#26 |
![]() Join Date: Apr 2012
Re: Blazer got some color today
Thing looks great!!!!
#27 |
Thanks all.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#28 |
It looks awesome! You're at the state I was in September. Now the assembly starts!
I just bought a new steering box and a new PS pump. I went with the red head steering box with 3.5 turns. . And while at it a new ac system with new hoses and compressor.... There is no end to the details you can spend money on in assembly... |
#29 | |
#30 | |
#31 |
BigBlockBobby
Love that color too on my c10
Bob |
#32 |
Active Member
![]() Join Date: Jun 2013
That is a relly beautiful Blue. After seeing this, I think I may stay with Blue also. I'm in the rust removal stage.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. ![]() Members Met: Aldtime, DeadheadNM |
#33 |
![]() Join Date: Nov 2015
Eye popping blue, I love it.
#34 |
![]() Join Date: Oct 2001
Beautiful color, I'm so jealous.....
Things happen for a reason! |
#35 |
Thanks much. Little by little putting it back together. All new brake lines, fuel line, tank, driveline in, some wiring done, window guts in, mirrors on, rear bumper, etc. over the past few weeks.
#36 |
sure looks good so far Rick, alot easier to reassemble stock. I should have left well enuff alone, who am I to reengineer a masterpice
I'll have to visit in the spring when I get up to my son's house in Avon NY
#37 |
Jim,
That would be great. Yours will be a masterpiece when completed and will run like a new vehicle.
#38 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Coming along very nice Rick
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#39 |
Looking good my friend.
#40 | |
Thanks for the support
#41 |
Jim,
Even after buying new and used parts for the last year and refurbing the used, I find stuff I need every day I work on it. For example, last Friday, my new brake hoses arrived so I worked on installing them on the weekend, put the new wheel cylinders on new shoes along and the with hardware. I had run all new lines before putting the engine, trans and transfer case in. Pulled the hubs, cleaned them and prepped them for repacking and assembly - that's when I noticed that the passenger side lower ball joint needed replacement. So I pulled the right axle and spindle out and removed the knuckle. Lower ball joints easy to find - uppers not so much. I think I have them coming. Of course, I'll replace the spindle axle shaft needle bearings and seals, and as long as the axle is out, I'll also replace the axle ujoint since it would be dumb not to do so since it is out. Then I'll pull everything off the driver's side because if the passenger side lower ball joint was bad, chances are those will need replacing. About another $400 in parts and a couple full days of work, and I'll be back to where I started.
#42 |
#43 |
Looks great!!
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold) 1969 Jimmy, 2wd swapped. bagged, body dropped |
#44 |
Great color!
"This is the last part I will have to order for this truck." -I say this after every order. |
#45 |
Little by little. New ball joints finished, front brakes, wheel cylinders etc. installed (waiting on new drums for all 4 wheels), new axle u joints, spindle bearings, seals, grille and front finished up, etc.
#46 |
#47 |
Looks great love the color and great workmanship.
My 72 is a boring factory bronze but its clean and runs great wish it was a different color but its the way Chevy made it so that color it will stay. PG |
#48 |
Don't buy drums from Rock Auto, returned 2 sets because they were cracked
truck is looking amazing, nice work!! I see you got some snow, we were up in Altmar last week snow mobiling
#49 |
BlahBlahBlah
Great color, Ive heard people call that Hawaiian Blue. Cant wait to see it done and in the sun!
#50 |
Truck is looking great!
A little off topic, but how is that floor working out for you?
Justin 1970 Blazer in progress |
