12-04-2018, 04:51 PM | #1 |
70+ ( Old Skool Club )
My Pet Peeve.. Short Rant
Saw this truck on EBay this morning and looking over this morning and thought wow a decent driver Cheyenne Super that is pretty original.. Scrolling the multiple pics I come to the under hood shot and horror as usual all the A/C stuff is gone. Why do people do that ????
https://www.ebay.com/itm/1972-Chevro...53.m1438.l2649
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-04-2018, 04:58 PM | #2 |
Re: My Pet Peeve.. Short Rant
Wow nice clean truck, yes your right. why? I mean it wouldn't take much more to go a little further and put the A/C stuff back right...
Things happen for a reason! |
12-04-2018, 05:14 PM | #3 |
Well, it looks like has a non-stock (replaced) motor...fair enough.
So if a shop was doing the work for the owner they might have said that it is just as easy to remove the non-working A/C stuff, while replacing the motor... and leave it off than the extra cost of hooking it back up and charging, etc. The owner probably got it all back in a box...and that was the end of it. As well tho', why would they go change the interior from a nice parchment to what appears to be re-dyed black, at least on the door panels, etc. I like those original parchment interiors and I think they work well with the Ochre color....just my thoughts. ...nice example tho'...and still a good price so far for sure. All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
12-04-2018, 05:17 PM | #4 |
Moderator
“AC works, just needs a recharge....and a compressor, condenser, expansion valve, hoses,....”
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-04-2018, 08:04 PM | #5 |
Because it's easier and cheaper to do a hack job than a real repair. Add the fact that most amateurs have no understanding how a/c works and what it takes to repair it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
12-04-2018, 11:27 PM | #6 |
Who Changed This?
When I worked as a mechanic, I could pull the AC out of the way for engine R&R without even discharging the system. I guess a lot of guys don't care about not costing the customer extra money, or maybe they just don't know any better. It doesn't even require knowing how to fix it to move it out of the way for the other work!
Back in the '70s I was asked to go and troubleshoot a brake problem in the field. The "mechanic" was replacing a steel brake line using vacuum line with clamps, and couldn't figure out why the hose blew off when he stepped on the brake pedal. I kid you not.
12-04-2018, 11:41 PM | #7 |
When I was younger, I never cared about a/c. Then I moved to China Lake.
12-05-2018, 12:50 AM | #8 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-05-2018, 02:13 AM | #9 |
Bingo! Adding to that is the fact that if you repair it correctly at shop price, it could run over a grand easy. I converted my 69 to a big block and the AC to R4 with a short water pump. I'll post up some pics when I finish it and get it charged up
12-05-2018, 10:42 AM | #10 |
cause its a truck...its job was to go from point a to point b with a load of stuff in the bed...when the a/c broke you rolled down the windows cause you couldnt afford to fix it....and the minute you did anything to the engine that required removing the compressor you left it off so the truck would be easier to fix in the future...that system could have been removed 40 yrs ago
1970 short step c10 leaf spring 454 Last edited by volksworld; 12-05-2018 at 10:48 AM. |
12-05-2018, 10:54 AM | #11 |
Its also entirely possible that it was removed in 1982 when the price of fuel had jumped and the A/C had died and the owner decided he could save some gas by removing it.
I tore the A/C out of my 68 396 SS Chevelle in about 1984. It didn't work and was in the way just about every time I was under the hood. I was happy to lose 50 pounds of dead weight. Not saying I would do that today.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-05-2018, 11:14 AM | #12 |
Because people believe that a cleaned up engine compartment with the non-working AC removed will fetch more than a AC truck sold as incomplete or non-working.
So far as I'm concerned, that makes them a heater truck with the wrong interior and HVAC box! Plus, fixing AC is hard and removing it is easy.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-05-2018, 11:15 AM | #13 | |
Non-working AC is strictly a used car phenomenon.
12-06-2018, 10:29 AM | #14 |
I know why I remove them. Ugly as heck. Being in New England it's not really needed. Got a 69 Camaro....yup pulled it out too. Still have it and could go back on any time. Got a 79 K10 Silverado....yup pulled it out too. Know how hard it is to find a cab from out west that doesn't have AC!! Took a while but I found one. I like the clean look and to me AC is the best way to ugly up an engine compartment. I want a truck. Not a truck that has car options. This place would shred me for I did to my 79. It is a Silverado but I basically made it what I want and that's prolly equal to a Custom Deluxe now. I just wish I could buy a new truck without any of the crap they have in them now. Ok my rant over. Lol.
12-06-2018, 11:37 AM | #15 |
I pulled my A/C out.....and replaced it with a Vintage air unit! Cleaned up the firewall and a smaller compressor on the engine looks cleaner.
12-06-2018, 11:53 AM | #16 |
Given the location, they probably didn't care about the expense of making the A/C work.
Unfortunately, the firewall between A/C and non A/C are a bit different, so you can't just pull the big A/C box and put on a factory heat box to make it "look" better.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-06-2018, 12:09 PM | #17 |
Nothing wrong with pulling a compressor and lines on a truck you bought with it not working in. It's never a first concern and it's in the way. I always do that, plug the fittings, store the parts removed. But why it's gone is because there was a point in the middle of a truck's life it was just an old truck that still ran and most people don't know how to deal with a/c... even those who are mechanical and do about anything else on their vehicles. Many can do everything but repair hvac, carbs, and automatic transmissions. Why it's missing is because that's what most Americans do. Throw stuff out, don't see the value till it's hard to find.
This doesn't stop me from buying a truck. It just means here we go again, start searching for the parts
12-06-2018, 01:20 PM | #18 |
One of my friends has his grandmas "original owner" 69 chevelle malibu with 350/350. At one time in the 80s, he and his friend put a performer intake, carb and headers on it and **** canned the AC stuff. however, luckilly, it was all put in a plastic bin and kept in the garage...
But why? We are going to get the AC going with one of those sander compressor/condenser/electronic poa valve conversion kits.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
12-06-2018, 05:27 PM | #19 |
Thanks for all the replies. You all have valid comments and yes over 47 yearsa truck would go through multiole stages. I guess my thoughts are if it stopped working remove the belt and leave it intact so someday if you want to repair it everything is there. Just an old guys rant.
12-14-2018, 11:51 AM | #20 |
My AC doesn't work presently; but I still run the belt to keep the tension on the water pump even from both sides of the engine. (Big Block)
12-14-2018, 12:32 PM | #21 |
I do a lot of shopping for vintage automobiles and it seems more often than not the A/C has been removed. If it's still there, it's usually not working. As a general rule, since I'm in Texas, I factor an additional $2K to any vehicle purchase for Vintage Air.
12-14-2018, 09:33 PM | #22 |
Cluster King
I have never in my life seen such a failed experiment as to how the engineers plumbed AC onto one of these trucks. It looks like when they were in development stage (something I know a lot about) they just could not get it packaged right and just threw it were it landed and called it AC.
And that is why most of mine got canned. I just could not stand to look at that mess of crap under the hood. Now the only reason I would have one on a 67-72 is if it was there when I bought it and functional. Let the stone throwing begin!!!
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
