
Travisarmenta
I can get up to 50 MPH now with no issues, but once I get to a stop light it dies and it wont start unless WOT, and even when it does start it runs like garbage.
I hit the throttle linkage on the carb and when it sprayed gas it just started smoking(out of carb) hence the spacer idea, i figured it was like that because of how hot it got.
So flooding is my main concern,
Am I wasting time and money with a spacer?
Old 10-02-2018, 01:59 PM   #31
61K10
61K10's Avatar
you said new carb? where did it come from? New or rebuilt? Some QJet experts might give you some tips.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-02-2018, 02:03 PM   #32
geezer#99
geezer#99's Avatar
Needing to go wot to start it means it needs more air to mix with the excess fuel in the carb/intake.
The smoking isn’t from heat. It’s excess fuel vapour. Looks like smoke.
Any carb that floods does that.
Look in the carb while cranking it over or when you get it running. Any fuel seen at all means it’s flooding.
Could be dirt in the needle/seat or a sunk float.
Old 10-03-2018, 07:25 AM   #33
rpmerf
rpmerf's Avatar
Agreed, stock carb on a stock manifold shouldn't need a spacer to run right. It does sound like it is running rich.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-03-2018, 08:30 AM   #34
Myself
I had one get all crazy rich on me once and a dirt dobber had decided to plug the bowl vent!!
Old 10-03-2018, 11:07 AM   #35
Travisarmenta
It def is running rich, there is soot in my exhaust tips.
Took the Q-jet apart last night, there def was some crap in there, cleaned it all up, since it was new I just decided to put it back together, transparently it needs more than just a blowout-it flooded again.
Rebuild kit on order.
Reman-dated 05/2018
Old 10-03-2018, 11:25 AM   #36
geezer#99
geezer#99's Avatar
Did you put the needle/seat back togethor correctly. The clip installed wrong causes flooding.
http://www.crankshaftcoalition.com/w...4MV_carburetor
Like in here.
Old 10-03-2018, 11:41 AM   #37
Travisarmenta
Like in here.
Yes, but I broke the Float Bowl Insert(pictured on the right) and had to use another one(pictured on the left)
https://quadrajetparts.com/used-floa...319-p-398.html
BUT because the reman one has this in it:
https://quadrajetparts.com/carbureto...ket-p-438.html
I had to shave down the sides and but out the center of it just to make it work.
I have a 71 Q-Jet, and a 72 Q-jet that don't have the repair done. but they do need a GOOD cleaning, any benefit to rebuilding one of those? Since im doing it anyway. The float hinge is different on the repaired one, that is why i needed to shave it down.
I hate to think of wasting the 500 on the reman and just shelving it, but I just want it done right.
Thoughts?
Old 10-03-2018, 12:06 PM   #38
geezer#99
geezer#99's Avatar
Gotta hate that cobbled togethor stuff.
I’d bite the bullet and rebuild one of the others with a much better kit from Cliff Ruggles.
Old 10-03-2018, 12:13 PM   #39
Travisarmenta
I figured.
That's what I'll do. Thanks again for your input.
Old 10-04-2018, 05:57 PM   #40
cadillac_al
It could just be a float adjustment. If there was trash in your new carb, I assume you cleaned the needle and seat good. Were the primary needles moving smoothly/ not jammed or stuck?. If the needle and seat looked clean and the primaries are working like they are supposed to then I would just lower the float and try it again.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-15-2018, 11:17 AM   #41
Travisarmenta
Got a hold of Cliff, Short conversation and he steered me exactly where I needed to go, Great guy.
Basic rebuild kit was purchased, used the 72 Dated Q-Jet that was organic to my Burb and runs great. No more re manufactured crap.
Old 10-15-2018, 11:42 AM   #42
geezer#99
geezer#99's Avatar
They aren’t all crap.
Sean builds nice carbs.
https://www.smicarburetor.com/
Good to see you got it fixed up.
Old 10-15-2018, 03:02 PM   #43
Dead Parrot
If you still have the stock exhaust, make sure the riser valve(if it is still there) is working. I learned the hard way many years ago that too much heat on a Q-jet can screw it up, causing severe flooding. In my case, it was a collapsed inner wall on the OEM double wall Y-pipe blocking off one side that caused the problem.
If it is too late to return your newer troublesome Q-jet, worse case, you have a nice source of spare parts for future repairs.
Dead Parrot is offline   Reply With Quote
