Old 07-10-2018, 11:08 PM   #51
Oldironracing
Oldironracing's Avatar
Re: GM connect and cruise engine package
One more
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 07-10-2018, 11:10 PM   #52
Oldironracing
Some more that got done.
OLDIRONRACING
Old 07-10-2018, 11:11 PM   #53
Oldironracing
Some more pic
OLDIRONRACING
Old 07-10-2018, 11:12 PM   #54
Oldironracing
Can't post but one pic at a time ?
OLDIRONRACING
Old 07-10-2018, 11:14 PM   #55
Oldironracing
Made my on pedal bracket using the factory holes.
OLDIRONRACING
Old 07-12-2018, 11:28 PM   #56
Oldironracing
My motor sets to high in the front. I have the CPP motor stands with dirty dingo sliders. I'm at 6 degrees with a degree finder on the top of the intake. What s up? Are any one else haveing the same trouble? I used the original trans cross member.
OLDIRONRACING
Old 07-12-2018, 11:33 PM   #57
Oldironracing
How do I make this a build thread or link? Rename it or move it?
OLDIRONRACING
Old 08-10-2018, 09:20 PM   #58
Ric's/86
Did you figure out the problem?
Ric's/86 is offline   Reply With Quote
Old 01-02-2019, 12:04 AM   #59
Oldironracing
Still have not found the fix to the exstream angle of motor. I can put a3/4 spacer under trans crossmember and get it to 5* but trans touches front of trans tunnel at pinch weld.
OLDIRONRACING
Old 01-03-2019, 10:00 AM   #60
davepl
davepl's Avatar
Can the motor come forward then on its mounts so the back of the trans can come up more?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-03-2019, 10:05 AM   #61
Oldironracing
Can't move forward,won't have room for air intake tube between motor and fans
OLDIRONRACING
Old 01-05-2019, 09:11 PM   #62
Oldironracing
Ok up date on truck been a lot going on. Holley front drive installed air intake built brake lines made and run motor back in and now build a exhaust.
OLDIRONRACING
Old 01-05-2019, 09:12 PM   #63
Oldironracing
How do u load more than one picture at a time?
OLDIRONRACING
Old 01-06-2019, 06:34 AM   #64
my kids toy
Whos top rad mount did you use ?
my kids toy is offline   Reply With Quote
Old 01-06-2019, 04:43 PM   #65
Oldironracing
Made my own. Trying to post pictures.
OLDIRONRACING
Old 01-06-2019, 04:52 PM   #66
Oldironracing
Got pic to upload finally. Added this two sence last post. White 70 is a driver and the blue is work in progress.
OLDIRONRACING
Old 01-06-2019, 04:53 PM   #67
Oldironracing
Pic. Upload
OLDIRONRACING
Old 01-06-2019, 04:54 PM   #68
Oldironracing
Pic
OLDIRONRACING
Old 01-06-2019, 04:55 PM   #69
Oldironracing
Pic.
OLDIRONRACING
Old 01-06-2019, 05:01 PM   #70
Oldironracing
Pic.
OLDIRONRACING
Old 01-07-2019, 12:38 AM   #71
bigmoe
bigmoe's Avatar
I wouldn't measure the angle on the top of the motor. You need the angle at the trans tail shaft. Then you match that angle at the rear end pinion. 3 degrees down and 3 degrees up is good. Often you have to tweek it after all the weight is on the wheels. You can do that on the trans crossmember or angled shims on the spring perches. If you draw an imaginary line back from the trans output shaft, and another line forward from the rear pinion, the two lines should be parallel. Google image driveline angles and get some good explanation.
bigmoe is offline   Reply With Quote
Old 01-07-2019, 12:40 AM   #72
bigmoe
bigmoe's Avatar
https://ls1tech.com/forums/gears-axl...in-angles.html
Old 01-07-2019, 10:38 AM   #73
Oldironracing
At the crank front pulley I have 4*now. Thank I'll be good for now.
OLDIRONRACING
Old 01-07-2019, 12:47 PM   #74
bigmoe
bigmoe's Avatar
Front pulley would work too. Good idea. Gonna have to remember that one.
Old 01-09-2019, 12:29 AM   #75
Oldironracing
What r u guys doing for exhaust and what muffler?
OLDIRONRACING
