Old 12-12-2018, 06:59 PM   #1
Andyking1203
5 lug or 6 lug
So I'm in the process of doing a frame off on a 68 c10 swb, the suspension was originally a 6 lug setup. Everything is gonna be replaced, whether I go 5 or stay with 6, (except rear axles). My question is, what would be the better deal 5 or 6 lug? The truck is gonna be lowered and have a 600hp sbc in it, main use is gonna be driven with a little drag racing mixed in. Thanks
Andyking1203 is offline   Reply With Quote
Old 12-12-2018, 07:46 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 5 lug or 6 lug
Youll have alot more wheel choices with 5 lug...lots of drag cars running 5 lug
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-12-2018, 07:48 PM   #3
sweetk30
sweetk30's Avatar
Re: 5 lug or 6 lug
x2 on 5 lug wheel options .
but find the wheel you like first as some models i think look better in 6 lug for the placement of the rim design and lug holes. i have seen a few over the years were this would have been a great option for a fine detail .
and if going late model rim take off stuff there 6 lug also .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-12-2018, 07:52 PM   #4
Andyking1203
Re: 5 lug or 6 lug
Was thinking almost like a classic crater style wheel, but in either 16 or 17"
Old 12-13-2018, 02:16 PM   #5
GIZZ
GIZZ's Avatar
Re: 5 lug or 6 lug
I would not get 16's, the tire selection is limited unless you're doing a 4x4. I think it's even worse than if you had 15's. 17's is the way to go, maybe even larger.
GIZZmotorsports on YouTube & my panel truck build
'69 c10 panel, '75 c35 flatdeck car hauler
GIZZ is offline   Reply With Quote
Old 12-13-2018, 05:16 PM   #6
Andyking1203
Re: 5 lug or 6 lug
5 lug seems to be the answer... I like a lot of the rims I have seen in 5 lug better then 6
Old 12-13-2018, 10:33 PM   #7
Mike C
Mike C's Avatar
Re: 5 lug or 6 lug
Add another vote for 5 lug. There are some 6 lug rims out there but most have a pilot hole that is too small to fit on the older trucks.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-14-2018, 10:09 AM   #8
DjS71
Re: 5 lug or 6 lug
5x5 (OE truck) will have a lot of wheel choices compared to the 6 luggers.
5x4.75 (OE car) will have even more.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 12-16-2018, 08:00 PM   #9
Mike C
Mike C's Avatar
Re: 5 lug or 6 lug
I read your post again and "everything will be replaced but the axles". Not sure what that means, but if you are REALLY making 600hp, 35 spline (33 at minimum) axles should be on your shopping list regardless of how many lugs you go with.
But again, 6 lug drastically limits your wheel choice.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-16-2018, 08:06 PM   #10
Andyking1203
Re: 5 lug or 6 lug
If I stay 6 lug, I'd keep my stock axles. But everything else will be new. And the motor on the dyno read 650.. so I'm guessing around 575ish to the wheels
Old 12-22-2018, 09:36 PM   #11
Mike C
Mike C's Avatar
Re: 5 lug or 6 lug
A truck 12 bolt stock is borderline strong enough at 400 WHP IMO. Look into a 6 lug semi-float 14 bolt if you want to stay 6 lug. They have 33 spline axles and a 9.5" ring gear. Significantly stronger than a truck 12 bolt.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-22-2018, 10:21 PM   #12
sweetk30
sweetk30's Avatar
Re: 5 lug or 6 lug
and if you want 5 lug get axles for the 454 spec truck .
also there is 2 width of 9.5" semi float 14 bolt . 2wd and 4wd .
Old 12-23-2018, 01:16 AM   #13
Andyking1203
Re: 5 lug or 6 lug
I have actually decided to go with a the no limit rear fat bar 4 link and a 9" I believe. And also gonna do the no limit wide front end. Which will convert the truck to 5 lug.. thanks for the ideas guys
