1966 CHEVROLET suburban engine question
I want to verify the date on the engine block of the 327 that came out of my 1966 Suburban. Casting # on rear of block is 3858174. The other casting numbers I find are on the back of the block which would be under the flywheel. H5 174. Is this the date or do I need to look somewhere else for the date? Thanks, Jim
60-66 Nut
Re: 1966 CHEVROLET suburban engine question
The casting date is cast into the block on the passenger side of the block, above where the flywheel is. It does consist of a letter which corresponds to the month of the year, then the day of the month and then the year as a single digit.
Here is a photo of the back of the block. Any ideas on date?
60-66 Nut
That looks like it is behind the flywheel.....I do not see any date code there. The date code is located where I previously said.
This is on a big block but a small block casting numbers and date codes are in the same location. http://www.67-72chevytrucks.com/vboa...d.php?t=773368
just had to look in the correct spot and scrape off some grease to find it!
60-66 Nut
Does that say B 4 6 ? If so, the block was cast on February 4th 1966. The casting number does show to be a 1964-67 327. What is the stamping on the front pad?
Yes B 4 6 . I will check stamped number on front.
stamping on front reads FO2O9YD
![]() Join Date: Nov 2012
So far so good. Block cast on Feb 4, final assembly on Feb 9. At Flint Engine Plant on Bristol Road, which is gone now.
60-66 Nut
Thanks for all the information and help. Everything seems to line up good as original engine. J
It does have the plugs in the exhaust manifolds where the A.I.R. system used to tie in.
