Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 09-18-2017, 01:35 PM   #26
The1960APE
The1960APE's Avatar
Re: 81-87 NEW OEM quality dash pads!!
Originally Posted by The1960APE View Post
I cannot seem to get them on the phone or to respond?
He called today, nice fellow, dash is on its way!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline
Old 09-18-2017, 02:10 PM   #27
TKCR
TKCR's Avatar
That IS good news!! My bad!! Sorry there was a typo on that earlier.
TKCR is online now
Old 10-24-2017, 01:21 PM   #28
cheyennepickup
I have just made up a bunch of 73-78 and 79-80 and 81-87 dash pads all colors and ready to ship out. shipping is 55.00 anywhere in lower 48 states. Please contact me by phone if you have questions I rarely check messages on here. Thanks Anthony
cheyennepickup is offline
Old 03-20-2018, 02:39 PM   #29
blindbug
Did your prices go up? The original post said $325, and the last pose has shipping at $55... but when I go to the site I'm getting $339.95 and $60.79, respectively.
blindbug is offline
Old 10-28-2018, 01:33 AM   #30
BigJackDaddy
BigJackDaddy's Avatar
Original post was from Apr 2017.
ColoradoMelons.com
BigJackDaddy is offline
Old 10-29-2018, 10:14 AM   #31
blindbug
... and my question was from Mar 2018. The question was asked because some vendors offer discounts for forum members, so I was interested in whether the cost increased, or if the cost posted here was a forum-member-only deal.
Regardless, my post was 7 months ago, and I've since purchased and installed a new dash pad. I ended up with a USA1 Industries pad, which I am not 100% satisfied with, but it's a sunk cost now. The grass is always greener on the other side, but wish I had went with one of these pads now... I didn't get a response to my original question, nor a response to 2 voicemails, so took it as a bad sign. Oh well!
blindbug is offline
Old 10-29-2018, 12:57 PM   #32
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
blindbug, what was your issues with the USA1 pad?
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline
Old 10-29-2018, 02:38 PM   #33
blindbug
  1. I did like the finish of the pad itself. The material used very closely mimics the stock pad that I removed from my 86'.
  2. It required a bit of trimming to get the pad all the way seated on my dash... but that is to be expected with any of the aftermarket pads from my research.
  3. The paint that is on the pad (blue) was already rubbed off in some places before I even got it in the truck. Not enough to warrant a return, but it's sort of a let down.
  4. I ordered matching defrost vent covers, but they did not seat fully, as the hole wasn't large enough. I ended up having to cut off a (unseen) corner of the vent cover to get it to click into place.
  5. I odered a new aluminum dash insert. When I went to put that onto the pad, the holes didn't quite line up, and caused the insert to not seat fully. I used a dremel to make the hole a little lower and that helped some.
  6. The mold that they use is obviously designed for A/C vents, because there is a slight curve inward where the inner A/C vent would go, it isn't insane, but it creates a gap between the insert and the pad for about 3"... it wouldn't be noticable if the rest of the insert had the same gap, but because part of the insert sits up against the pad, this one 3" section looks bad (to me).
  7. The lower holes that hold the dash pad to the dash metal (there's like 5o f them). Those holes DO NOT HAVE ANY METAL REINFORCEMENT. The stock pad has metal embedded into those mounting tabs which means the pad holds down against the dash fully. Without the metal reinforcement, it took less than 10 minutes for one of the tabs to rip (it's all vinyl) instead of keep the pad in place. I ended up just removing all the screws because I'd rather have no screws than rips all across the bottom.
  8. The foam is too thick in parts, causing the dash pad to look wavy across the top. Especially above the driver's console, I have a big wave that I thought would lay down better, but I'm going to have to pull the pad, shave down a 3-4" section and then put the pad back in.
  9. The upper left and right sections where the drivers dash bezel sit against the pad need better screw retainers. The ones that are in there are glued? taped? I don't know... all I know is that the first screw went in and I hear 'ting' and the flat nut falls to the floor. The other side, same thing. I had to get a U nut and do some cutting and arranging to get the bezel to sit against the pad in this section... and even then after an hour of road time, the nut slipped off the pad and I have a gap again.
This is just one man's opinion. It's the little details that make or break a quality product, and I think the USA1 dash pad missed the little details. When you step back and look at the pad, it looks great... but anyone with a hobby vehicle knows that any imperfection you notice becomes the only thing you obsess over. Given the PRICE of the pad, I thought that these little things shouldn't have been such an issue. The lower retaining metal is a very simple fix, and feels sloppy that it wasn't fixed after the first version.
The Cheyenne pad could have the exact same issues... I don't know. All I know is that I wished I'd went with a different brand on the off chance that it wasn't an issue.
blindbug is offline
Old 12-11-2018, 08:21 PM   #34
cst204x4
So has anyone bought and installed one of these Cheyenne pads recently I’m needing one for my 81
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline
Old 12-12-2018, 04:53 PM   #35
1968vetL-71
Junior Member
1968vetL-71's Avatar
i'm about ready to buy one in the next week or so for my 89 V3500. I'd like to know also.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline
Old 12-13-2018, 11:24 AM   #36
yote1234
yote1234's Avatar
i've bought 3 from these guys. and i am impressed! the color is ever so close if not right on. the fit is nice. i am impressed. i feel these are the best thing to nos orig. just my .02 cents. again very pleased.
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline
Old 12-13-2018, 04:45 PM   #37
1968vetL-71
Junior Member
Cool... I guess i'm gonna order one tomorrow. I'll let y'all know how it fits in a couple weeks.
Old 12-30-2018, 11:50 AM   #38
1968vetL-71
Junior Member
Well I called and they are out of stock for a couple weeks. So I will wait till after the first of the year and go from there. I did order both seat upholstery front/rear and foams for the crew cab from USA1, but really wanted to order the dash pad from Cheyenne.. as soon as I get it in I will give everyone an update.
Have a happy and blessed New Years all!!
Old 12-30-2018, 01:23 PM   #39
TKCR
TKCR's Avatar
Good choice on the foam, USA1 Industries. That is where I get my foam from, for my seat restorations. Made right here in the USA. Fit and quality is A+!!
TKCR is online now
Old 04-14-2019, 08:55 AM   #40
cst204x4
Any updates I'm ready to order one did you get yours 1968vet-L71
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
cst204x4 is offline
Old 04-16-2019, 08:09 AM   #41
1968vetL-71
Junior Member
Well, i ordered one from USA1 industries. it came damaged in shipping. Honestly, the last couple items I received from them were very poorly packed. I called and expressed my concern. They were great at returning and replacing the items... but the time frame is a little longer than I like. I literally just received my 2nd dash pad from them yesterday. I will unpack this evening and post my thoughts.
Old 04-16-2019, 08:28 AM   #42
TKCR
TKCR's Avatar
Damn, that's not good. I have a pallet of parts being delivered today from USA1. I've been waiting over a month for these parts. I hope they arrive safely. I get a lot of large orders from them. I think in the future, I will just make the drive to NC, and pick them up. I hate waiting this long!!
TKCR is online now
Old 11-03-2019, 09:10 PM   #43
SilveradoDude
Originally Posted by cheyennepickup View Post
These pads suggested retail price is over $400.00. If you want a color, other than black, I have them in grey, brown , burgundy, camel and blue. PRICE IS 325.00 FIRM I can ship if needed to lower 48 states for 59.00 if needed .
IF YOU WANT YOU CAN PURCHASE ONE DIRECTLY FROM MY WEBSITE
Looks like your prices have gone up...quite a bit actually...
SilveradoDude is offline
Closed Thread
