10-24-2017, 06:02 PM | #126 |
Re: LSX swappers what ya got?!?!
[QUOTE=BR3W CITY;5896635]
[B]Model: 1970 C10 [B]Motor/transmission: 2002 5.3 4L60E [B]Fuel tank: Boyds [B]Motor mounts: Ebay [B]Tranny mount: CPP [B]Oil pan: Stock [B]Radiator: Stock 4 row [B]Shift linkage: Lokar [B]Exhaust manifolds: Trailblazer SS [B]Gears: 3:73 [B]Rear End: GM 12 bolt [B]Tire size: 275 60 18 [B]Bagged: Static 2.5" 4" [B]Running: Yes [B]Build thread: No [B]Carb or FI: Stock EFI [B]Go Fast: Blackbear Performance Custom tune Torque management removed.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
10-26-2017, 11:40 PM | #127 |
Model: 1972 GMC C10
Motor/transmission: 2001 LM7 5.3/4L60E Fuel tank: Stock in cab. Motor mounts: CPP sheet metal perches/CPP mounts & sliders Tranny mount: CPP tubular w/ poly mount Oil pan: Stock 5.3 pan Radiator: 2001 Silverado LS rad w/ LS1 EFans Shift linkage: Lokar ACA-1800 Exhaust manifolds: Speed Engineering 1 3/4 Mids w/ 3" collectors Gears: Stock, unsure of gears Rear End: Stock, 12 bolt Bagged: No. Soon to be 2" spindles/1" coil springs and lowering leafs & shackles Running: Not yet Build thread: Not yet Carb or FI: FI - External Walbro, Corvette regulator, returnless fuel rail Go Fast: Not yet |
12-07-2017, 03:15 PM | #128 |
Model: 1953 3100
Motor: 2002 5.3 Flex Transmission: Muncie M20 Oil pan: Truck Motor mounts: Custom Tranny mount: Custom Tranny Tunnel: Slight hump Radiator: Griffin Aluminum Pro Series Radiators 1-25182-X Fuel tank: Stock in cab Shift linkage: Hurst Exhaust manifolds: 1982-04 Chevrolet S10 Blazer LS1 Sonoma Engine Swap Headers Stainless by Racing Innovation Supply Gears: 2.29 (will go 3.73) Tire size: 29" Carb or EFI: EFI Bagged: No Running: Soon. ish. Go Fast: Right foot
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 Last edited by robertsjm711; 12-07-2017 at 03:21 PM. |
03-27-2018, 09:50 PM | #129 | |
03-27-2018, 10:02 PM | #130 |
that's a bee-uti-full truck Darrell
04-24-2018, 12:15 AM | #131 |
Model: 1968 C10 SWB
Motor: 5th gen Camaro LS3 Transmission: Jakes performance stage 2 4l80e Oil pan: Cadilac CTSV Motor mounts: CPP stands with DD sliders Tranny mount: Energy suspension (red) Tranny Tunnel: Low hump Radiator: Entropy dual pass with electric fans Fuel tank: Boyd’s EFI with built in Aeromotive Stealth Shift linkage: Stock for now Exhaust manifolds: Kooks TBSS long tubes Gears: 3.70 Rearend: ford 9” with Eaton Trutrac Tire size: 28” will upgrade to taller tires Carb or EFI: EFI Bagged: Static drop ECE 4/6 Running: I wished Go Fast: Custom speced Pat G cam, AI heads, Mamo 102, ported NW 102. Long tubes when I know what fits my build lol. Last edited by Ghost's68; 05-03-2018 at 08:02 AM. |
05-12-2018, 10:51 AM | #132 |
Model: 69 c10 CST
Motor/transmission: 2000 4.8/4l60e Fuel tank: universal by tanks Motor mounts: dirty dingus with stock Tranny mount: stock Oil pan: 4..8 stock Radiator: 69 stock Shift linkage: lokar Exhaust manifolds: speed engineering Gears: 3:73 Rear End: 69 12 bolt eaton Tire size: 275/60-15 Bagged: no Running: yes but not moving yet Build thread: Carb or FI: factory 00 FI Go Fast:not sure yet |
05-18-2018, 04:52 PM | #133 | |
06-27-2018, 07:35 PM | #134 |
Model: 1971 C20
