![]() Join Date: Mar 2013
Re: 1972 SWB Build
I've been slowly gathering parts. While talking with Texas Speed, they mentioned that my stock 24lb injectors will not be enough for my build. I did some digging and found a set of injectors from a 2012 6.0 flex fuel. Here is a picture of the stock 25317628 24lb injector on the left, and a flex fuel 12613412 50lb injector on the right. The mounting height is the same. The flex fuel doesn't have the boot on the tip, which as far as I can tell effects nothing. The flex also uses the EV6 connector. Since I am going to buy a harness, I'll just spec it with the EV6 connectors. These will be more than enough for what I am doing and probably will support a small blower in the future.
Motor is almost done Trans is rebuilt Heads are almost done Motor mount adapter plates are on the way Still need to order some big items. I'm trying to space these out a little to fly them under my wife's radar. -exhaust manifold or headers. Debating between the hooker cast manifold or tying out a set of the speed engineering shorty headers. The reviews seem favorable on them. -Boyds tank -Radiator -Wiring harness Last edited by beaterku; 10-03-2018 at 04:24 PM. |
