01-02-2019, 11:57 PM | #776 |
Re: 67 long box
I was looking at buying a set of filler panels but they don't clean my vintage air dryer. It's a sure fit kit, so all pre bent tubing and mounting hardware. I'm not sure if there's a different filler panel to clear but I can make it. Any vintage air guys ? Cutting a hole to clear is defeating the purpose.
Do it, Do it right, Do it right the first time |
01-03-2019, 12:38 AM | #777 |
Re: 67 long box
Thanks I'll let ya know, I'm taking a break from it as I over think things according to my wife.
01-03-2019, 12:42 AM | #778 |
How did I get this OLD!
Re: 67 long box
No worries. It’s here if you want it.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
01-08-2019, 12:26 AM | #779 |
Re: 67 long box
I found the perfect fitting filler panel or at least one.
01-08-2019, 12:46 AM | #780 |
Re: 67 long box
Nice work man. Looks like a perfect fit.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
01-08-2019, 12:53 AM | #781 |
Re: 67 long box
Thanks man but the first one is the easy one, now to make a mirror image. That's where art work comes in when bent by hand and hammer.
Do it, Do it right, Do it right the first time Last edited by Metaldoc; 01-08-2019 at 01:02 AM. |
01-09-2019, 07:04 PM | #782 |
Re: 67 long box
Second half done and finished fit. Looks great, First try.
01-09-2019, 07:15 PM | #783 |
Re: 67 long box
Looks good Metaldoc.......nice clean fit on those filler panels.
01-09-2019, 07:24 PM | #784 |
Re: 67 long box
Very nice! I actually like the added bend you did to accommodate the a.c. stuff. Looks awesome, great work as usual!
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
01-09-2019, 08:32 PM | #785 |
Re: 67 long box
These 4 screws
01-10-2019, 09:33 PM | #786 |
Re: 67 long box
I like it and it cleans it up nicely.
01-11-2019, 12:52 AM | #787 |
Re: 67 long box
Do you have any plans for painting the filler panels?
01-11-2019, 01:01 AM | #788 |
Re: 67 long box
I looked at either black or blue, but I'm not sure if I go black the engine shows up more. If I go blue it will match the firewall but will draw the attention away from the engine.
01-12-2019, 01:02 AM | #789 |
Re: 67 long box
Tough call.... I think if it were my truck I'd go with black. I think the engine will be the focal point either way. One of the reasons I say black is because the small original blue part between the grille and new filler panels would be a slightly different blue than the firewall blue, so I'd say a definite contrast (black) would look sharper.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. Last edited by cornerstone; 01-12-2019 at 01:10 AM. Reason: had a long hard look and changed my mind. |
01-12-2019, 03:03 AM | #790 | |
Re: 67 long box
01-12-2019, 12:09 PM | #791 |
Re: 67 long box
Very nice work on the filler panel! Gives a really clean look.
01-12-2019, 12:41 PM | #792 |
Re: 67 long box
Thanks man it does look a lot cleaner
01-12-2019, 12:43 PM | #793 |
Re: 67 long box
Back on the dash today, got the LED 194 bulbs to make the gauges brighter.
01-13-2019, 01:48 AM | #794 |
Re: 67 long box
With only one bulb in it makes a big difference. They make a dimmer for these now so I can lower the light. Maybe.
01-13-2019, 08:52 PM | #795 |
Re: 67 long box
Well it fits back on with a couple of mods and it all works. I'm too cheap sometimes. The LED bulb change looks great.
01-14-2019, 01:15 PM | #796 |
Re: 67 long box
Metaldoc.... is the tach getting power from the red wire going to the fuel tank instrument gauge? Or what is that red wire used for on the back of the fuel tank gauge?
01-14-2019, 02:59 PM | #797 |
Re: 67 long box
I'm hoping this will work I tested power to there but not sure if it will interfere, but I'm thinking it needs a better source.
01-15-2019, 09:10 PM | #798 |
Re: 67 long box
Black fits the image and it blends in nicely. Clean looking.
01-15-2019, 11:20 PM | #799 |
Re: 67 long box
Yes! Well done.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
01-16-2019, 12:02 AM | #800 |
Re: 67 long box
