Trans cooler, too big?
So I had this oil cooler I bought years ago for a project that never materialized. Thought I might use it for the trans in my truck now that I'm LS swapping.
I live in DFW Texas so it gets somewhat warm here. This is mostly just a fun driver, but I'd like to be able to take road trips and tow a car or whatever and you know, use it like a truck also. I have to admit I'm quite ignorant with regard to anything towing related! Truck specs: 1979 Big 10 long bed 6.0 (LQ4, probably) BTR Stage IV truck cam Rebuilt & beefed up 4l80e Circle D 3200 converter 3.73 posi Oil cooler specs: Earls 42510ERL Number of Cooling Rows: 25 Core Height (in): 7.750 in. Core Width (in): 9.000 in. Core Thickness (in): 2.000 in. Is this going to be too big or should I just run it? Last edited by mplex2000; 10-15-2018 at 07:38 AM. |
Re: Trans cooler, too big?
In my eyes there is no such thing as too big trans cooler . You would benefit from a large cooler . Your trans need a cooler for sure with that stall and especially towing with it . Put as big as cooler as you can fit .
You need a cooler regardless if you tow or not . That stall will generate some heat . Biggest killer of a trans is heat . |
I put a trans temp gauge on my truck 20 years ago and it never over heats. I guess I don't tow enough.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Like homemade87 said, I'm going to need one regardless due to the higher stall with my converter, adding towing to the mix should make for a very hot transmission without an additional cooler. I'd imagine Maine is a bit cooler than Texas as well
![]() Join Date: Jun 2016
Route it this way - Trans > external cooler > factory cooler (radiator) > trans
Contrary to popular belief, you CAN overcool a trans. You want it running right around 180 degrees. Routing this way does a few things - First, keeps the hottest fluid out of the radiator. Why would you want to put the hottest fluid into the cold side of the radiator? So this takes some of the load off of your engine cooling system. Second, when it is cold it can put some heat back into the fluid so you don't overcool it.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
x2 on too cold a fluid .
add a gauge in the pan AND 2nd sender in hot line out from trans to cooler . then install toggle switch for the sender wires feeding the gauge . this will let you know how hot you are working the trans and for the reg driving just the pan temp will be fine . . . only if you like to know lots of info do it this way . also they do make automatic thermo switches for fluid control that you can plumb inline so it flows stock and when it gets to a specific point ( temp range you ordered ) it will flip the flow and run to the cooler . then when cooled down back to normal . https://www.summitracing.com/search/...9%2B4294882595 and yes to good temp range is 180* . i remember my old c3500 with 4l80-e would not lockup in 4th untill the engine coolant was atleast 140* warm . so even gm knows to cold is not good .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
driving is in my blood
Not sure what your specs equal size wise, but a long time ago I bought the biggest b&w tans cooler I could find, think it was like 22,000GVW rated or so. Had a 200-4R with a 2400 stall convertor in it. Ran fluid from trans to radiator to cooler back to trans. In stop and go traffic for 30min on a 115* day here in phoenix I finally got it up to a whooping 145* trans temp. That was the highest it ever got, way too cool for optimal trans operation and fluid life. So yes, you can go too big.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Yes this is way more than one for 22k gvw from what I've seen. It was going on a twin turbo v6 as an oil cooler. I think it's going back on the shelf and I'm just going to get a much smaller cooler. Will be easier to mount at least!
So can anyone post up some credible evidence that overcooling a transmission is a bad thing?
I've found some information that ATF at very low temperatures (below freezing) does not lubricate well. Although I don't think auto transmissions, compared to engines, have similar lubrication needs so it may not be important. Certainly overheated ATF looses it's ability to lubricate. I've seen many examples in my transmission career.
#10 | |
#11 | |
Thought I'd update in case this information may help someone else at some point.
I spoke with both the converter and trans builders. Circle-D said they recommend a cooler rated with a 40k GVW rating - very very large. Trans builder said the one I have is perfect and he'd recommend running that. He recommended either not using the radiator or plumbing the radiator before the external cooler then back to trans. So, 4l80e in a truck with a 3200 stall gets a very large trans cooler recommendation from these guys. |
Great info... Thanks!
Can you elaborate just a bit further? Did anybody speak of whether or not a fan was necessary for that large 40k cooler? -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
I missed that part. A 3200rpm stall means you'll always be slipping the convertor on side streets until it locks up, and slippage creates heat. On my 200-4R I had a lockup switch so I could lock it up in 3rd gear when I was going too slow for overdrive [was running a 3.07 rear gear with the combo]
#15 |
If installing in front of a radiator with some air movement a fan would not be needed . I run the 40k cooler they had suggested with good results .
#16 |
Pictures for anyone interested. Derale makes some nice brackets but I wanted to mount it right on the condenser so I had to make my own and used stainless hardware. Red tube nuts for "hot" fluid in and blue for cool fluid out.
Of course after I finished I saw several things that I could have done better. Maybe I'll remember that stuff next time! |
#17 |
You should always push hot into the lower fitting on ANY cooler install.
#18 | |
Fittings never down, always down, always up, always sideways, factory coolers have fittings down, inlet always on top, inlet always on bottom, cooler can be too big, can't be too big, cooler before radiator, after radiator, only cooler no radiator, and ... In this particular case the factory runs the hot line in to the top of the radiator and most sources I've seen suggest running the inlet at top when fittings are sideways. I haven't seen much of a good explanation for why it matters one way or the other but I did what I thought was best based on the information available to me. I'd guess that running to the top may put less stress on the pump and at the same time running to the bottom may keep the fluid in the cooler longer. Either way, I'll bet it will be fine and will run nice and cool. |
#19 | |
#20 | |
Explanation? I am not doubting your word but the top of the radiator is hotter than the lower. Why send hot fluid in the cooler section and take it out at the hotter section? What about horizontal coolers? Now, I know the OE's use hot transmission fluid to heat the radiator quicker to get into warm closed loop faster but that is an emission deal not transmission life consideration.
#21 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Flow chart for cooling system, and flow chart for added trans cooler. Hot usually enters the top and exits the bottom. The engines cooling system heats the transmission fluid. If the trans fluid is heating the engines coolant, you have a problem with the trans... https://www.crankshaftcoalition.com/...ing-system.jpg
https://www.google.com/url?sa=i&rct=...40551921549221
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#22 |
#23 | |
As for your theory about hotter/colder on the radiator, the trans cooler is in the cold tank so temperature should be consistent from top to bottom...theoretically...as no cooling takes place in the tank. Not sure where the info came from that the factory pushes into the top and out the bottom as my TH400 in my 87 most definitely pumped into the bottom and out the top. As for what you read on the internet...forget all that crap and go hang around any professional endurance racing team and see how they plumb stuff. I'm basing my statements on my 30+ years of IMSA, SCTA, SCORE and BITD racing experience.
#24 | |
Perhaps you can back up your statement with what the normal coolant temp is in the cold tank of the radiator vs trans fluid temp? HINT - the water in the cold tank of the radiator would need to be cooler than the trans fluid in order for the cooler to work. As there is a heat transfer between the trans fluid and the coolant, the result is lower trans fluid temp and raised water temp in your cold tank. Thermodynamics don't lie. That block/head flow is wrong for LT/LS based engines though...
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 Last edited by DieselSJ; 10-29-2018 at 03:25 PM. |
#25 | |
