Active Member
![]() Join Date: Jun 2017
stock cooling fan
does anyone run the stock cooling fan on a 5.3 swap? if so does the small block fan shroud work with it?.
thanks Bryan |
Re: stock cooling fan
I usually run the stock fan. Fits the fan shroud and never had any cooling problems, even with the A/C on.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Active Member
Thanks I was hoping I could use a stock shroud. I was worried that the fan was a little too low.Is yours from a 6cyl or a small block? I have a champion aluminum rad but I think a shroud will work
thanks Bryan |
![]() Join Date: Jun 2015
Used the factory Fan from the 5.3 with the 1985 SBC fan shroud. Mine fit perfectly but it might depend on the mounting plates you use. I lucked out and got a no-name set off eBay that worked but do not remember the vendor.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
I used the 6.0 clutch fan in my 1968 suburban
I would replace the thermostat clutch as I did have mine go bad. It wouldnt engage and pull air.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Active Member
Thanks for the info. glad to know it should work. i have the wires for the electric fans but i would just rather go this way if it works
thanks Bryan |
