Old 05-26-2019, 10:04 AM   #26
damnyankee36
damnyankee36's Avatar
Re: Out of the box cool ideas / upgrades.
Sure do. (Having trouble uploading pics at the moment)...
damnyankee36 is offline   Reply With Quote
Old 05-26-2019, 10:13 AM   #27
damnyankee36
Old 05-26-2019, 10:18 AM   #28
damnyankee36
Old 05-26-2019, 10:25 AM   #29
damnyankee36
Wish I could tell you what tank that is is. It's been years since I got it from the junkyard.
Old 05-26-2019, 11:52 AM   #30
cwcarpenter98
cwcarpenter98's Avatar
That is sweet man, thanks for the pics. I would like to do something similar with the fuel door, but haven't decided what I want to do about the tank. I still want to keep my spare tire underneath the bed
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 05-26-2019, 01:11 PM   #31
damnyankee36
Hmmm, without even looking at my truck, I wonder if there is room for a saddle tank like the later Chevys?
Old 05-26-2019, 01:25 PM   #32
cwcarpenter98
I'm thinking about maybe fitting up a factory squarebody tank, but for now my tank behind the seat works good and doesn't fume up the cab. Got a bunch of other stuff I want to do before I get to moving the tank
Christian Carpenter
Old 05-26-2019, 07:58 PM   #33
nsb29
nsb29's Avatar
Those saddle tanks were bombs they were mounted on the outside of the frame if you got t-boned they popped and the gass went into the engine compartment of the car that hit you you know what happens next
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 05-27-2019, 11:12 AM   #34
damnyankee36
Also installed 4X6 speakers under the dash and behind the seat in the corners. A powered sub under the seats provides the lows.
Old 05-27-2019, 07:52 PM   #35
Blue666(2)
How didyou cut the slots in the upright panel? Did you use a drill & a Dremel? They look really good.
Blue666(2) is offline   Reply With Quote
Old 05-27-2019, 09:04 PM   #36
damnyankee36
Thanks!
I had the luxury of getting them water jetted at work. I drew up the pattern based on the slot design of the original dash speaker grille.
Old 05-28-2019, 07:17 PM   #37
raidmagic
raidmagic's Avatar
Eh, more of a wife's tale than a factual problem. Millions upon millions of those trucks were made. I bet one couldn't scrape up 20 actual reported stories of it really happening.
raidmagic is offline   Reply With Quote
Old 05-28-2019, 07:52 PM   #38
damnyankee36
I remember back in the day of the same problem with school buses. A very popular topic. But as raidmagic mentioned, not so sure of the actual numbers.
Old 05-28-2019, 08:45 PM   #39
Clyde65
Clyde65's Avatar
I worked at some dealerships back in the 80’s and there was a law suit against GM for that but iirc, it wasn’t won. Like others have said, there were some accidents where the tanks ruptured and caught fire, but not enough for a recall.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-28-2019, 10:31 PM   #40
TxCajun
TxCajun's Avatar
I'm not advocating on either side with respect to the side saddle tanks, but here are some interesting articles related to the subject.
The Center for Auto Safety report on "History of the GM Side Saddle Gas Tank Defect":
https://www.autosafety.org/history-g...s-tank-defect/
You can find some interesting research done on safer locations for mounting fuel tanks in the website below. For example, mounting between the frame rails was found to be safer than the side saddle mount tanks:
https://www.researchgate.net/publica...desaddle_Tanks
TxCajun is offline   Reply With Quote
Old 05-28-2019, 11:34 PM   #41
69 C10 LWB
Here is what I did for my radio. It is a cheap plastic cup holder/storage compartment. My dad had it in one of his trucks that I parted out. I had a radio that fit inside perfectly.
69 C10 LWB is offline   Reply With Quote
Old 05-29-2019, 03:05 PM   #42
sirJim
Original air cleaner top with K&N filter with lots of breathing room.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
