11-06-2018, 11:40 PM | #1 |
What’s the most practical way to swap engines?
Ok so I finally found a project truck. 56 GMC stepside. Body is really good considering the age. Floors are unbelievably solid. Cab corners are shot but fixable. Front fenders need some love or just replaced. Interior is wasted but that’s just cosmetic stuff that can wait. For me the first order of business would be a drivetrain and brakes.
I was thinking about a 350 w/700r4 trans. What’s the most practical way to go about it? Is there a certain year of engine/trans I should be looking for? Best mounts and/or crossmember to use? I do not want to change the front suspension. I will eventually put disk brakes on the front. Was thinking PS/PB as well eventually. Other than that i don’t plan on veering too far from stock. Thanks in advance |
11-07-2018, 12:18 AM | #2 |
Re: What’s the most practical way to swap engines?
What engine is currently in the GMC? Ether way your doing a big swap going to auto and power steering.
Are you on a budget? I like to think we all are, if your wanting to go cheap you could buy a doner vehicle and swap all the engine and trans stuff. That could be an LS car or and older TBI or carbed vehical. If wanting all new, I would get with a supplier like CPP and get all the conversion items needed. Power steering box and pump, disk brakes, crossmember. Look at some of the build threads and get some ideas. What rear end is in the truck? The stock gears if 3.90 or 4.11 should be OK with an OD trans but if 3.38 it may be a little doggish. Hope this helps. I used a 93 GMC parts truck and swapped the tbi engine and transmission stuff into my 59. Nothing was bolt in as much as I would have liked it to be. |
11-07-2018, 01:42 AM | #3 |
I went with EPAS electric power steering, clean and simple.
11-07-2018, 07:27 AM | #4 | |
Thank you |
11-07-2018, 07:48 AM | #5 |
I will definitely look into this. I wondered if it was possible to utilize the power steering pump that came in whatever engine I put in it or if that would just be opening up a huge and possibly unnecessary project. I’m pretty much a newb when it comes to this. I’m sure I have bit off more than I can chew but I’m in no hurry.
Thank you for this idea |
11-07-2018, 11:23 AM | #6 |
I started with similar notions about keeping it stock-ish in the front suspension.
My experience is that by the time you add disc brakes, power steering, new bushings, new steering joints, etc you have spent darn near what an IFS might have cost you. I've got new shackles, rear spring bushings, new king pins, new tie rod, C10 power steering (avoid like plague), disc brakes, tapered roller bearings, 4* caster wedges and probably some other junk into my I-beam front end. It handles and steers like a boat, parks like a garbage truck and buzzes like a summ***** going down the freeway. With a Chevy 350 & 7004R you will have the power and gearing to go a lot faster than your front end will really keep up with. It still needs a ton of work to be "right" - partially because the C10 steering kit is such an engineering junk-show to begin with, partly because you are still gilding and spending money on 1957's worn-out parts that were designed well before interstate travel was hitting 80 mph. Possible caveat there is that if you have really tight kingpin and spindle bores or go with a new drop axle, your junk will probably not buzz like mine does.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
11-07-2018, 12:38 PM | #7 |
do you mean cheapest or literally the most practical? I dont want to assume one or the other but a lot of people use "practical" when they mean "cheapest"
the most practical way would be to buy a complete donor like mikebte suggests and take out every single part you need to swap over. I have a theory that a wiring harness/drivetrain doesnt inherently KNOW what chassis it is installed in, it just looks for certain inputs, and if you can make sure it has those inputs you will have a working system even with it laying on the ground. in aerospace they call it an "iron bird". then look at what you cant reuse but need to. for example your donor may be a column shift auto but you cant add that to your stock column. your donor may be EFI but needs the harness pared down and a different gas tank with the same pump. lines may not switch over. the easy part is mounting, buy or more likely build the mounts.
11-07-2018, 01:03 PM | #8 | |
Thank you |
11-07-2018, 01:14 PM | #9 | |
By practical I mean what makes the most sense. What’s going to be the easiest. I’m in no hurry to have my finished project. This is just something to put my head into and take it off of the normal issues with life. I guess I would call it a hobby. Thank you Jason |
11-07-2018, 01:36 PM | #10 |
its pretty simple these days to use a modernish (98-2010) donor and just buy a stand alone harness, you will need someone to flash the pcm for standalone but literally 8 wires to hook up. getting the right fuel system is the next hurdle, usuing the donor pump is the best way if you can pull it off. then cooling system, then gauges.
11-07-2018, 02:53 PM | #11 |
for x-members the most practical way i have found is to fabricate your own
most inexpensive x-members are universal fit and need to be cut, fit and welded why cut, fit and weld someone else's metal? power steering is a slippery slope. you'll need a new column as the old column is integrated into the steering box if you decide to go ifs all your work/money comes out into the junk pile yossarian has some good info in his post, reread his reply ten times
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-07-2018, 03:30 PM | #12 | |
Posted via Mobile Device |
11-07-2018, 04:40 PM | #13 | |
As for newer engines, the electronics are not bad. Many of them will last a long time and you get the ease of fuel injected start ups and an electronic shift transmission. If you get a truck as a doner, the cross member may only need shortened and bolted in, the engine mount will be the biggest custom part you have and that is very easy. You can also use this kit, easy enough. https://www.summitracing.com/parts/c...etxk/overview/ Also check out other builds. I have taken so many ideas from the folks on here that its crazy. I found that OrrieG used a foot brake pedal out of a 70-80s blazer in his truck. So i adapted the same idea and it was super easy. Mainly, its your build. Have fun and keep it unique. |
11-07-2018, 06:45 PM | #14 | |
I have been poking around this forum for awhile trying to decide the best course of action. Trying to decide which way I want to go. I’m still not sure. I know EFI is nice, not sold on it. Kinda like the old school carb. Is figuring out the wiring going to be more difficult using a newer donor compared to an older one? I’ve never done auto wiring. I rewired my whole house tho 😁. Yes I know that it’s completely different lol. I was hoping I could just buy a new harness and plug everything in, ripping out the old as I go. Nothing is that easy. If I was keeping the original motor that would be more if a possibility I’m guessing |
11-07-2018, 09:50 PM | #15 |
I like using all the EFI and harness too, but it can get kind of crowded under hood.
