12-10-2018, 04:31 PM | #1 |
Replacing mid shaft bearing on driveshaft...need a little help
Hello All,
I am replacing the mid shaft bearing on my 1966 Chevy, the driveshaft is two pieces, there is a bolt that seems to be holding the 2 pieces together in the center (splined). Is this bolt a right handed thread? It's awful tight. Or is it a left handed thread? Thanks |
12-11-2018, 04:50 AM | #2 |
Re: Replacing mid shaft bearing on driveshaft...need a little help
From what i remember its rt hand but my rememberer doesn't work to well anymore
12-11-2018, 12:53 PM | #3 |
It is right hand threads but it usually is tight & a hard place to get to. I have a ground down wrench I have used on them. Sometimes you have to disassemble the U-joint to get to it.
12-11-2018, 03:32 PM | #4 |
I did mine last year, and as far as I can remember it is just a normal bolt. I believe I stuck the shaft in a vice and zipped the bolt out with a deep socket on an impact wrench.
12-11-2018, 03:47 PM | #5 | |
4x4k30 if trouble was money i would have plenty |
12-11-2018, 07:19 PM | #6 |
Moderator
12-11-2018, 08:25 PM | #7 |
Thank you all for the info...
I took the advice of another member and brought the driveshaft to a local shop that specializes in driveshaft repairs. They have the presses and experience to make it a quick turnaround. Plus I still get to keep the skin on my knuckles and the cursing to a minimum. |
12-11-2018, 10:56 PM | #8 |
Junior Member
Here are some pics of my drive shaft project. Have everything pulled apart, and now waiting for parts, beadblast, paint, and then reassembly.
12-12-2018, 12:52 AM | #9 |
60-66 Nut
Depending on the intended use of your truck, you might consider upgrading to the HD driveshaft and carrier bearing instead of keeping the light duty version. Those particular driveshafts and carrier bearing are why so many people hate 2 piece driveshafts.
12-12-2018, 08:33 AM | #10 |
Junior Member
Captainfab, do you have a link or part numbers for the HD drive shaft and carrier bearing? Thanks
12-12-2018, 10:50 AM | #11 |
Moderator
Good pics, f66! Sure looks familiar. I didn't have that nice sharp jaw puller you have, would have saved me the torch and press work. Luckily I do have both at the school shop.
Definitely use a local truck driveline shop if you don't have the specialty tools needed to get the bearing off. Those guys are always great, and their prices usually are, too. Doing little stuff like this is a gravy job for them. |
12-13-2018, 12:13 AM | #12 |
60-66 Nut
No I do not have any part numbers. The best I can do is a couple pics that I have in my for sale thread for my HD carrier bearing mount.
http://67-72chevytrucks.com/vboard/s...d.php?t=620312 I believe the HD setup should be standard in a V8 4 speed truck. Personally I would never run that light duty driveshaft and carrier bearing in any of my trucks.
12-13-2018, 04:18 PM | #13 | |
Junior Member
