Old 10-17-2018, 09:05 PM   #1
crewcabshorty
crewcabshorty's Avatar
k 30 wheels
I am having tire to pitman arm interference on my 1985 k 30 . I am running 16 x 8 Alcoa wheels with 4.5 in backspacing. When i turn to the left , my Toyo mud terrains rub on the pitman arm . What wheels are you guys using ? My tire size is 305 /70/16.
crewcabshorty is offline   Reply With Quote
Old 10-18-2018, 11:07 AM   #2
sweetk30
sweetk30's Avatar
Re: k 30 wheels
need way more info . even pics maybe .
front axle ?
4wd steering box or 2wd for crossover ?
pitman arm on box ? or steering arm on axle ? lots of people mix these up .
drop pitman arm or raised steering arm like a dodge arm ?
i use to run hummer h2 17" rims with 5" backspace and the 35x12.50x17 tires and had no problems on my k30 with dana 60 front and 2.5" drop pitman arm .
something is funky in your setup . or that specific tire is just that wide . and the 305/70/16 is just a fat 33" tire .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-18-2018, 12:35 PM   #3
crewcabshorty
Re: k 30 wheels
Thanks . I have pretty much stock k 30. A 2 1/2 inch skyjacker lift on the front. Then tires are rubbing on the 2 in dropped pitman arm that is on a stock steering box . The side treads on these tires are really aggresive. That might be the problem.
Old 10-18-2018, 02:30 PM   #4
sweetk30
sweetk30's Avatar
Re: k 30 wheels
o.k.
step 1 you prob dont need the drop pitman arm for a 2inch lift kit . there has been lots of debate on this over the years and stephen from offroad design did a huge info post on ck5.com about this .
you WANT some down slope from the pitman arm down to the axle steering arm . if its level or nose low this will create some problems.
and #2 as you said the HEAVY side lugs can play hell on some combos of vehicle . see it a lot over the years . if its just a little bit of kiss then keep a eye on it at full turn's . if its a lot then it might be time for a wheel spacer . but make sure you have good lugnut thread engagement after install of a spacer .
nice to see a semi local guy . 250 miles west of me and a tad south .
Old 10-21-2018, 09:16 PM   #5
GSP7
GSP7's Avatar
Re: k 30 wheels
You should have got 285/75/16, same height if not taller
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 10-22-2018, 10:30 AM   #6
sweetk30
sweetk30's Avatar
Re: k 30 wheels
the 285 is tall skinny of the 33"
the 305 is fat brother of the 33"
Old 10-23-2018, 11:22 PM   #7
GSP7
GSP7's Avatar
Re: k 30 wheels
Not tall and skinny
Good, correct proportion
305/70s are overly too wide for the size and look wrong on 8" wide rims
Old 10-24-2018, 08:33 AM   #8
95 S_Trucker
95 S_Trucker's Avatar
Re: k 30 wheels
Originally Posted by GSP7 View Post
Not tall and skinny
Approved rim width on the 305/70/16 is 8.0-9.5
Approved rim width on the 285/75/16 is 7.5-9.0
Some people like the biggest looking tire possible.
I run 285/75/16 on factory 16x6.5 wheels. They look great and don't wear funny.
95 S_Trucker is offline   Reply With Quote
Old 10-24-2018, 11:03 AM   #9
sweetk30
sweetk30's Avatar
Re: k 30 wheels
i am doing the 255/85/16 on stock 16" steels my self with hub caps .
rear was a tad tall yet . i took about 2" out of the rear height . and no driveline in it yet for weight . 3" front lift and with 2.5" flip kit rear .
Old 10-26-2018, 10:11 AM   #10
GSP7
GSP7's Avatar
Re: k 30 wheels
I run 315/75/16 on 16x4" wheels. Look great
