Old 01-15-2019, 01:28 AM   #26
kwmech
Re: Tranny fluid in Transfer case
Yes it can. Change the input seal to the T-case. You'll find upon removal that the seal is hard as a rock.
Old 01-15-2019, 10:25 AM   #27
A1971Blazer
A1971Blazer's Avatar
There is an o-ring that fits in the splined coupler to prevent atf from migrating into the transfer case...
it's shown here on this website https://www.quad4x4.com/catalog/cate..._parts#cat_255
part# QU30075... Input O-Ring
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-15-2019, 10:58 AM   #28
ballencd
Will do. Never done this before. Transfer case doesn't look hard but the transmission looks tricky to get the seal out. I'll post after I'm done.
1983 M35 (bobbed and converted to dump)
1984 M1010
1988 Chevy Suburban (5.7TBI/TH700R4/NP208)
1991 Chevy Suburban (5.7TBI/TH700R4/NP241C)
ballencd is offline   Reply With Quote
Old 01-15-2019, 01:27 PM   #29
kwmech
There is no seal in the trans with a 241 set-up. Just the large O-ring between the adapter and the transmission case. Then you have the gasket between the adapter and the transfer case and the input seal to the t-case. Remove the 4 bolts holding the aluminum input piece (transfer) to remove the seal. Do not over goop the aluminum piece with silicone when re-installing, other wise you'll plug up the drain hole
Old 01-15-2019, 03:31 PM   #30
ballencd
Thanks KWMECH, I've been going round and round with this and today was the first I heard that there was no seal in the rear of the trans. I got the t/c seal replaced with as little sealer as I could and was careful with the drain area. I'm working on cleaning up the rest to install the t/c back in the car. Thanks for your input.
1984 M1010
Old 01-15-2019, 07:17 PM   #31
ballencd
Well it is back in. I replaced the seal on the input of the transfer case only. I did put some (small amount) silicone sealant around the outside edge of the input flange and another bigger bead on the outside flange of the adapter to transfer case seat. It's filled with ATF and seems to be running fine. I will drain the pan and replace the filter soon but I wanted to get the problem fixed before I started on something new.
Thanks for the help.
1984 M1010
