Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-05-2018, 09:01 AM   #1
Chaddyp59
Chaddyp59's Avatar
What Headlight Switch??
I have 1959 Apache Fleetside that I am upgrading to H4 Bulbs with the Relay harness mod.
What light switch do you guys recommend. This is what the truck has in it now and it's a POS..
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Any advice would be much appreciated.
thanks.
Chaddyp59 is offline   Reply With Quote
Old 11-05-2018, 09:55 AM   #2
Chaddyp59
Chaddyp59's Avatar
Re: What Headlight Switch??
I should have said that the truck has been rewired with a EZ wire 21 standard wiring harness.
Old 11-05-2018, 09:13 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What Headlight Switch??
As long as the lights have the fuses and relays ran and the whole system is wired correctly then that switch will do the job. I would have thought though it would have a factory wiring harness though.I have used the same switch on many golf carts and never had any problems with them.If your using the relays and the switch is just a on/off for the relay your fine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
