Old 05-31-2019, 05:52 PM   #1
Funstuie
Dakota Digital Tachometer wiring?
hey all,
I got a Dakota Digital VFD and I am struggling to wire it up - I have got most of it wired up now but I don't know how to wire up the tachometer and their tech support has not responded (it's Friday so I will forgive them).
It says to tap into the ignition coil and my dumb new question is - how?
Funstuie is offline   Reply With Quote
Old 05-31-2019, 11:06 PM   #2
86454k30
86454k30's Avatar
Re: Dakota Digital Tachometer wiring?
There is no oem coil wire in your harness. You need a run a new wire to the distributor. If you have an HEI you have an open mail spade terminal that says tach on the distributor cap.
86454k30 is offline   Reply With Quote
Old 05-31-2019, 11:09 PM   #3
86454k30
86454k30's Avatar
Originally Posted by Funstuie View Post
hey all,
see picture
Old 05-31-2019, 11:11 PM   #4
SunSoaked
SunSoaked's Avatar
What year are we talking about? On the back of the dizzy cap you should have a 3 wire plug and two recessed male terminals. The cap will have a stamp for each of the two terminals, one says "Batt" and one says "Tach". The tach wire or terminal is the one that needs to go to the Dakota tach signal.
SunSoaked is offline   Reply With Quote
Old 05-31-2019, 11:13 PM   #5
Funstuie
Thanks. I checked and there’s a tach connection on the distributor. So I just run a wire from that through the firewall?
I still can’t work out the Shifter module setup but at least I can sort the tach.
Old 06-01-2019, 01:43 PM   #6
nlped
nlped's Avatar
Yes, that’s all you need to do for the tach wiring.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-03-2019, 08:05 AM   #7
44boggers
Follow the provided directions on setting up the shifter module. There is a set up procedure to get it to sync with your trans .
44boggers is offline   Reply With Quote
