#51 | |
Re: 1969 C50 crew cab build
#52 |
Got the front firewall of the crew cab portion taken off this weekend. Looks as clean as I had hoped. Started disassembly of the front cab to get the back panel, headliner, etc out. The front driver bottom door pillar is pretty rusty in places. You can buy front pillar replacements for C10's but they are not the same as the C50. I will have to get into it deeper. I was reading a thread earlier and have bought a "67-72 chevy assembly line instruction manual" to help me understand where all the spot welds are. Yikes.
#53 |
Some more info....a C50 cab sits off the frame about 2.5" higher than C10-C30 trucks. I will need to locate another set of C50 front cab mounts to get the 2nd cab on the same plane as the front cab. For the back mounts I will have to use the 2 most inboard set of cab mount holes that are already in the cab, and make another cross member and set of bushings like what I made for the front cab.
Anyone have a set of C50 front cab mounts handy?? |
#54 |
Progress this weekend. This is going to be the back cab.
#55 |
Sorry about the sideways picture. Not sure why it did that nor do I know how to fix it! Here is a cross section of the door frame/top sheet metal/drip edge, etc in case anyone wondered what all is in there. Also showing the joints where the head liner and the seam along the back top of cab in case anyone wants to have a reference.
#56 |
Old frame, motor and trans.
#57 |
![]() Join Date: Dec 2009
Nice work on cutting the cab.
Thanks for the Pics. I am a few weeks away from cutting mine.
#58 |
#59 | |
http://67-72chevytrucks.com/vboard/s...63#post8395463 I working on getting it in my signature. I have the instruction just need to try again.
#60 |
Here is this weekends progress. Got the 2nd cab positioned on the frame. The cab length is 95" from front door to back of cab. I want 4 full size doors so this will allow plenty of leg room. Now I will have to figure out how to marry the 2 cabs.
#61 |
Very Nice Progress
![]() Are you going for this approach in the picture below? If so will you have the other 10.5 inches as a filler panel? Or will you lengthen the rear door?
#62 |
Keeping a eye on this one. Good luck
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
#63 |
![]() Join Date: Jun 2017
I'm watching now too! Nice progress
#64 |
Have you thought about using a Suburban and then welding on the back of the truck cab behind the rear doors?
http://topclassiccarsforsale.com/che...-70-71-72.html Last edited by Airdirect; 03-09-2019 at 02:47 PM. |
#65 |
Very cool build! I'm in
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
#66 |
Yes...kind of. The front door will be stock. I will take the back of the rear door channel for the passenger side and weld it to the front driver side to make it uniform front and rear. Not sure how to explain it until I cut and show a pic.
#67 |
I have a radical idea!
Very cool!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#68 | |
A C-50 will look real good with (2) Full-size rear doors. Edit: 4 full size doors
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 04-13-2019 at 08:35 AM. Reason: addition/Correction |
#69 |
Glad I found this build. Looking forward to it progressing.
#70 | |
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
#71 |
![]() Join Date: Apr 2016
Awesome! Can't wait to see how the rounded rear doors look and how much room you have inside!
#72 |
#73 |
![]() Join Date: May 2013
Hey gup1972,
When your able, could you take a couple pictures of how your ch465 is mounted to the engine? Trying to confirm if there is adapter in between the engine and trans. Thanks! |
#74 |
![]() Join Date: Dec 2011
Subscribed awesome!
#75 |
Just curious...can Dana 60 and 14 bolt swap in and bolt to the spring perches on the c50 chassis?
