Old 08-01-2019, 07:58 PM   #1
Old65C10
Roof Rack for Suburban?
Anyone know of a roof rack for the Square Suburbans? Did they have one from the factory as an option? Were they sturdy?
I am outfitting mine as an Overlander for camping and exploring and I need a roof rack to mount a few things to.
I sold my welder a few years back and don't have money for a good replacement so welding one up is out. I thought about using pipe, but I am afraid it would cost a lot and look like poo.
I want to mount things like an Awning, water storage/shower, tire, my High-Lift jack, Light bar, etc.
Any suggestions?
Old65C10 is offline   Reply With Quote
Old 08-01-2019, 08:40 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Roof Rack for Suburban?
I have one on a 1979 Parts Suburban
Old 08-01-2019, 10:45 PM   #3
mrtoni
You should find a con-ferr rack. I actually have a few. They mount to the gutters but we’re discontinued maybe 15 years ago. Con-ferr conferr or con ferr on Craigslist. Run about $300-700 depending on length. Make sure it has mounts
mrtoni is offline   Reply With Quote
Old 08-02-2019, 11:55 AM   #4
Old65C10
Too bad you are so far away, Shipping the rack would be really expensive due to the size, unless it comes apart.
I have been doing some looking at 8020 extruded Aluminum to build one. It would cost $400 and I could design it myself with lots of modular possibilities. So, if a Conn-Fer is going to cost more, I will stay with the 8020.
I would still need to add some fake drip rail mounts like you see on canopies some times.
Old 08-02-2019, 03:53 PM   #5
Old65C10
So far it looks like I can build a rack from Aluminum Extrusion (8020) for about $600 and it be custom made for my needs. It will be all T slot extrusion and will give me a ton of modular capability for adding, attaching and changing things as needed. Now I just have to save up the money to do it.
Old 08-02-2019, 11:16 PM   #6
1976gmc20
I built crossbar racks for a canoe on my old Suburban out of scrap 1x2 oak that I got for free from the shop where I worked at the time.
I just cut out a couple good pieces about four feet long, plus four pieces about six inches long with ends cut 45* for spacers. I used four 1/4" carriage bolts for mounting and drilled through the layers of oak and through the roof at appropriate places on the raised ridges. It never leaked with the oak tightened down against the raised ridge on the sheet metal. It helped that I had no headliner anyway!
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 08-04-2019, 02:05 PM   #7
Old65C10
That is not a bad idea, and I do have a lot of wood, some oak from pallets. However I am wanting to turn this into an Overlanding rig to camp and travel in. I am thinking the 8020 route may the best for my needs. It will give me unlimited options to mount anything I want and not have to drill holes everywhere. From what I am seeing it is going to cost me $500 for any decent rack, even used. I can build the 8020 rack for that much and have a lot more flexibility. So, unless I find a real bargain on a used rack, that is the way I will go. Just need to save up the cash.
I bought the Suburban and a 96 BMW R1100RT motorcycle this month and the registration fees alone have cost me $800. My current budget is in the negatives till I can either sell some stuff or something.
Old 08-05-2019, 11:39 AM   #8
1976gmc20
Four through bolts is plenty, and a heck of a lot more secure than clamping to drip rails. But I can see why you might not want to take down and put back up your headliner.
I used the oak because I had it, and to not have metal on metal rubbing anywhere. The wood was a buffer between the roof and the aluminum canoe. The carriage bolt heads sucked down into the wood and I only had to tighten from the inside. After we traded off that Suburban for a 4x4 version, we saw the old one being driven around town still with the custom oak boat rack
The other thing is that whatever you make it out of, think about having a couple of permanent simple rails (either crosswise or lengthwise) and then clamping/bolting whatever basket or box to that so you can easily take it off, but still have a secure mounting.
Old 08-06-2019, 11:53 AM   #9
Ski-me
Ski-me's Avatar
I used Yakima on my old one....
Spacing could change a bit depending on your needs. Mine was driven for the fairing and the bike rack trays.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 09-30-2019, 02:01 PM   #10
j_cst_10
j_cst_10's Avatar
I believe my truck has a factory roof rack. It's a 91 and my wife's parents bought the truck in 94. Sturdy I would say not, enough to mount one of those totes above it but that's about it.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 11-12-2019, 09:29 AM   #11
RDrancher
RDrancher's Avatar
I know this is a couple months old, but I was on CL and saw this ad for racks. Looks like they make them for just about everything. Prices look pretty good too. http://bajavoodoo.com/roof_racks Here's the CL ad... https://dallas.craigslist.org/dal/pt...008864850.html
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 11-05-2020, 07:51 PM   #12
malc1080
Anyone own a 1979-1980 suburban factory 454? I need help and need a picture of the emission sticker diagram please. I need to pass smog. Thank you
malc1080 is offline   Reply With Quote
Old 11-05-2020, 10:37 PM   #13
malc1080
This work?
Yes ! Thank you so much! Finally I got the help! Is there any way I can get a clearer picture? I can get the picture made into a deal by a company.
Old 11-05-2020, 11:25 PM   #14
Warrens69GMC
Tomorrow ok? Its pitch black here........
Old 11-05-2020, 11:26 PM   #15
malc1080
This work?
In surprised it doesn’t have air cleaner with hoses to it like this emission sticker of a 1980 350 I was trying to follow. I knew it wasn’t accurate. I wonder if your suburban is a federal car and not for Cali...
Old 11-05-2020, 11:29 PM   #16
Warrens69GMC
Mine is federal, that one is Cali......
Old 11-05-2020, 11:46 PM   #17
malc1080
I wish I didn’t live in Cali. Thank you so much for trying to help out.. unfortunately i need Cali emission approved so i can pass state ref and approve they motor swap.
Old 11-05-2020, 11:57 PM   #18
Warrens69GMC
Looks like you are in Louisiana.....
Old 11-05-2020, 11:59 PM   #19
malc1080
No I’m in California lol
Old 11-14-2020, 01:37 PM   #20
kwmech
If you are just looking for a diagram of the vacuum lines, they can probably be had at the local library or from a smog station.
Old 11-14-2020, 02:30 PM   #21
malc1080
Thanks for replying . But i won’t be able to make my c10 smog legal and the 454 will have to be removed since it was not an engine option for c10s. Cali is strict so I’ll be going back to finding a cheap 350 to put in and follow my smog diagram as original . Thank you
Old 11-15-2020, 11:58 PM   #22
Irish1941
Irish1941's Avatar
Man hate seeing this..you do know you can go back on guy who sold it to you for smog repairs. Small claims court(DMV is no help here) and you will likely not get any cash BUT DMV will make his life miserable. And if he title jumped it's even worse.
"The seller is required to provide the buyer with a valid smog inspection certification at the time of the sale or transfer. Smog certifications are good for 90 days from the date of issuance."
SELLER is responsible for vehicle to pass smog. Cal law.
Irish1941 is offline   Reply With Quote
