Need some help picking tire sizes for a 4/6 drop
I'm thinking about buying some wheels and tires for my build today for my 87' C10. Going with Torq Thrust II's. Pretty sure I am going to go with 20's (wanted 18's but tire sizes for that wheel are really limited). On the Front I was thinking either: 1) 245/45/20, or 2) 255/45/20s (20x8 wheel). The rears I want to use 295/40/20s (20x10 wheel).
I'm pretty certain the rears will work with no issues. After reading a lot here I am somewhat concerned about the fronts. I'd like to retain the stock inner fenders with my build and my concern is about rubbing issues. Drop up front is a western chassis 2.5" drop spindle and one coil cut off the springs - would estimate this at about a 4.5" drop. The 245/45/20 wheels spec out to around 28.7" tall the 255/45/20 wheels are about 29.1" tall I would much prefer to go with the 255/45/20 wheels up front, but again - not sure this will even work. The backspacing for the front wheels will be 4.50 in. Any input is appreciated - the web is running some sales on tires today so was hoping to wrap this up. If anyone has a suggestion of a different front size please let me know. Last edited by Mattchu60; 11-26-2018 at 10:54 AM. |
#2 | |
Re: Need some help picking tire sizes for a 4/6 drop
Based on my limited experience, it looks like that'd fit - my truck had 265/75/15's (basically 31x10.5) on 15x8 rallys (4" backspacing I believe...) on it, with 2.5" drop springs and sagging stock 6cyl springs up front (with a 350 installed.) I had no rubbing at all even when I bottomed out the front suspension over dips in the road or doing hard off camber full lock turns into a steep driveway. I'm in the same boat as you, but trying to run a 17x9 with a 255/60/17 up front on a 4.5-5" lowered truck, and haven't figured out what backspacing I need or if I should go with a 17x8 wheel instead. |
#3 | |
The Peacemaker
The 245/45/20's should work fine. Mine was lower in the front and I ran a 245/45/18 which granted is a 26.7" but I was also at a full 6" drop in the front. Rear was the 295/40/20 which fits perfect with the 5.5 BS.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
Well I ended up going a completely different direction. Ended up ordering some 18" wheels and 235/60/18 for the fronts on a 18x8, and a 265/60/18 on the rear on 18x9 wheels. I like the look of the 20s but I wanted some more sidewall as I plan to drive the heck out of this thing and our Iowa roads are not the smoothest.
Please post some pictures..I'm leaning towards 18's as well. Connecticut roads are pretty rough too. I am currently running 29.1" tall tires now.
#6 | |
This is my '81 . "4/6" drop - flipped rear and belltech 3" drop spindles with one coil cut on stock springs.
The 18" wheels and 255/55R18 tires came with the truck, Don't look too bad but the front does rub quite a bit. It hit the part of the inner fender where its lowest and bolts to the outer fender. I think these tires are about 29" tall.
81 short step. |
#8 | |
The wheels are 18x8.5 with "0" offset. About 4.75" backspacing. I didn't see how I could easily make more clearance due to the lip where the inner fender meets the outer, So I actually have some 255/45R18 tires (about 27" tall) I am going to swap on.
Theres not a lot of choice for "truck" size tires in the 18" wheel size, as you may have found, But Hankook has some sizes.
81 short step. |
#10 | |
I'm also running 1.5" spacers on the rear which really made a diff in looks.
81 short step. |
I'll be running 17x9s with 4.25" back spacing and figured I'd have to use spacers to adjust to get the look I'm going for
![]() Join Date: Oct 2014
Ridler 645 in Chrome 18x8 up front & 18x9.5 in the rear.
Tires are Pirelli's 265/65/18 all around. PO had 20's on there, but I really like the 18's much better. I noticed that it rides much smoother than the 20's.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#15 | |
It looks like you're around a 2/4 drop? Do the fronts rub at all? What is the offset or backspacing on the rims? Great looking truck! |
#16 |
Proud Vet that loves the USA
![]() Join Date: Jun 2016
Rocket "Attack" Wheels
Front 18x9 4.5 inches bs-275/35/18 Rear 18x10 5 inches bs-275/35/18 |
#17 | |
Here is a before pic of the 20" wheels. I really did not like these wheels or how it rode. Every little bump in the road was felt. Big bump felt like the truck was coming apart. 20x8 with 255/45/20 20x10 with 285/50/20
#18 |
heres a couple of 18" equipped squares that I found on here. 295/45/18 on rear and 245/45/18 on front of white one and 255/45/18 on front of blue one. hope pics post!
#19 |
That white one is perfect. I have 15s and want a bigger wheel but not loose on side wall. 295/45/18 is what I want to run in the rear with 245/55/18 on the front . I like a leveled truck and nice side walls.
