S10 Rear Spring Measurement
We are fixing some frame modifications made by a previous owner. We have a 1993 S10 2WD extended cab frame. Can someone tell me the following measurement for the rear leaf spring on an S10 2WD - the distance from the center of the front eye bolt in the rear leaf spring to the center of the bolt in the rear spring shackle in the frame (i.e. the center of the rear bolt that goes through the frame and the top of the rear spring shackle). Hopefully that makes sense.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
Re: S10 Rear Spring Measurement
https://www.gmupfitter.com/publicat/..._Truck_pgs.pdf
try this, start at about page 51 and go from there. the front area will show what model of truck you have so you can find the right page in the frame drawings. |
#3 | |
There are a couple of sites I like:
https://www.sdtrucksprings.com/index...oducts_id=1430 https://www.truckspring.com/Search.a...-of-Leaves:3-3 The SRI number from the first page will cross on the second page. I will often copy the specifications from the first page into Excel then add the missing information from the second page. |
#5 | |
so, basically you are looking for the dimension on the frame from the center of the front spring mounting bolt to the rear shackle hanging bolt?
looks like (for 122" wheel base) 20.94 from front bolt to axle centerline, then no dimension spec'd from axle to rear spring frame location. it's a rubber bushing in a bracket on the frame, correct? somewhere just behind the frame cross member located near there? is your frame cut up or something? missing the frame bracket? maybe worth a trip to pick n pull with a tape measure or some no stretch string and masking tape? use the string, held against the center of the front mount hole, then arced back to the rear hole. place the tape on the string at those points and mark with sharp pencil then measure the string with the tape. make sure to measure a truck like your frame donor because I think the springs have different lengths between trucks with diff wheelbase. |
#7 | |
if no responses come back from this site you might try calling a frame repair shop, they might loosen up with some dimensions for that.they have access to detailed frame measurement because they need to ensure these points are correct when they straighten a frame.
or make a trip to pick n pull, they have a website that shows if they have any of your vehicle in their yard. |
#11 | |
Wade
117 inches, it was a standard cab long bed. If you need to shorten your frame cut at the factory weld under the cab remove the 5 inches and reweld.
Jan's 53 |
like norcal says, grind off the weld under the drivers foot area, where the front suspension frame meets the rest of the frame, slip the parts together-or apart as needed, then reweld the parts back like factory. I suggest to mark the frame ahead and behind the spot so you can get everything back together the same on each side.
if your frame is hacked up you may wanna just get a new one and do it up right. the frame is the base for the rest of the truck. get that right so everything else is also right. |
Thanks guys. The frame is not really hacked up, but the rear spring shackle mount was moved - PO tried to shorten the frame from the rear
![]() The plan is to put the rear spring shackle back where it belongs and then shorten the frame properly.
#15 |
check to be sure, but some guys moved the rear spring mount because they also moved the front spring mount for wheelbase change or ride height. since the front mount is not on the flat bottom of the frame, but instead on the upswing of the frame bump over the rear axle, it can affect the ride height or driveline angle.
correct guys? been awhile since I had an s10 in the shop. |
#16 |
do you have a pic of that?
#17 |
![]() Join Date: May 2007
dsraven I think you are talking about people who LENGTHEN a shortbed s10 by moving the rear perch back 8 inches, and cut the rear 11 inches off the frame and flip it over to move the rear shackle mount back 8 inches. this gives a shortbed s10 108" truck a 116" wheelbase. because the perch moves up along the frame slightly you get a little free lowering
I havent ever seen anyone shorten an ext cab s10 by moving the perches forward, thats just a whole lot of work in the making not only for the because the axle would probably hit the frame and definitely would interfere with the gas tank crossmember.
#19 | |
Thanks for the help.
#20 |
hey driver, got a pic?
