Old 10-22-2018, 08:00 AM   #776
Re: What did you do to your truck today part IV
Originally Posted by jbgroby View Post
Cussed it, because I'm having issues with getting the headlights to work.
Mine tends to see some exaggerated language also.
Old 10-22-2018, 08:03 AM   #777
jbgroby
jbgroby's Avatar
The problem should be a simple one to fix, but darned if I can.
jbgroby is offline   Reply With Quote
Old 10-22-2018, 02:03 PM   #778
cwcarpenter98
cwcarpenter98's Avatar
For several months I didn't know why I only had brights and no dims, so I replaced the dimmer switch and was about to replace the headlight switch, until a looked under the hood and found that I had unplugged the harness at the core support then completely forgot to plug back in Funny thing is that that was over a year ago, and the dimmer switch I put in failed a couple of weeks ago. Put the original one back in and it still worked just fine
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-22-2018, 04:26 PM   #779
loudenzak
So I received a '65 c10 Stepside from my dad as a wedding present a couple months ago. Unfortunately it has been sitting since probably 1996 so there is a LOT of work that needs to be done. There also hasnt been a lot of aftermarket stuff done to it ie.. still 4 drums, no power steering. It does have a 305 in it (originally came with a 283) and he converted it to an automatic with a TH350 Trans when he was in highschool. I am currently in school for Auto Mechanics and my instructor has let me work on the truck through the classes we have taken. Right now we have just finished our brake class and although it was tempting to convert to disks, its just not in the cards for money right now. BUT! I have replaced everything from the master cylinder, brake lines (all, even made them myself instead of buying a pre-made kit), parking brake lines, hoses, shoes, drums, hardware, and brake cylinders. Now the nice thing is being in school we have a huge discount on parts and everything only cost me 282 bucks! (That receipt doesn't include the parking brake cables). Now we are onto electrical and there isn't much to do for me in this short 3 week class as we have to get it running first. Next is Suspension and I plan on replacing/rebuilding basically everything as we go through. I already have an associates in Auto body so the body will be my summer project next year.
loudenzak is offline   Reply With Quote
Old 10-22-2018, 05:49 PM   #780
jayoldschool
Moderator
Really cool truck and story. Get some white on those wheels and bumpers asap!
jayoldschool is offline   Reply With Quote
Old 10-22-2018, 08:00 PM   #781
Clyde65
Clyde65's Avatar
Welcome! You have an awesome dad imo! Your doing it just like we all preach here, safe, legal and driveable. Good luck!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-24-2018, 04:39 PM   #782
lowslow64
lowslow64's Avatar
New exhaust system today
lowslow64 is offline   Reply With Quote
Old 10-24-2018, 04:43 PM   #783
botoepfer
botoepfer's Avatar
I have been parting out and tearing down an 83 C10 so I can get the front cross member for my 63 motor out yesterday!
botoepfer is offline   Reply With Quote
Old 10-25-2018, 01:47 PM   #784
AngryPirate
AngryPirate's Avatar
Originally Posted by Aceslow View Post
Cut out the back of cab for big back window and made a template for the glass and inner panel
I'm about to do something similar to this; any tips?
Where did you make the cuts to remove the old and put the new?
Thanks!
AngryPirate is offline   Reply With Quote
Old 10-26-2018, 12:17 PM   #785
botoepfer
botoepfer's Avatar
Originally Posted by 69 C10 LWB View Post
Ive been looking for a set of manifolds for the small block in my truck and stumbled on these. Loosely installed them this morning to check fit. Couldnt do much because the yard at work is wet after the rain and I dont have room inside at the moment
I have those on the motor in my 55,, I love them, Hope you will too,, are you upgrading the brakes?
Old 10-27-2018, 01:05 AM   #786
tripleD
tripleD's Avatar
Worked Mator pulling trees and stumps from hurricane
triple d
tripleD is offline   Reply With Quote
Old 10-27-2018, 01:10 AM   #787
tripleD
tripleD's Avatar
Changed up wheel and tires ! Not real happy got one more set of tires and wheels I’ll keep y’all posted need ur opinions!
triple d
Old 10-28-2018, 12:14 AM   #788
66C10LB
The wider whitewalls look good with the painted rims.
66C10LB is offline   Reply With Quote
Old 10-28-2018, 08:18 AM   #789
The Rocknrod
Moderator
The Rocknrod's Avatar
Thanks!
Lots of threads on this here:
http://67-72chevytrucks.com/vboard/s...d.php?t=527836
FAQ section has this:
Big Back Window Conversion
big back glass conversion
Started my big back window conversion today : January 2014
Build Thread :'66 Longbed 327 w/AC project by cortcomp
At this point in his build thread, he starts posting photos related to a Big Back Window conversion.
Old 10-31-2018, 08:46 PM   #790
cwcarpenter98
Just put in an order for some new 3 point seat belts. It will be a nice safety upgrade to keep me from biting the dash, but hopefully I won't have to test out the effectiveness
Christian Carpenter
Old 10-31-2018, 10:51 PM   #791
Ratman74
Ratman74's Avatar
installed door panels and glovebox door
Dan "Ratman" Ratcliffe
Fourth generation Chevy truck guy, raising the fifth
1978 Scottsdale Big 10 "Bad Medicine" Daily Driver 28 yrs
1965 C10 Panel Truck "RWC" http://www.67-72chevytrucks.com/vboa...d.php?t=749003
Ratman74 is offline   Reply With Quote
Old 11-11-2018, 02:42 PM   #792
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Sold the service box off my 66 last week. The buyer hauled it off today.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-11-2018, 05:04 PM   #793
studeclunker
studeclunker's Avatar
Best of good fortune with your truck.
studeclunker is offline   Reply With Quote
Old 11-12-2018, 10:58 AM   #794
AngryPirate
Thanks RnR!
Old 11-12-2018, 03:43 PM   #795
Jdm63
Cab metal work finished, primed and ready for color. Picking paint color is somewhat stressful - and i’m not even ready to paint outside of truck yet 👀 just want to get firewall and underside done along with interior right now.
Jdm63 is offline   Reply With Quote
Old 11-14-2018, 04:39 PM   #796
pdxhall
pdxhall's Avatar
Got my inner fenders put on.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-14-2018, 08:12 PM   #797
Clyde65
Clyde65's Avatar
Spent $!
Since that rain finally stopped it’s to dang cold to work on the truck....
Clyde65
Rebuild of Clyde
support our troops!
Old 11-16-2018, 01:47 PM   #798
graymage
graymage's Avatar
Originally Posted by TJ's Chevy View Post
Got the trans installed and both inner fenders painted.
thats perfect, I just ordered a tko-600 and wasn't sure about shifter location, again you guys solved another problem
graymage is offline   Reply With Quote
Old 11-24-2018, 01:07 PM   #799
crewguy
17 years in the making. After many starts and stops, the Crewcab went for paint this week.
crewguy is offline   Reply With Quote
Old 11-24-2018, 02:50 PM   #800
Clyde65
Clyde65's Avatar
Holy crap! I love that thing! What color are you going with??
Clyde65
Rebuild of Clyde
support our troops!
