Old 10-31-2018, 08:04 PM   #1
feller
feller's Avatar
What's everyone running for gears?
I've got a 4.8/4l60 combo going into a c10 long bed, curious as to what everyone else is doing for gears, I plan to dd it, and I burn wood so it will probably haul some, but nothing too serious. I want an all around performer out of this truck my first thought was 3.73s, with probably a 29 to no more than a 31 inch tire. Thanks in advance for the help
feller is offline   Reply With Quote
Old 10-31-2018, 08:10 PM   #2
mongocanfly
mongocanfly's Avatar
Re: What's everyone running for gears?
3.73s should work good..I'm running 4.10s with 30"tire and od...I love the combo...
3.73s with a 30"tire at 65mph will turn around 1900rpm...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 10-31-2018, 08:48 PM   #3
feller
feller's Avatar
That's what I was thinking, but math isn't my best subject, also I know my Cummins had 373s and when I had 33s it was pretty good milage, but then I put 35s on and it was a lot worse. Of course that truck would pull anything you wanted and I had it up to 110 more than once, it was a mean truck for sure. Thanks.
Old 10-31-2018, 10:24 PM   #4
Macdaddy1
I am also runnung 3.73's
Macdaddy1 is offline   Reply With Quote
Old 10-31-2018, 10:34 PM   #5
mongocanfly
I cheated in math...haha...I use this rpm calc all the time to figure it out......down at the bottom of the page...
http://www.csgnetwork.com/multirpmcalc.html
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-31-2018, 11:43 PM   #6
feller
feller's Avatar
That calculator is awesome, 3.73+30 inch tire + .70 of, puts me at 1755 rpm, at 60 mph, that's right in the fuel mileage sweet spot. Thanks guys
Old 11-01-2018, 10:24 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
3:73 and 28"s on mine.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-01-2018, 01:52 PM   #8
sweetk30
sweetk30's Avatar
mines not on the road yet but 5.3/4l60-e/3.73/255/70/15=29.0 tire
60mph = 1800rpm
70mph = 2100rpm
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-01-2018, 03:15 PM   #9
OutlawDrifter
3.73 gears should be a good middle ground for economy/power. Don't be afraid to rev the little 4.8, the LS/LQ platform makes power higher in the curves than a standard SBC.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-01-2018, 09:00 PM   #10
Clyde65
Clyde65's Avatar
I have a 4.8/4l60e, 3.73:1 and 29” tires. The little 4.8 can burn the tires if I have the need. Sounds good and gets 20+mpg hey all day long.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-02-2018, 09:51 AM   #11
Rich84
Rich84's Avatar
60mph = 1800rpm
70mph = 2100rpm
I have this set up with a 4l80..65 mph is about 2150 rpm's.
Rich84 is offline   Reply With Quote
Old 11-02-2018, 06:19 PM   #12
72MARIO
72MARIO's Avatar
3:73 32" tire on my C20 6.0 4l80. Need 4:10 or 4:56 for the work it does. To low of rpm alway dropping into 3rd and 2nd climbing hills.
My suburban is 27" tire 3:42 pulls way better but still would like 3:73 or 4:10 in it. Need to target 2200 rpm at 62 mph for my liking.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-02-2018, 08:47 PM   #13
feller
feller's Avatar
Clyde 65, that's what I wanted to hear, thank you all for answering, with real world results
Old 11-04-2018, 05:29 PM   #14
crazy longhorn
Fabricate till you "puke"
I agree a 3.73, on a 29 tire....good mix! Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
