Old 03-23-2019, 03:09 PM   #1
Sooner71
63 GMC throttle pedal conversion
Hey what's up guys , I'm in need of some help. Has anyone done a gas pedal conversion. If you have please get back with me. Please. I need direction.
Sooner71 is offline   Reply With Quote
Old 03-23-2019, 05:34 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 63 GMC throttle pedal conversion
Conversion to what?
Old 03-23-2019, 06:35 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Are you wanting a cable style gas pedal?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-24-2019, 12:52 AM   #4
64shortbox
64shortbox's Avatar
Are you talking about something like this?
64shortbox is offline   Reply With Quote
Old 03-24-2019, 08:33 AM   #5
Sooner71
Yes, I'm looking to go cable.
After talking to the tech department at cpp ( classic performance products ), I found out that there wasn't no information on a 63 GMC throttle pedal conversion, so I had to figure out something, so I removed the original throttle assembly that was bolted to the side of the transmission tunnel. I found a flat spot next to that area and mocked up my lokar pedal and marked a line around the base of the mounting surface, then I put the plate that mounts to the firewall over the line that I marked around the base of the pedal to marke the 2 holes that needed to be drilled for the installation. Worked out perfectly.
Thanks for all y'alls responses.
