Old 06-18-2019, 10:40 PM   #1
RostaRob
58 Apache sun visor
Size:  29.0 KBSo one of these is not like the other. Does anyone know why this would be? This is the original cab and pillar. It just doesn't gave the large hole for the visor bracket spring to go into. I found no evidence of it being welded up or replaced. Do the make different visor for the passenger side? I'm at a loss. Rob.
RostaRob is offline   Reply With Quote
Old 06-19-2019, 05:11 AM   #2
1project2many
Re: 58 Apache sun visor
"Okay folks, step away from the A pillar. There's nothing to see here."
That's factory., The instructions for installing a RH visor include "Drill hole 1-1/2 inch diameter."
http://chevy.oldcarmanualproject.com...cpctai207.html
1project2many is offline   Reply With Quote
Old 06-19-2019, 08:58 AM   #3
Divine 59
^^^ 1project2many is spot on. That is factory. My low option 59 did not have a passenger sun visor and has the same stamping. Some vendors used to include a paper template with the RH interior visor so it could be located correctly. I plan on doing the same as you. Your passengers will like you better if they don't have to squint or hold a hand up to shade their eyes.
My Build Thread http://s95.photobucket.com/user/drop...?sort=3&page=1
Divine 59 is offline   Reply With Quote
Old 06-19-2019, 12:34 PM   #4
paulspickupparts
Most of the standard trucks did not come with a RH visor. Custom cab trucks often did. The Rh visor is different than the LH.
paulspickupparts is offline   Reply With Quote
Old 06-19-2019, 01:24 PM   #5
1project2many
Interesting. How is it different? I did what many people did and used a LH visor for the right side of my truck. After the new upholstery it looked like it belonged there.
Old 06-19-2019, 04:54 PM   #6
paulspickupparts
The visor is symetrical to the left hand visor . They each carry the opposite swing angle. Each has it own Chevrolet part number. If you are at a swap meet and see a bunch of arms look on the back. Next to the part # it will have an RH for the passenger side and a LH for the drivers side.
Old 06-19-2019, 05:20 PM   #7
Russell Ashley
Russell Ashley's Avatar
There are three stamped indentions where you drill the holes for the screws if the truck has not had a right side visor. I made a template from the driver side and placed it over the three drilled holes on the passenger side to locate the large hole for the right side visor mount. When I bought my visors there was no mention of right and/or left. I have the factory style speaker housing above the windshield and the driver side visor almost touches it but there is a couple of inches between the passenger side visor and it. The speaker housing has a notch for the mirror bracket so can't be moved but this might be why it looks like the drivers side visor should be shorter.
Russell Ashley is offline   Reply With Quote
Old 06-19-2019, 07:24 PM   #8
Ironworking
Ironworking's Avatar
Originally Posted by RostaRob View Post
Attachment 1912773
Attachment 1912774So one of these is not like the other. Does anyone know why this would be? This is the original cab and pillar. It just doesn't gave the large hole for the visor bracket spring to go into. I found no evidence of it being welded up or replaced. Do the make different visor for the passenger side? I'm at a loss. Rob.
Sweet looking ride. I so like two tone paint jobs better than a single color.
Ironworking's "diamond" in the rough 58 chevy lwb fleetside custom build.
100% Service Connected Disabled Vietnam Era Veteran.
Ironworking is offline   Reply With Quote
Old 06-19-2019, 11:07 PM   #9
RostaRob
Thank you all for the info. I never would have thought that having a passenger visor (or stamped hole for one) would be considered an upgrade. I guess I'll have to get out my hol saw and get er done. FYI... my truck looks much beetr in person than the picture... silver and black with metallic
Old 06-19-2019, 11:41 PM   #10
RostaRob
Old 06-20-2019, 12:45 PM   #11
1project2many
That's a good point. I'll have to look at mine to see if the RH visor swings down toward the seat as it's pulled away from the windshield. If not then it must be a RH visor and the fog has crept further into my memory.
Old 06-21-2019, 12:03 PM   #12
Russell Ashley
During this thread when the term "visor" was used I was thinking of the visor that you pull down and not the bracket. That's why I said in my previous comment that I thought they were both alike. Hey, I'm old, sometimes it takes me a while to catch on, LOL.
Old 07-01-2019, 11:26 AM   #13
Dan in Pasadena
Dan in Pasadena's Avatar
Well, that answers a question I have had about my truck. The hole in the right side looks like it was eaten there by metal chewing mice! I imagine someone didn't have a hole saw and instead made a series of small holes in a circular pattern. Oh well.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-01-2019, 10:09 PM   #14
1project2many
Yeah... I imagine there aren't too many people that happen to have a 1-1/2" hole saw around. And the smart ones are going to be nervous about using it because the roof panel is close to the inside panel. I honestly can't even remember how I put the hole in mine. Probably using a rotary file on a die grinder.
Old 07-01-2019, 10:21 PM   #15
Ironworking
Being an ironworker, i am in love with tools. So, i have just about every size hole saw blade all the way up to 5 inches. LOL. Ironically though, i am without a welding machine at the moment.
Old 07-04-2019, 02:11 PM   #16
_Ogre
_Ogre's Avatar
heater was an upgrade option back then
shop air compressor timer
Old 07-04-2019, 05:28 PM   #17
1project2many
Chevrolet options included:
Heater
4 speed or Hydramatic transmission
fuse box
Turn signals
V8
Electric wipers
RH Visor
Inside Mirror
Spare tire
Deluxe Cab
Big Back Window
Windshield Washers
V8 engine
16" wheels
Rear Bumper
Old 07-09-2019, 02:27 PM   #18
paulspickupparts
Here are pics of a nice original RH visor I listed in the parts section.
