Old 03-14-2019, 03:15 PM   #1
UATahoe
Removing Ebrake completely
Just a quick question to the board. I am going to be running disc brakes in the rear with wilwood calipers and no ebrake provisions. Any ramifications to just removing the entire pedal assembly and cables to clean things up? Seems pretty straight forward with no issues, just wanted to make sure i wasnt overlooking something.
UATahoe is offline   Reply With Quote
Old 03-14-2019, 05:00 PM   #2
sweetk30
sweetk30's Avatar
Re: Removing Ebrake completely
any vehicle inspections that require parking brake to pass ? ?
otherwise up to you i say . in my rust belt living we are afraid to use them in fear they will be FROZEN on and not release unless you use them all the time .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-14-2019, 05:26 PM   #3
riz
Unless you live a stupid state like California....... remove it all.
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 03-14-2019, 06:26 PM   #4
Bimus
A working emergency brake is a must have to me .
Bimus is offline   Reply With Quote
Old 03-14-2019, 07:56 PM   #5
UATahoe
No inspections here in Alabama so no worries there. I will be honest, at 37, I have never once used an E-brake. Lol. Well, once actually when launching a boat. Since it’s going to be inop anyways, I think I will just yank it all out and clean things up. Thanks for the input guys.
Old 03-14-2019, 08:28 PM   #6
sweetk30
sweetk30's Avatar
lots of no inspection states if you get in a motor vehicle accident they check your vehicle to see if it was at fault for defects or lack of maintenance . i would check to see if this could be a violation gosh forbid you ever had a problem .
Old 03-14-2019, 08:36 PM   #7
UATahoe
Totally understand. I mean it will be inoperable regardless of whether or not I remove everything since the rear calipers don’t have ebrake provisions. That’s a good point though to check on that.
Old 03-14-2019, 09:48 PM   #8
Keith Seymore
Keith Seymore's Avatar
Haven't had one on my Chevelle for 20 years (strip only; about 10-20 miles per year on the street). I removed it because the cable was in the way during trans swaps and maintenence activities (four inch exhaust doesn't allow for much room, either).
I pulled the ebrake off the car during my time in Arizona. Our there, I didn't have any garage space for working (it was used for storage) so I had the car up in the air in the driveway working on it.
I didn't realize, but while I was under the car my next door neighbor stopped by and was quietly watching. Imagine my surprise when, dressed in my dirty coveralls, I came rolling out from under the car with the ebrake cables and links in hand.
Immediately, I said: "...only ONE leftover part!!".
He responded, just as quickly: "...it doesn't look important anyway..."
I figure if I need more stopping power I'll add a chute.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-14-2019, 09:54 PM   #9
mongocanfly
mongocanfly's Avatar
No need to worry about not having one...Alabama couldnt care less....unless they can tax it...
I have no clue when the last time I used mine was...if ever....now on a manual trans it's a little different.....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-14-2019, 10:41 PM   #10
bigdaddy4x4
bigdaddy4x4's Avatar
I removed the parking brake on my 77 4x4 and added disc brakes to the rear I thought about usein a brake micro lock . but have not .got one . I have had my dog hit the tcase shift handle when running 60mph and knock in to netural and the same thing can happen anytime when parked. the shift lever can be hit by my dog or worse one of the grandkids and it could just roll off and hit anything not good.
bigdaddy4x4 is offline   Reply With Quote
Old 03-14-2019, 11:03 PM   #11
UATahoe
Lol awesome story Keith. Definitely think it’s the way for me to go. Appreciate all the feedback guys. I’m going to go ahead and take everything out. Losing the ebrake pedal will give me a little more clearance around the kick panel speakers too. Time to make one big push and get this LS project back on the road.
I hear you Mongo on the tax. Really looking forward to this new gas tax. Guess we are finally catching up to some of the other states.
Old 03-15-2019, 09:45 AM   #12
SunSoaked
SunSoaked's Avatar
The aerodynamic drag of squarebody trucks usually negates the need for emergency brakes.
SunSoaked is offline   Reply With Quote
Old 03-15-2019, 10:56 AM   #13
rpmerf
rpmerf's Avatar
"Don't use the emergency brake. If you use the emergency brake, you are in charge of fixing it"
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 03-15-2019, 11:56 AM   #14
layinrocker65
layinrocker65's Avatar
There aren’t vehicle inspections in CA so it wouldn’t be a big deal. I bet most states are like CA though where it requires vehicles to have a parking/emergency brake to be maintained in good working order.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 03-15-2019, 12:11 PM   #15
sweetk30
sweetk30's Avatar
ny state law for vehicle inspection test each year . you the inspector have to test its operation and if it holds the vehicle .
Old 03-16-2019, 01:42 PM   #16
Pontiac1976
Pontiac1976's Avatar
Just a side note. They help take the stress of the trans when parked on hills & keep the shift linkage stripping or have to adjusting more often.
I run with and with out. But after parking on any slops try to in shift leaver would make the shift linkage slip or strip and need tighten more often.
Or drive around to find flat spot parking. lol
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-17-2019, 07:06 AM   #17
Wgesnerjr
Wgesnerjr's Avatar
If you want to keep the e-brake and lose the pedal, why not install an electric brake?
https://www.amazon.com/Stopp-Button-.../dp/B00QL3JKKQ
expensive but would clean up the pedal area.
these are also on newer cars and SUV that are hitting the yards now. I bet one could be adapted way cheaper. our 2014 impala has this set up.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 03-17-2019, 10:58 AM   #18
mongocanfly
he switched to wildwood brakes..that have no e-brake provision....
I would look into a linelock type system if I needed a e-brake in this situation...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-17-2019, 06:07 PM   #19
hatzie
Moderator
hatzie's Avatar
Or a driveshaft/pinion mount E-Brake. Some of the P series had a drum brake on the transmission output yoke and a backer with shoes on the transmission.
https://www.google.com/search?q=Driv...=4288&bih=2275
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-17-2019, 06:28 PM   #20
AussieinNC
Moderator
AussieinNC's Avatar
Not sure why you are electing to use Willwood calipers without eBrake....
Willwood make eBrake style calipers for just about any application....
I see you are in Alabama...no inspections yep...but think about resale to a new owner that lives in a state where mechanical inspections are in force...
Just my humble opinion sir....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 03-17-2019, 07:03 PM   #21
UATahoe
The rear conversion brackets are meant to be used with D52 calipers. Wilwood doesn’t offer an ebrake on that caliper. I didn’t mean for this to turn in to an ebrake debate honestly so I apologize about that. I was mainly angling towards making sure nothing else is adversely affected by removing the pedal. Appreciate all of the feedback!
Old 03-17-2019, 07:11 PM   #22
hatzie
Moderator
hatzie's Avatar
You loose your parking brake. Up to you whether that matters.
The possibility of insurance problems and possible imperial entanglements have already been mentioned. Bad enough to get them to cover what they say in writing that they will I don't like giving them any excuses but we're all adults here. Ya makes ya choices and ya takes ya lumps...
Old 03-18-2019, 07:31 PM   #23
kalbert
It's a parking brake, not emergency brake. You'll never apply enough force to stop in an "emergency". It'll hold the vehicle in place on a hill though. Like putting a boat in, parking on a grade, etc. Don't rely on the parking pawl or engine to hold you.
kalbert is offline   Reply With Quote
Old 03-18-2019, 07:57 PM   #24
sweetk30
sweetk30's Avatar
i would trust our older vehicles for e-brake over to days wimpy crap that most call a e-brake . . .
