07-03-2019, 06:07 PM | #26 | |
Re: "Dixie" 1988 Chevrolet V30 3+3 Dually
07-04-2019, 09:11 AM | #27 |
Glad it helped. I had searched across the internet and see a lot of HD trucks running it. I also had the chance to speak to a local shop here that works on a lot of 3/4 ton and dually trucks and the service manager had said he has only had great experiences with them, so fingers crossed.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
08-04-2019, 10:52 PM | #28 |
I have been slacking on this thread.
Work has been keeping me on busy, so it has been a lot of ordering parts and prepping. The Vintage Air unit was charged and has been blowing ice cold. Moving on to the steering. Redhead box had arrived. I also planned to upgrade the powering steering pump to PSC 1405h unit with a cooler, remote reservoir, and remote fill while I was in there.
08-04-2019, 10:58 PM | #29 |
This morning I started pulling everything apart. I will be going back with a hydroboost setup on the truck. The Redhead steering box is also ported for a ram assist setup down the road.
The original box
08-04-2019, 11:03 PM | #30 |
While I was changing the steering box out I decided it would be wise to install a steering brace. The truck will have 35s" installed in the coming weeks so I decided to do it now. This is ORD's steering brace and you can instantly tell how much it beefs everything up. After I had that in, the Redhead box fell right into place. I am really excited about testing this steering box out, I have heard great things.
08-04-2019, 11:11 PM | #31 |
The power steering bracket from the factory setup was not in great condition. The bolts were stripped out and the pulley split when I pulled it off. In addition to a power steering pump, I looked around for a new bracket kit.
Here is the ICT Billet power steering bracket. It fit great on my big block and is stout. I am waiting for my new power steering pulley before putting it on.
08-04-2019, 11:21 PM | #32 |
While I wait for my power steering pulley I decided to start the steering shaft upgrade. SCOTI has been going through this upgrade (http://67-72chevytrucks.com/vboard/s...=505196&page=2) the last week and I have been following along closely.
It is always great when someone has the answers to the exam. If anyone is wondering - the steering shaft is the Crown Automotive Steering Shafts 4713943 from Summit Racing. I am going to finish it up this week.
08-05-2019, 09:05 AM | #33 |
Looking good. I like how much stronger everything appears to be over the stock components.
08-05-2019, 10:15 AM | #34 |
Thanks. The truck is going to be my daily eventually and I wanted it to be as strong as possible. I have yet to be disappointed by the products I have ordered - most of them come from recommendations from others on the board so it has made life a bit easier.
08-05-2019, 11:32 AM | #35 | |
On the shaft swap, watch the hardware (threads) if you don't file anything off the gear-box or column stub. The supplied hardware would work but it wanted to gall my SS stuff. After seeing both types galled, I would file the ends of the box/column shafts if possible or do what I did w/slightly smaller dia hardware. The box end is easy enough to access for filing but the column end on mine would have required more effort.
08-05-2019, 11:50 AM | #36 | |
What do you mean by filing off some material? Cast flashing or cleaning up the edges before assembly?
08-05-2019, 12:23 PM | #37 | |
The steering box end of the new XJ shaft is the same arrangement, but the metric hardware barely clears:
08-05-2019, 01:02 PM | #38 |
Column end:
08-06-2019, 02:27 PM | #39 |
Ok, I see it now.
What I've done on aviation applications is center drill a hole in the outer shaft, put a counter sink in the inner shaft then file the hardware to a point so that it is seated in a hole without protruding through to the other side. |
08-07-2019, 11:12 PM | #40 |
Thanks again SCOTI. The driveshaft will be a project this week to finish.
Went to install my new power steering pulley and found that it interfered with one of the heads on the bolts. I ordered a replacement OEM 2 groove pulley from Summit that should be here tomorrow. Also ordered the power steering fluid for the unit. I am looking to get this wrapped up this week and move onto the next project.
08-24-2019, 04:43 PM | #41 |
I finished up the power steering project a couple weeks ago.
I laid the parts out on the bench to get started. Along with PSC's power steering pump for my hydro boost system, I also went with their remote reservoir, cooler, and remote anti-splash fluid vent. It was a package that 4 Wheel Parts was offering for a short period of time and was a great deal.
08-24-2019, 04:46 PM | #42 |
I tried to keep everything clean looking and very serviceable. PSC recommends trying to keep the filler line as short as possible and gravity fed. I fabricated up a small bracket and attached it to Vintage Air's compressor bracket. Unfortunately when I was painting the bracket the temperature did not cooperate, so I will have to remove it and repaint it once I have time for the smaller parts.
08-24-2019, 04:55 PM | #43 |
The last component to the steering upgrade was finishing the upgrade from the rag joint to the Jeep shaft. I followed SCOTI's explanation on the Jeep Shaft installation. I end up putting a set screw in the shaft to tighten everything up and make it serviceable. Like the power steering reservoir, I will repaint the steering shaft.
Next up - wheels and tires
08-24-2019, 05:04 PM | #44 |
Wheels and tires have been a focal point for the last month. The truck now rides much better, however the tires have been showing their age and I was not crazy about the wheels. To the internet I went to source suitable substitutes.
I really like the Fuel Maverick D436 wheels since they are Matte Black. Unfortunately those wheels are stud centric and not hub centric which is what I need for the truck so back to the drawing board.
08-24-2019, 05:10 PM | #45 |
After talking to Fuel they said they offer Mavericks (D538) as hub centric which is what I needed. Unfortunately they come milled and could not be pulled early off the assembly line to prevent this.
So there was no other choice - I ordered the D538s. Friday afternoon I received the call they had arrived and I transported them directly to powder coating. They will be coming back in 2 weeks in matte black. They will be getting wrapped with Toyo Open Country tires.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) Last edited by focusedontheprize; 08-24-2019 at 05:22 PM. |
09-05-2019, 01:26 PM | #46 |
Wheels were completed on Wednesday, so the powdercoater was nice enough to drop them off at the shop where they will be mounted. I was a little concerned because I wouldn't be able to put eyes on them before they mounted.
Then I received the text: "Oh these look awesome". So that is a relief. The tires also arrived on Wednesday so now we should be cooking with gas. Hopefully by Friday Dixie will have a set of new shoes.
09-05-2019, 01:34 PM | #47 |
Thanks to all the responses to the "Purchase BB exhaust manifolds" post I moved forward on sourcing a new set along with the Flowmaster 70 Series mufflers. The truck currently has Flowmaster 40s on it that do not extend to the rear, but either way I wanted the truck as quiet as I could get it. The truck will be heading in for exhaust next week while I am traveling.
My buddy sent me this yesterday when I told him about the project. This at the moment is my favorite meme template.
09-16-2019, 07:56 AM | #48 |
cool projekt, love the truck , please check PN
10-07-2019, 09:18 PM | #49 |
10-07-2019, 09:21 PM | #50 |
I have been working on the truck on and off, but now am back on it full time.
After I replaced the power steering pump, I noticed a small weep underneath the hydro boost. I imagine since the hydro boost system was operating so efficiently, those 30+ year old seals couldn't hold back the fluid like they use to. I end up doing a complete reseal kit on the hydro boost unit and installed a new master cylinder. Unfortunately I didn't take any photos, but it was a good step ahead.