IMG_2168 by Joe Doh, on Flickr
11-08-2018, 02:14 AM | #16 | |
11-08-2018, 07:42 AM | #17 | ||||
Hmmm... considering IFS because it's better? LMK when you start the IFS swap in your Jeep. Last edited by 1project2many; 11-08-2018 at 07:50 AM. |
11-08-2018, 09:33 AM | #18 | |
I love the look and nostalgia of these old trucks which is why i dont want to have to veer real far from stock. i know I will have to in some degree and might decide to as the years go on but for now ill change only what is necessary. will it ride rough? probably more so than my grand cherokee but thats what i want. If i could have found a survivor that had drivetrain in it than that would have been awesome. Instead i looked for the best cab and frame i could find and went with that. Got pretty lucky in that department. a couple cab corners to weld in and thats it. thank you for your response |
11-08-2018, 09:44 AM | #19 |
tell me if this is way off base pls. find a donor from 87 to 92 that has the 350/700r4 that im looking for and use as much of the donors wiring harness that i can. I can find a crossmember that conforms to this frame and matches up to the 700r4. Ive found engine mounts that do the same as well. Im new to this extensive automotive work so ple tell me if im heading into a complete nightmare that isnt likely to work.
My Dad has rebuilt a few cars in his day and has every tool one could want except a lift. He will be a big help i have no doubt but he is also a mopar/jeep guy(as i have always been, but this series of truck is too sexy to pass up lol). I already got the raised eyebrow when i told him about it. any and all comments and info is appreciated. Im just trying to learn and not make too many costly mistakes. This is going to be my pasttime for the next few years so in getting it road worthy anyway. thank you again to everyone who has commented on this thread |
11-08-2018, 10:18 AM | #20 | |
If you run into any issues on wiring, you know were to find all of us. |
11-09-2018, 03:29 AM | #21 |
I've always been a fan of buying a running driving donor for a project as long as it has the correct engine and trans you want for your project. That might be reasonably easy where you live as you can hunt down the good running V8 "winter rig" They may not be as cheap now as they would be in the spring though. That good running mid 80's two wheel drive pickup or maybe ex cop car caprice that runs great but is all rusted out might be a good cheap donor that you can sort out the engine and trans before you pull them.
11-09-2018, 09:51 AM | #22 | |
Thank yoy Posted via Mobile Device |
12-05-2018, 01:12 PM | #23 |
You say you are going to do a lot of around town driving and no high speed driving and nothing over 55mph. Don't mess with a 700r4, just put in a turbo hydro 350 tested tried and true. The 700r4 is for computer engines that run slow, about 1500rpm. A carburetor engine needs to run above 2000 rpm to work well. Most people don't know this because carburetors were phased out in 88. A Q jet 350 and a turbo 350 are the perfect combination for occasional use and slow speeds around town. No wiring headaches, you can fix anything on it, and it is going to sit most of the time so why make thing complicated?
12-05-2018, 04:15 PM | #24 |
yep, if you want easy and quick buy a GOOD runner, not something that "just needs a tune up" or do the tune up while it is in the runner still. then take it all apart and slip it into your truck. these trucks came with a small block so you should be able to find mounts easy enough. the issue may come with the ifs swap because the original engine mounts are front mounts. you will also need to fit up a trans cross member but keep in mind that the original tranny cross also supports the cab and front spring rear mount areas for stiffness. you may wanna look at keeping some support there.
check out a few threads here, lots of those style of swaps. |
12-05-2018, 06:39 PM | #25 |
Hey I'm in your shoes and learning and this is what I'm told so far and trying for myself. my mechanic calls it my practical poor man plan
1988 to 1991chevy or gmc 2wd truck is what to look for if you want less wiring and flashing computer stuff. Once you get to 1992 you have the electronic tranny. has the tbi engine for fuel injection and the 700r4 then you supposedly can use lots of other stuff like suggested above out of the donor vehicle. but I liked his idea cause I can buy the truck and drive it and make sure everything works before putting in my truck. since you won't be drivin it a ton you buy one with around 100k and supposedly you will have an engine for the rest of your life haha. plus I'm not a person who can keep my carb tuned up and the fuel nowadays seems to make it harder he claimed. there's a guy on Facebook Seth doulton in a Chevy/gmc forum I think that does really reasonable priced custom wiring kits I hear good things about. but there's tons of wiring companies just have to decide how much youb want to spend he's like $250 I think so much cheaper than alot i found. it's an adventure. I originally planned to do like you and just upgrade my stock frobt with disk brakes and such but have since decided on a mustang ii after listening to these helpful gu ys on here. the cost and the benefits of what you gain are worth it to me since I'll be driving in town and need good handling and brakes and the cost of adding disk and powersteering was getting close so I'm saving for the better handling bonus as well haha good luck and welcome. this forum is amazing and I have learned a little and have much to go. enjoy your build |
