01-30-2012, 06:19 PM | #26 | |
But Found Her 25yrs Later!
Re: Proportioning valve
I just noticed that SCOTI has the Front Right and Left opposite of the pic I posted.
01-30-2012, 10:42 PM | #27 |
How my prop valve is tagged is how they were plumbed in the truck. The proportioning is equal between L & R; just F & R is different so the fronts are actually interchangeable.
03-27-2012, 12:29 AM | #28 |
Looking at Parts Stores, it looks like combination valves aren't necessarily vehicle specific?
http://www.summitracing.com/parts/CLP-PV-2/
11-02-2018, 02:18 PM | #29 |
I thought that you only need a propportioning valve, if you are useing disk brakes, my 64 C 30 panel has standerd brakes, please advise if i am wrong, Iwant to change to a duel master cylinder.
thanks |
11-02-2018, 02:57 PM | #30 |
You are correct.
If you have four drums then you only need a "distribution block" and to tie into the rear system. The proportioning will take place via the wheel cylinder sizes. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-22-2019, 01:08 PM | #31 |
chevy truck fan
This is nice information guys. I am in the process of "re-doing" a 1986 2wd (in the build section) and I am wondering as to why the proportioning valve is located on the brace in front of the motor? I would like to know if the valve can be relocated somewhere else?? I was thinking of replacing my booster and master with a later (mid '90's version) and placing the prop. valve next to the master with the lines relocated correctly. what do you guys think??
thanks!! |
10-22-2019, 02:54 PM | #32 | ||
(lol) K
10-22-2019, 03:53 PM | #33 |
chevy truck fan
Keith,
i was hoping that you might return a chime in... !! I figured that it could be relocated, I had done the same on my '72. When I saw the location of it I was like.... ?? it seems like that is a weird spot? especially if it needs to be serviced or replaced. Now I just need to see how I will run my lines to the new location... Hmmmmm? thanks for the reply... I feel honored to have a response from you... very similar to getting a response from ken (N2TRUX)... !! |
11-26-2022, 09:32 PM | #34 |
Reviving this thread and hoping to find an answer.
I just converted my 77 to hydro boost, with a new master cylinder and adjustable proportioning valve, which is mounted just beside the master cylinder. My question is - can I just remove the old proportioning valve and tee the front lines together, and coupling the rears together since I'm using a new proportioning valve now? Or am I supposed to leave the old valve in place anyway? Last edited by Dleslie212; 11-26-2022 at 09:50 PM. |
11-30-2022, 09:36 PM | #35 | |
Proud Vet that loves the USA
Bubba |
11-30-2022, 09:46 PM | #36 |
12-01-2022, 10:21 AM | #37 | |
Bubba |
