01-17-2019, 09:48 PM | #1 |
Need a bit of help identifying this running gear....
I just bought this recently, this was a 4X4 conversion done about 25 years ago. It looks like a very proper job and maintains the original frame except for the front end where they custom fabbed in a frame to accept the front diff. It is a 1973 El Camino SS, 383 stroker, automatic. Manual locking hubs.
The fella thought (he is old) they used Blazer drive train. Any of y’all have an opinion of what was used? Year? I can take more pics up on the lift if need be. Thanks! |
01-17-2019, 10:38 PM | #2 |
Re: Need a bit of help identifying this running gear....
skip the casting #'s
show me the diff covers . and thats a np205 gear to gear t-case under there . and the 1 axle is missing its vent hose .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-17-2019, 10:38 PM | #3 |
01-17-2019, 10:44 PM | #4 |
Thanks a bunch! |
01-17-2019, 11:03 PM | #5 |
dana 44 front and gm truck 12 bolt rear
01-17-2019, 11:28 PM | #6 |
Could be from a Blazer or any 1/2 ton 4WD Chevy or GMC pickup.
Nice ride. How does it drive?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-18-2019, 12:29 AM | #7 | |
It goes into my keeper inventory I’m just trying to figure out what I have, so when it comes time to buy parts I’m at least going in the right direction (finding hedders, shocks, brakes etc...) |
01-18-2019, 01:29 AM | #8 |
If you identify whether the front knuckles are open or closed that would help you get closer on the year - I think open knuckles came in 71 or 72. Also if you can determine the width of the original spring perches - they changed in 73.
01-18-2019, 02:12 AM | #9 |
First open knuckle was in 1970, but it was drum brake. 1971+ saw disc brakes. All the chevy front housings have a spring width of 31.5'' all the way up to 1991 on the V series----including the Dana 44, dana 60 and the 10 bolt front. With the cross over steering pictured, my guess would be a 71-76 ish drive train. They had a flat top knuckle on the right side that could be drilled and tapped for a steering arm.
01-18-2019, 08:42 AM | #10 |
What a great bunch of guys, thanks so much for the help !! |
01-18-2019, 11:20 AM | #11 |
I'm happy to share my ignorance any time. Thanks for setting me straight, KW.
01-18-2019, 04:08 PM | #12 |
ya when you get time more pics of the steering system . interesting to see how they did it 25 years ago .
and as to date thats easy . pull a diff cover and look at the ring gear for date stamp . or the t-case will have a date stamp on the front facing the trans .
01-18-2019, 05:06 PM | #13 |
01-18-2019, 06:10 PM | #14 |
Steering shock needs to be flipped over on the axle bracket
01-18-2019, 09:13 PM | #15 |
from what i can see that sure is one nice conversion kit under there .
01-18-2019, 10:12 PM | #16 |
I think it all may be custom made. Looks pretty clean and not hacked
01-19-2019, 10:11 AM | #17 |
Thanks y’all, it’s a custom fab job, very welll done I think. I’ll shoot a couple pics of the front frame they sectioned in.
01-19-2019, 08:55 PM | #18 |
01-21-2019, 04:33 PM | #19 |
Is the transmission an SM465 or an automatic?
I have a '71 Jimmy, and all your running gear looks familiar. There is often the debate about: "Is an ElCo a truck?" Well THAT one is. When I was stationed at MCAS Yuma in the late '70s, there was a local's rig that was a Gremlin body on a Jeep chassis. Looked funny but went anywhere.
01-21-2019, 05:23 PM | #20 | |
01-21-2019, 06:16 PM | #21 |
all i can say is i dont do cars / that body style el camino .............. but that thing is just RIGHT in every way
01-22-2019, 01:48 PM | #22 |
Thanks K30, I dig it
Should be up your way around June; about the time Texas gets hot and Maine gets beautiful. |
01-22-2019, 04:06 PM | #23 |
if driving the car/truck thing love to see it first hand . or just stop in anyways .
i am easy off the highway I86 old state route 17 that goes from erie / jamestown all the way across lower new york back down to nyc area .
