New lift kit
I put a Skyjacker lift kit on a 71 Jimmy frame and the e brake cables seem to be a little tight. It supposed to be a 2.5 lift in the rear. When I put the tub back on how much will the frame move with the weight. Do I need to get new cables and if so where to get them. Thanks
![]() Join Date: Apr 2006
Re: New lift kit
Got it installed hu. You should see what the 3” did to mine. Huge difference from the old saggy stock springs.
Inline tube used to make them. I heard they don’t anymore, so I wonder if there is anyone else.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
Re: New lift kit
So what did you do for cables
Re: New lift kit
Inline Tube referenced around the forum quite often..
may be able to search for some threads referencing your application.. Inline Tube / Parking Brake Cables or give them a call to see what they offer.. good luck!
I started out with nothing - and I still have most of it |
#5 | |
![]() Join Date: May 2015
Re: New lift kit
![]() Join Date: Mar 2009
Re: New lift kit
Agreed. I did the 2 1/2 inch all spring lift on my 70 blazer and they were fine.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
Re: New lift kit
I have 4" National Springs on the back of my Jimmy and the stock length cables have always been fine.
My kids Jimmy project is tub-off-the-frame in the driveway right now and the driveshaft and shocks are both WAY too short. I'm thinking it's going to move quite a bit with the tub back on based on my previous experience with my own truck on how everything fits with that same combo.
Re: New lift kit
I was going to use the stock cables so I don’t know yet.
