Active Member
![]() Join Date: Jan 2017
65 K20 Rim size and lug pattern measurement
Anyone know the stock rim size and lug pattern measurement for a '65 K20? Thanks!
Submariner616 1965 Chevrolet K20 350 4 speed manual |
60-66 Nut
Re: 65 K20 Rim size and lug pattern measurement
I don't know about the stock wheel size, other than there were a couple of options available, but the wheel stud pattern is 8 x 6.5"
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Active Member
Perfect! Thanks! I picked up a 65 K20 that has old aftermarket chrome rims that are 16.5 inches diameter and just discovered nobody makes tires for those rims. It looks like the truck has a 4 inch lift and the tires are 22 years old with 99% tread left and are 33x12.50R16.5
Looks like new rims and tires...………..
Moderator
![]() Join Date: Dec 2012
https://www.tirerack.com/tires/sizes...?diameter=16.5
https://www.summitracing.com/int/sea...ameter/16-5-in Ebay, WalMart, Sam'S Club will all give more results. |
![]() Join Date: Oct 2009
That's an old wives' tale... There are several 16.5 options out there if you want to keep those rims. But, if you don't want to keep the rims, then now is the time to change over to 16.
