Old 03-11-2019, 11:59 AM   #351
zicc1835
zicc1835's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by 71CHEVYSHORTBED402 View Post
Polished this up with Pro Honda. Comes in a spray. Beyond my expectations, it took out some tuff areas with ease. I could brighten it up some more, but why bother. May have painted it, they look amazing painted, but seems they "breathe" easier without it.
$1550 to have this rebuilt. It's shifted smooth since the day I got it, but 140K miles, and an occasion of abuse, it was due.
Which one did you use they have a few different products
zicc1835 is offline   Reply With Quote
Old 03-11-2019, 12:53 PM   #352
89AKurt
89AKurt's Avatar
Not sure if it's worth the trouble, cleaned up the aluminum trim with steel wool. It's all trashed, front fender arch looks like it was driven through a barbed wire fence.
Can anyone tell I did only the cab?
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-11-2019, 01:07 PM   #353
weq92f
Can't tell with that image, no. Too poor quality and the angle is wrong for comparison.
But... it does look good to me!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-11-2019, 01:40 PM   #354
BugzC10
BugzC10's Avatar
That's called Patina!
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-11-2019, 05:54 PM   #355
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Here you go. Their instructions say "for longer lasting shine, leave on until haze and buff"...............Well, I tested an area, let it sit over 24 hours and their aint no haze about it, it's pretty oily. https://www.chapmoto.com/pro-honda-s...EaAssvEALw_wcB
The transmission was mostly clean already. I sprayed a reasonable amount and let it sit 4-5 hours. Wiped, brass brushes on a Dremmel, wiped. Sprayed some more and buffed some with fine steel wool, whiped. Sprayed a pinch more, wiped and done. About 1.5 hours is all, nice stuff.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-11-2019, 06:41 PM   #356
Barnfind46
Barnfind46's Avatar
Every little bit helps. The little things are what make a well kept daily driver stand out. I repainted the tailgate letters on my faded tailgate with a spray can and some tape. Made the truck look much better!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 03-11-2019, 10:13 PM   #357
66clow
66clow's Avatar
Recived my bolt on firewall panels from Atomic Armadillo Metal Fab. Excellent fit.
66clow is offline   Reply With Quote
Old 03-11-2019, 11:10 PM   #358
zicc1835
zicc1835's Avatar
Thanks much for the response I’m going to try it .....my trans is clean I thought about paint but like the natural cast look
Old 03-11-2019, 11:28 PM   #359
SoCoC10
SoCoC10's Avatar
Installed new trim on the K10 Cheyenne. Final door and fender fitment is next.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 03-12-2019, 01:56 AM   #360
71CHEVYSHORTBED402
I read someplace the transmission will appreciate the natural cast, something to the effect paint may look in some heat. Good enough for GM it's good enough for me. There's a little scaling, you can see. I figure so what.
I shined up and installed the tubes today. 3M works magic on stainless and chrome. The transmission tube was well stained etc., no problem.
Trim look AWESOME SoCoC10
Tony
Old 03-12-2019, 09:21 AM   #361
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
I loaded the ramp truck yesterday for the 5hr trip to the beach for the big one in SC.
First show of the season for me.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-12-2019, 10:04 AM   #362
JustToxic
JustToxic's Avatar
Started putting new floor boards in the cab over the weekend. New kick panels, lower A-pillar, DS forward cab support, Inner and outer rockers, PS rear cab support and finally Cab corners.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 03-13-2019, 09:14 PM   #363
Thrill4130
Active Member
Thrill4130's Avatar
Your 68 looks awesome how it is. Here’s my 67 I put the hubcaps back on today. On mine it seems everything I have to fix stands out so I try to leave it alone
Thrill4130 is offline   Reply With Quote
Old 03-13-2019, 09:54 PM   #364
nlped
nlped's Avatar
They both look killer!!! I’ve got one too, but mine won’t be so original underneath.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 03-13-2019, 10:05 PM   #365
davischevy
davischevy's Avatar
My dad bought the twin to that truck brand new in the fall of 67.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-14-2019, 01:29 PM   #366
toolboxchev
Hey I think its awesome that you are keeping it original for now. Time capsule from the past, brought back to life.
Dig IT!
toolboxchev is offline   Reply With Quote
Old 03-14-2019, 02:08 PM   #367
machas74
I added 383 emblem on hood.
machas74 is offline   Reply With Quote
Old 03-14-2019, 06:58 PM   #368
Toms67
Toms67's Avatar
Originally Posted by SlowGreen71 View Post
Shortened her up a little and changed over to 73-87 style engine mounts. Still need to finish welding the inner sleeve and smoothing the cuts for the motor stands but it’s all in.
Nice job. Looks good.
Toms67 is offline   Reply With Quote
Old 03-14-2019, 08:08 PM   #369
Speedracer39
Speedracer39's Avatar
Finally finished assembly of new engine trying to get caught up with a few other repairs before install.
Speedracer39 is offline   Reply With Quote
Old 03-14-2019, 09:34 PM   #370
Boog
laying low
Boog's Avatar
Turn.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-14-2019, 10:27 PM   #371
Ben IV
Started on a carb rebuild. Never touched a quadrajet before.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 03-14-2019, 11:42 PM   #372
Steeveedee
Who Changed This?
Steeveedee's Avatar
If you don't have one yet, get one of the books on rebuilding Q-Jets. The sheet that comes with the carb leaves a lot of necessary information uncovered.
~Steven
Simi Valley, CA
Old 03-15-2019, 07:25 AM   #373
66clow
66clow's Avatar
Hammer dolly hammer dolly
Old 03-15-2019, 12:02 PM   #374
89AKurt
89AKurt's Avatar
That's something I *should do* in the future, there are pop-riveted aluminum pieces now, but still need to slow down when crossing a puddle. LOL
Appreciate everyone responding to my cheapskate task!
1968 Long Bed
Old 03-15-2019, 03:10 PM   #375
67/70C10SHORTY
I almost got motivated to work on my truck today
67/70C10SHORTY is offline   Reply With Quote
