Will this tire fit??
I will soon be installing the drop kit/disc brake kit from ECE 9036770/ 9026570 on my 67 c10
I am wondering if the tires I have now, P275/60 R 15, 6 lug, will fit. I know there are some issues with tires fitting on the front end With disk brake kit/ drop spindles. At some point I will convert to five lug but hoping for now I can work with these tires/ wheels! |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Will this tire fit??
You'll probably have rubbing issues in turns and bumps once the drop spindles are installed. The 8" wide rally's should clear the spindles, mine did but mine is a 72...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
What size tires and wheels do you have and is the 72 different than the 67 on this issue? I’m not exactly sure what size wheels I actually have either
Tire size and style is personal to some extent, and practical to another. IMO, the 8" wide rally wheel is too wide for the front, and a 265 is too wide as well. I think a 235 width tire on the 7" rim perfect for the front and a 275 on the 8" rim in the rear. You are stuck with the wheels for now, so think about a 235 70 on the front and a 255 70 on the rear. That is a nice combo for a dropped truck I think.