Motor/transmission: 2006 6.0 4L80E Fuel tank: Stock Motor mounts: Ebay 5/16" thick Tranny mount: Stock 350 mount Oil pan: Stock truck pan Radiator: ... Shift linkage: ... Exhaust manifolds: LS 6.2 Camero Ceramic coated inside and out. Gears: 4:10 Rear End: Dana 60 Tire size: 245 75 16 Bagged: Leaf springs Running: ... Build thread: ... Carb or FI: Stock EFI Go Fast: Installing the 6.0 Torque management. LT1 swap tune |
10-10-2018, 01:47 PM | #135 |
Model: 1986 Silverado
Motor/transmission: LS3 6.2/TR6060 Fuel tank: Rear mounted Boyd's tank with internal fuel pump Motor mounts: Home made Tranny mount: Hooker double hump cross member Oil pan: CTS-V Radiator: 2004 Silverado with 2007 Silverado cooling fans Shift linkage: MGW Short Throw Exhaust manifolds: Ebay stainless headers Gears: 3.42 Rear End: 12 bolt with Eaton Diff Tire size: Front 18x9 4.5bs-275/35/18 Rear 18x10 5bs 275/35/18 Ridetech front/rear coilovers susp/Wilwood front/rear brakes Running: Like a Beast Carb or FI: Ported LS3 intake Go Fast: Stage 3 GPI heads and cam Last edited by 1957 Chief; 10-10-2018 at 02:13 PM. |
10-10-2018, 02:30 PM | #136 |
^^^ That’s dead SeXy!!! It’s what I’d like my 77 to end up like...
And, on another note... my mom’s entire family is from Beebe/Garner AR. Small world Last edited by nlped; 10-10-2018 at 03:11 PM. |
10-11-2018, 06:44 AM | #137 | |
Model: 1956 GMC Motor/transmission: 2005 6.0 / 4L60E w/Yank SS3200 Engine mods: bored .020, flat top pistons, TS&P 224R cam Fuel tank: aluminum aftermarket with silverado fuel pump Motor mounts: custom stands to early sbc pedestal style Tranny mount: modified 2nd gen F body cross member Oil pan: F body LS1 Radiator: champion Shift linkage: Lokar cable, column shift Exhaust manifolds: Dougs D314 headers for 73-87 LS swap Gears: 3.07 Rear End: dana 44, 1990 corvette Tire size: 275/40r18 front, 275/40r18 rear Bagged: no Running: yes Build thread: in my sig Carb or FI: stock efi with flex fuel injectors
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 Last edited by OKGMC4; 10-11-2018 at 06:51 AM. |
10-16-2018, 02:04 PM | #138 |
Model: 1971 GMC Custom
Motor/transmission: 2006 Tahoe L59 5.3/4l60e Fuel tank: 1987 Blazer 25 gallon Motor mounts: DD sliders Tranny mount: Stock 350 mount Oil pan: Stock truck pan Radiator: American Eagle W/ Electric fans Shift linkage: Lokar Exhaust manifolds: 2012 Camaro Gears: 3:07 Rear End: 12 bolt Tire size: 235 75 15 Bagged: Leaf springs Running: yes Build thread: no Carb or FI: Stock EFI Go Fast: Not yet |
10-18-2018, 01:10 PM | #139 | |
Update: Model: 1972 GMC C10 Motor/transmission: 2001 LM7 5.3/4L60E Fuel tank: Stock in cab. Motor mounts: CPP sheet metal perches/CPP mounts & sliders Tranny mount: Dirty Dingo Oil pan: Stock 5.3 pan Radiator: Champion Radiator with Efans/Shroud Shift linkage: Lokar ACA-1800 Exhaust manifolds: Speed Engineering 1 7/8 LTs Gears: Stock, unsure of gears Rear End: Stock, 12 bolt Bagged: No. 4” drop leafs/3” drop springs. Not low enough. Running: Yes Build thread: Yes - http://67-72chevytrucks.com/vboard/showthread.php?p=8356099#post8356099 Carb or FI: FI - External Walbro, Corvette regulator, returnless fuel rail Go Fast: TSP Stage 2 Truck Cam low lift, PRC 5.3 Stg 2.5 Heads Last edited by '68 C10; 10-18-2018 at 01:17 PM. |
