01-20-2019, 12:01 PM | #1 |
Where can I find this part??
Maybe I am typing it in wrong, but I can not seem to find this air flap anywhere online. Mine is split all the way down the middle so basically it is useless.
Thanks |
01-20-2019, 03:05 PM | #2 |
Re: Where can I find this part??
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-20-2019, 03:14 PM | #3 | |
Thanks |
01-20-2019, 05:36 PM | #4 |
Can you tell us what year truck you have and where exactly the plastic part goes? Is it something to do with the a/c ductwork? I can't tell from the flat plastic what it might be.
01-20-2019, 05:42 PM | #5 | |
I believe it allows fresh air in once vacuum is applied to the actuator. The actuator should push open the flap. But with my piece the flap is split open where it should "pivot" so basically its useless. |
01-22-2019, 12:32 PM | #6 |
Any one else have an idea on where to find a replacement part?
01-22-2019, 02:12 PM | #7 |
Is there enough material left on the broken side that you could fasten another piece to it?
I wouldn't worry too much about it anyway, they don't block much air on Recirculate to make a big difference! |
01-22-2019, 03:16 PM | #8 |
Clean it very well and plastic weld it. A lot of these plastic parts are unavailable and the only way to fix the problem is repair the part. Find the compatible plastic and weld it in. It's probably PP plastic, but could be something else. Start viewing YouTube videos on plastic welding to get a good idea of what's needed. Sometimes just a simple soldering iron with the correct tip will do the job. I repaired a radiator shroud on the '97 K2500 I have with this technique.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
01-22-2019, 03:18 PM | #9 |
And I add that you can't hurt it any worse than it already is...
01-22-2019, 05:23 PM | #10 | |
Thanks for the feedback. |
01-22-2019, 10:09 PM | #11 |
Any chance you could use a small piano hinge on it?.....
01-30-2019, 10:46 PM | #12 |
Can try searching by part number, might find one or be able to use it for reference when contacting places:
http://www.gmpartswiki.com/getbigpage?pageid=58273
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
01-31-2019, 07:27 AM | #13 |
Since its the hinge part that broke, any repair will have to be flexible. piano hinge is a good idea but it may rust since it's out under the cowl. I might try making a hinge out of vinyl from a fabric store. once glued on each side, it should keep it in place, give the flexibity to open and close, and not rust in the long term.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
01-31-2019, 05:09 PM | #14 | |
Thanks Paul |
02-01-2019, 12:21 AM | #15 |
A piece of innertube and staples?
02-02-2019, 12:11 AM | #16 |
Those AC enclosure assemblies are quite the trick to restore back to original function! I’ve restored several and yes parts are very tough to obtain. I’ve even thought about creating a seperate business offering restored AC assemblies but the cost and labor to do one I’m sure is more than 90% of people would pay for-and the 10% of those who would isnt enough to make it worthwhile. I suggest some good ole fashioned junkyard time taking a few apart until you find a good one for parts. Again, Suburbans make great donor trucks!
02-11-2019, 12:08 PM | #17 |
Hay 44, I sent you a PM.Do you still need the flapper for the outside air ? I was taking parts off a scrapper truck I removed the piece. If you still need it I will send it to you just pay shipping.
See Ya John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
02-15-2019, 10:59 AM | #18 |
Since I did not get any response back from 44boggers, I am offer the same deal to anyone else. It is free except you just pay the shipping cost.
John
02-15-2019, 11:12 AM | #19 | |
Sorry I have been offline. I did not get a pm from you. But yes I am interested in your ac part. Please send me another pm with some details. Thanks buddy Paul |
02-15-2019, 04:57 PM | #20 |
PM Sent
02-22-2019, 10:57 AM | #21 |
Hello 44boggers, I sent you a PM. Package was sent out today, You should get it by Monday the 25th.
Thanks John
