10-13-2018, 04:16 PM | #1676 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Haha, seems like it’s mostly just you and me anymore these days...
Thanks Mike! It is proving to be somewhat of a pain, like most things. I did receive the Retrosound faceplate so I can tweak the hole. I was pretty close on the first shot, just needs minor work with a file to provide enough clearance once painted. More to come, soon. Spending some time getting a heater setup in my workspace, as winter is pretty much here in UT already
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-13-2018, 04:19 PM | #1677 |
A guy with a truck
I pulled into the garage after work yesterday to find this:
I don’t know if it’s a seasonal thing or if it’s some comment on how long this project is taking
10-13-2018, 08:23 PM | #1679 |
If it's still there come Christmas time, I think you may have found your answer.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
10-13-2018, 08:50 PM | #1680 |
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
10-16-2018, 08:08 AM | #1681 |
I'm just glad to be here!
Very funny. I'm guessing you wife is trying to tell you something???
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
10-16-2018, 09:12 AM | #1682 |
Hahaha nice job on the dash repair for the radio opening.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
10-16-2018, 01:00 PM | #1683 |
I like her sense of humor!!!!
I did this a couple of years ago with my '48 Farm Truck ....think mine is a distant, dusty cousin of yours(skeleton, that is)
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 10-16-2018 at 05:28 PM. |
10-17-2018, 03:32 PM | #1684 |
A guy with a truck
Thanks dudes, it was a fun surprise.
@rustytruck: I like what you did there. I always thought it would be fun to use the truck for a hayride, or maybe stuff a dead dummy underneath as though the suspension a had collapsed on it. Maybe next year...
10-17-2018, 08:57 PM | #1685 |
That would be cool...I'm trying to get the brakes fixed on the '72 in time for a Trunk-or-Treat this weekend
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
10-22-2018, 12:19 AM | #1686 |
A guy with a truck
Well, the new axles arrived in short order (next day from Summit for most things here), but the dimensions are not exactly the same as the stockers that I removed. It’s only a few thou here and there, but enough to require a trip to the machine shop. If I’d known, I would have just ordered a set of Mosers and been done with it. Oh well...
10-22-2018, 12:30 AM | #1687 |
A guy with a truck
So while the axles are at the machine shop, I figured I’d tear into the little five-three for some freshening and upgrades. So far I’ve got it all torn down and have cleaned the carbon deposits from the pistons and combustion chambers. It’s now sitting at #1 TDC awaiting installation of the BTR truck cam.
While it’s apart, it will also get new lifters, hardened pushrods, valve springs, oil pump, timing chain, and gaskets. This was a good running motor, so I’m not rebuilding the bottom end, just freshening her up a bit. Hope that doesn’t come back to bite me like every other time I try to cheap out (see axles above)...
10-22-2018, 04:53 PM | #1688 |
That was a good helper at one point...
I guess your wife is tired of waiting on this one. We're glad you're back on it too though.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
10-23-2018, 10:00 AM | #1689 | |
So far it has held good oil pressure and runs smooth...
10-24-2018, 12:47 AM | #1690 |
A guy with a truck
Good to know, Aggie, these are pretty astounding little engines. Fingers crossed...
New cam, timing chain, oil pump, and f-body oil pan are installed Next up is valve springs, then bolt the heads back on and she’ll be ready for a coat of chevy engine orange
10-29-2018, 10:30 AM | #1691 |
You’ll be good to go with your engine upgrades. I did the same with my 6.0 in the GMC and had zero issues. Actually contemplating doing the same thing to my 5.3 for the Burb. What kind of gains are you looking to make with the upgrades?? Keep up the great work!
10-29-2018, 12:38 PM | #1692 |
A guy with a truck
Thanks, fingers crossed! From what I’ve seen, I’m guessing somewhere in the neighborhood of 400 at the crank. Should be plenty of fun with the Muncie and 3:73s. Reminds me, I need to start looking for an Eaton carrier...
11-05-2018, 01:14 AM | #1693 |
A guy with a truck
Welp, the long block is completely reassembled with the new cam, lifters, hardened pushrods, valve springs, valve seals, oil pump, timing chain, and head gaskets/bolts. Nothing pic worthy to write home about, but a significant step nonetheless. She’s now ready for final scrubdown and a coat of chevy engine orange before stabbing for (hopefully) the last time.
Also did some work on the radio opening in the dash. Turns out I mis-measured one of the holes, so out came the cutoff wheel to reaccomplish what I thought was complete work. Ah well, it’s now all squared-away in primer, ready for final sanding and paint. Starting to feel some momentum, wonder what will go wrong next
11-09-2018, 12:54 AM | #1694 |
A guy with a truck
More progress with the dash final sanded, in color, and cleared. Color match is pretty good and the clear laid out nicely. I got some trash in the ashtray lid that I hope to wet sand out, but overall I’m pretty happy with how this turned out
11-09-2018, 06:08 AM | #1695 |
Nice work, Chris. Nothing like a factory unmolested dash. I thought you had a blemish in your paint, but it was my dirty screen
Great work so far!!!
11-09-2018, 11:32 AM | #1696 |
A guy with a truck
Thanks! It’s not perfect, but nothing on this truck is, so it blends right in
11-09-2018, 05:02 PM | #1697 |
Nice job Chris!!! Love that color!!
11-09-2018, 09:14 PM | #1698 |
Looks better than I could have done! I have runs in the paint on my engine block... But nobody will see that unless they want to change the oil for me, which I don't think will ever happen.
I can't wait to see this truck on the road.
11-10-2018, 01:19 AM | #1699 |
Really looks nice man. Is that a factory color? Medium blue? What kind of spray gun did you use?
Brian |
11-10-2018, 01:45 AM | #1700 | ||
A guy with a truck
Thanks a lot! I like it, too and it’s on the list of potentials if I ever decide to make this a shiny truck.
It may be driving soon-ish? I feel like it’s gaining momentum and most of the big stuff is either bought or planned for. Just gotta stay focused... Quote:
Believe it or not, this was a rattle can job; the base I had custom mixed at my local paint shop and the clear is a 2K hardened product from SprayMax. The clear is excellent and rivals the quality you get from “normal” 2-part paints. The can has a special nozzle that fans the spray pattern which makes the paint lay really nicely. Not a cheap spray bomb, but perfect for this small job. I’ll have to break out the HVLP when it’s time to squirt the firewall.