11-09-2018, 10:57 PM | #140 |
Model: 1967 C10 SBW,SWB fleetside
Motor/transmission: 480 horse LS3 with Tremec tko500 Fuel tank: Boyds welding tank Motor mounts: SBC+ ebay brackets with CPP stands Oil pan: Chevy performance Hot Rod Pan Radiator: Entropy with dual fans Shift linkage: mid shift with Lokar 16" curved shifter handle Exhaust manifolds: Doug Thorley 1 5/8th"s tri y headers Gears: 3.73 Rear End: Truck 12 bolt, 5lug Henry's Axles Tire size: Rear 265/70/15 on Halibrand style repros Bagged: no Running: not yet... Build thread: Carb or FI: FI with GM controller Last edited by the ideaman; 11-10-2018 at 08:09 AM. |
12-28-2018, 08:29 AM | #141 |
01-12-2019, 02:47 PM | #142 |
Model: 1965 c10
Motor/transmission: 2008 Ly6 6 litre /4l80 2500 stall, TSP cam etc Fuel tank: My own custom aluminum under bed Motor mounts: dirty dingo sliders with stock Tranny mount: CPP Oil pan: Gm performance muscle car pan Radiator: 65 stock Shift linkage: lokar Exhaust manifolds: speed engineering 1 7/8 long tube Gears: 3:07 for now going 3:73 and posi soon Rear End: 65 12 bolt Tire size: 275/50/20 235/50/18 Bagged: Rear bagged front drop spindle Running: yes Build thread: Carb or FI: factory Go Fast: |
01-22-2019, 05:45 PM | #143 |
the truck in my profile pic was built by me in 2015, 2003 6.0 lq9 drive by cable, tied to a 700r4, ss gas tank between the frame rails, duals all the way to the bumper, daily driver. youtube page= Dennis Catlin
She is up and running- youtube Last edited by dcatlin; 01-22-2019 at 06:02 PM. Reason: add picture |
01-23-2019, 02:43 PM | #144 |
Model: 1970 K10
Motor: 2011 L96 w/VVT Transmission: 2011 6L90E Trans Case: NP 205 with Atlas Kit Oil pan: Stock Motor mounts: Dirty Dingo Tranny mount: TBD/Custom Fab Tranny Tunnel: High Hump Radiator: TBD Fuel tank: Boyds is the plan... Shift linkage: TBD Exhaust manifolds: Stock Gears: 4.10 Tire size: 35" Carb or EFI: EFI Bagged: can you call a 6" lift bagged? Running: not yet...deep in progress... Go Fast: Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=773647 |
01-26-2019, 02:33 AM | #145 |
Model: 1981 c30
Motor/transmission: LQ9/NV4500 Fuel tank: stock Motor mounts: stock with ebay adapters Tranny mount: stock Oil pan: stock Radiator: stock Shift linkage: stock Exhaust manifolds: stainless headers Gears: .10 Rear End: 14bolt Tire size: 30" Bagged: no Running: yes Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Carb or FI: FI Go Fast: it will
12-07-2020, 04:22 PM | #146 |
Model: 1965 GMC short Fleetside
Motor/transmission: 2008 Gen IV LMG 5.3/4L60E Fuel tank: Tanks Inc USPT-GH Motor mounts: Blackheart Racing plates (3rd position forward) POL tubular mounts Tranny mount: aftermarket modified for exhaust Oil pan: Stock 5.3 pan Radiator: RND Fabrication (forum sponsor discount) Shift linkage: Art Carr Winters 177-1 Exhaust manifolds: Speed Engineering shorties Gears: Stock, 3.42 Rear End: Stock, 12 bolt 79C10 Lowered: 2 1/2" drop spindles, Jeep rear coils Running: tip top Build thread: yes Carb or FI: factory FI - internal Walbro, Corvette regulator, returnless fuel rail Wheels: 17 x 8, 4"bs, US Mags Ramblers 235-60-17 and 255-60-17 |
12-15-2020, 09:39 PM | #147 |
Roto Reuter thats the name...
