02-23-2019, 01:39 AM | #26 | |
20' Daredevil (Ret)
Re: What lift
Everyone has their own opinion and that is mine.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-23-2019, 01:11 PM | #27 |
Re: What lift
I think I’m going to go for the 2.5” as everyone is saying that is the best one for daily drivers. Thanks everyone.
02-25-2019, 10:14 PM | #28 |
Roto Reuter thats the name...
Re: What lift
I went 2-1/2" Skyjacker lift with zero rate spring in back. Here are a couple threads.
http://67-72chevytrucks.com/vboard/s...d.php?t=599446 Also, a thread to the first look after install. http://67-72chevytrucks.com/vboard/s...d.php?t=620627
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-25-2019, 10:43 PM | #29 | |
Re: What lift
02-25-2019, 10:51 PM | #30 | |
Re: What lift
02-25-2019, 10:54 PM | #31 |
Re: What lift
I added the zero rate spring after my skyjacker spring install. I saw that the back of the truck was just a little bit lower. The 1" zero rate spring brought up the back end just enough and leveled it out.
02-26-2019, 11:09 AM | #32 |
20' Daredevil (Ret)
Re: What lift
In my case, many years ago I added an AAL to my K20's factory rear spring pack. Then a few years back I added a heavy-duty Hellwig overload leaf spring kit. The truck now sits virtually level with the 2.5" Skyjackers up front.
I'm not recommending this combination, just posting it for comparison purposes. With all that rear spring capacity, the truck has a pretty firm ride. But it handles heavy loads pretty well, which was my goal.
02-26-2019, 12:33 PM | #33 |
Re: What lift
hay DEROTOREUT nice to see a local guy .
i am south of you in horseheads just east of corning .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-26-2019, 01:02 PM | #34 |
Re: What lift
Huh, I will most likely need to add that, you only had a short bed and still was not level wonder what a long bed would do.
02-26-2019, 09:01 PM | #35 |
Re: What lift
I know Horseheads. I used to live in Painted Post and Big Flats. Cool names huh? Nice area. Soaring Museum right? lol
02-26-2019, 09:32 PM | #36 |
Re: What lift
the air port is my back fence
03-05-2019, 02:42 PM | #37 |
Re: What lift
4" Tuff Country soft rides up front, ORD Shackle Lift in the rear. 33-12.50 R 15 Dick Cepek Mud Country tires and 15x10 Mickey Thompson/Alcoa Rims
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-14-2019, 04:24 AM | #38 |
Re: What lift
Awesome truck you got there. I've been planning to modify mine to make it more off-road capable truck but I lack the reference to do so. I already have a set of rockstar wheels I got last December to start with.
03-14-2019, 01:17 PM | #39 |
Re: What lift
4inch with 35s
Took a few leafs out of back
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 |
03-16-2019, 04:19 PM | #40 |
Re: What lift
2" Tuff country on my 70 netted about 4" of total height gain from where it was before I started. It was little taller than I was hoping, but the ride is much smoother, i have noticed a lot more body roll for sure around corners too. the i put 3" springs on the back but it was way to low so i had to put the factory 1.5" blocks back in. This still did not level out the frame so, I will be putting some 2-2 1/4" block in soon.
03-18-2019, 09:56 PM | #41 |
Re: What lift
Little bit of a closure for the thread, I bought a 4" skyjacker soft ride for my from a member on the board. Will post pictures if I ever finish my truck
03-23-2019, 10:38 AM | #42 |
Re: What lift
72 K15 - I'm assuming you had factory suspension... if so, what are your intentions with your stock suspension? I'm looking for stock springs to put my K 10 back to original.
Thx
Tony 1972 Chevy K10 SWB Custom Deluxe 350|350|NP205 2018 GMC Sierra Z/71 Crew 2008 GMC Yukon 2007 Chevy 1500 LT 1967 Pontiac Firebird 400 |
03-23-2019, 11:42 AM | #43 |
Re: What lift
Yup stock springs, looked to sag a little bit and I’m guessing shiping be would be stupid expensive but if interested send me a pm.
04-14-2019, 06:02 PM | #44 |
Re: What lift
My 71K1500 has Tuff Country 2" spring lift. Tires are 32x15 Cooper Discoverer. To me, the truck sits more like it has a 4" lift, to high for my taste. I have a complete set of leaf springs from a 67-72(not sure which year) K20. Any guesses on how my truck would sit with these K20 springs on it? I think the K20 springs are compatable, as replacement springs use the same numbers for K10 and K20. Would the old K20 rear springs be to harsh riding on a short bed? I could save much $ by using the used K20 spring.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) |
04-15-2019, 11:02 AM | #45 |
Re: What lift
My truck has K20 rear springs I have 5 leafs and an overload. I removed my overload spring. How many do your stock K10 springs have how many on the K20's ?
I cant tell you how they ride yet as I haven't got mine on the road yet. close very close!!!
04-15-2019, 04:58 PM | #46 |
Re: What lift
Both the 2" Tuff Country springs and the original equipment K20 springs have a total of 6 leaves. Both springs lower leaf is much shorter, this must be what your referring to as an overload spring. I didn't measure, but the K20 total spring pack looks a little thicker or taller than the Tuff Country.
04-15-2019, 05:39 PM | #47 |
Re: What lift
Sorry yes the short almost flat leaf is the overload leaf.
I am not sure but I think most stock k10’s have 3-4 springs including the overload My sons c10 had 4 total leafs and when we lowered it we replaced them with a 2 leaf pack.
