Old 02-02-2019, 08:34 PM   #1
Submariner616
Active Member
65 K20 Rim size and lug pattern measurement
Anyone know the stock rim size and lug pattern measurement for a '65 K20? Thanks!
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 02-03-2019, 01:00 AM   #2
Captainfab
60-66 Nut
Re: 65 K20 Rim size and lug pattern measurement
I don't know about the stock wheel size, other than there were a couple of options available, but the wheel stud pattern is 8 x 6.5"
Old 02-03-2019, 07:24 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
https://lh3.googleusercontent.com/Xm...A=w869-h672-no
Old 02-03-2019, 01:17 PM   #4
Submariner616
Active Member
Perfect! Thanks! I picked up a 65 K20 that has old aftermarket chrome rims that are 16.5 inches diameter and just discovered nobody makes tires for those rims. It looks like the truck has a 4 inch lift and the tires are 22 years old with 99% tread left and are 33x12.50R16.5
Looks like new rims and tires...………..
Submariner616
Old 02-03-2019, 03:44 PM   #5
jayoldschool
Moderator
https://www.tirerack.com/tires/sizes...?diameter=16.5
https://www.summitracing.com/int/sea...ameter/16-5-in
Ebay, WalMart, Sam'S Club will all give more results.
jayoldschool is offline   Reply With Quote
Old 02-03-2019, 06:12 PM   #6
jocko
jocko's Avatar
That's an old wives' tale... There are several 16.5 options out there if you want to keep those rims. But, if you don't want to keep the rims, then now is the time to change over to 16.