Model: 1970 K10 swb fleetside
Motor: 2000 5.3L LM7 (Yukon) Transmission: 4L60E Level II rebuid from Bowtie Overdrives Oil pan: Tilden custom fabricated Motor mounts: Pacific Fabrication / Tilden Motorsports 4WD crossmember with motor mounts Tranny mount: Stock with Advanced Adapters 4L60E to NP205 Tranny Tunnel: High hump Radiator: Northern Radiator 209603B with dual Spal electric fans Fuel tank: Ricks stainless tank with Walbro in tank pump Shift linkage: Column/Lokar Exhaust manifolds: Speed Engineering headers model 25-1021 Gears: 3.73 Tire size: 33"x12.5"x15" Carb or EFI: EFI Bagged: No, 2-1/2" lift kit by Skyjacker Running: Yes Go Fast: It Goes Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=782232
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-09-2021, 06:10 PM | #148 |
Still very much a project
Model: 1964 C10 Fleetside SWB Motor: 2003 5.3 (Tahoe) Transmission: 2003 4L60E with Corvette servo (Tahoe) Oil pan: 2003 Tahoe Motor mounts: ICT Tranny mount: Dirty Dingo Tranny Tunnel: Low hump Radiator: CC284 Champion LS swap radiator Fuel tank: No Limit 19 Gallon aluminum tank Shift linkage: None yet Exhaust manifolds: Speed Engineering longtubes Gears: 3.73 Tire size: 28" Carb or EFI: EFI Running: not yet... Build page: https://67-72chevytrucks.com/vboard/...d.php?t=812156
1964 C10 Rusto-mod 5.3L - L59 |
02-11-2021, 12:54 PM | #149 |
Model: 1970 Custom CST LWB K10
Motor/transmission: 2008 ly2-4/L60E Fuel tank: 90 Blazer tank in rear pump in tank with filler in taillight Motor mounts: Custom Tranny mount: 90 burb Oil pan: Stock 2008 Radiator: Champion Aluminum with 2 electric fans Shift linkage: Stock Exhaust: All SS exhaust with Shorty headers and cutout/Magnaflow Gears: 3.73 Posi Rear End: 12 Bolt Front Dana 44 Tire size: 33/12.50R15 on 10 Alcoa's Lift: Custom 5" Lift Running: Yes, build is almost complete. Build thread: See signature Carb or FI: Stock EFI Go Fast: TorqueStorm Supercharger Picture is from sometime back but you get the idea!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
12-10-2021, 09:27 PM | #150 |
Model: 1950 Chevy Roadster pickup
Motor/transmission: 5.3 LM7 - 4L60E Fuel tank: Custom Motor mounts: ICT Billet and Prothane Tranny mount: Custom Oil pan: TSP Radiator: Champion Shift linkage: Lokar floor shifter Exhaust manifolds: Block Hugger SS Gears: 3?? Rear End: Nova Tire size: 235/55/17 27"tall Bagged: No Running: Yes Build thread: See signature bottom of page (start on page 76) Carb or FI: EFI Deepmotor fab. intake Go Fast: crusier
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 12-10-2021 at 09:34 PM. |
